Garuda Login taking too long, around 1 or 2 minutes. And unable to launch Garuda settings manager
Whenever I login to Garuda the screen freezes and the cursor turns to ×, and then comes the black screen and it takes some time to load the desktop even though it is default (not customized)
I mean the login and loading of desktop is taking its sweet time which is around 1 minute.
Is it like that only or is it taking too long for me.
And also unable to launch Garuda settings manager, it’s icon is loading and going away.
All things are up to date as of time I posted this.
My specs RYZEN 7 7745HX, 32 GB DDR5 RAM, 2×1TB GEN4 SSD(SN770), RTX 4060
One issue per topic, please.
For garuda-settings-manager see (still open as of now):
For the login time you should definitely provide more info. At least:
garuda-inxi (see new topic template…)
systemd-analyze
systemd-analyze blame
systemd-analyze critical-chain
Kernel: 6.14.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-linux-zen
root=UUID=60b58089-17d0-400c-a93c-251340096be7 rw quiet loglevel=3
Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.12.0
Type: Laptop System: Alienware product: Alienware m16 R1 AMD v: 1.16.0
serial: <superuser required> Chassis: type: 10 v: 1.16.0
Mobo: Alienware model: 09FRTK v: A00 serial: <superuser required>
part-nu: 0BFD uuid: <superuser required> UEFI: Alienware v: 1.16.0
date: 02/06/2025
ID-1: BAT0 charge: 61.9 Wh (100.0%) condition: 61.9/84.3 Wh (73.4%)
volts: 12.0 min: 11.4 model: BYD DELL M59JH39 type: Li-poly serial: <filter>
status: full cycles: 72
Info: model: AMD Ryzen 7 7745HX with Radeon Graphics bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x61 (97) stepping: 2 microcode: 0xA60120C
desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 1490 min/max: 400/5153 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1490 2: 1490 3: 1490
4: 1490 5: 1490 6: 1490 7: 1490 8: 1490 9: 1490 10: 1490 11: 1490 12: 1490
13: 1490 14: 1490 15: 1490 16: 1490 bogomips: 114989
Device-1: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile] vendor: Dell
driver: nvidia v: 570.133.07 alternate: nouveau,nvidia_drm
non-free: 550/565.xx+ status: current (as of 2025-01) arch: Lovelace
code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4
speed: 16 GT/s lanes: 8 ports: active: none empty: DP-1, DP-2, HDMI-A-1,
eDP-1 bus-ID: 01:00.0 chip-ID: 10de:28e0 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Dell
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-2
empty: DP-3, DP-4, DP-5, HDMI-A-2, Writeback-1 bus-ID: 0a:00.0
chip-ID: 1002:164e class-ID: 0300 temp: 60.0 C
Device-3: Realtek Integrated_Webcam_FHD driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-1:2 chip-ID: 0bda:555a
gpu: amdgpu display-ID: 0
Monitor-1: eDP-2 model: BOE Display 0x0b04 built: 2022 res:
mode: 2560x1600 hz: 240 scale: 125% (1.25) to: 2048x1280 dpi: 188 gamma: 1.2
size: 345x215mm (13.58x8.46") diag: 407mm (16") ratio: 16:10 modes:
max: 2560x1600 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia drv: amd radeonsi
platforms: device: 0 drv: nvidia device: 1 drv: radeonsi device: 2
drv: nouveau device: 3 drv: swrast gbm: drv: kms_swrast surfaceless:
drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 25.0.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 610M (radeonsi
raphael_mendocino LLVM 19.1.7 DRM 3.61 6.14.2-zen1-1-zen)
device-ID: 1002:164e memory: 500 MiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.309 layers: 14 device: 0 type: integrated-gpu name: AMD
Radeon 610M (RADV RAPHAEL_MENDOCINO) driver: N/A device-ID: 1002:164e
surfaces: xcb,xlib,wayland device: 1 type: discrete-gpu name: NVIDIA
GeForce RTX 4060 Laptop GPU driver: N/A device-ID: 10de:28e0
Device-1: NVIDIA AD107 High Definition Audio vendor: Dell
vendor: Dell driver: snd_rpl_pci_acp6x v: kernel alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_pci_ps,
bus-ID: 0a:00.5 chip-ID: 1022:15e2 class-ID: 0480
vendor: Dell driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 0a:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.14.2-zen1-1-zen status: kernel-api with: aoss
Device-1: Qualcomm QCNFA765 Wireless Network Adapter vendor: Foxconn
driver: ath11k_pci v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 1
bus-ID: 07:00.0 chip-ID: 17cb:1103 class-ID: 0280
IF: wlp7s0 state: up mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Dell driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 2000 bus-ID: 09:00.0
Device-1: Foxconn / Hon Hai driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1.2:4 chip-ID: 0489:e0e3
Local Storage: total: 1.84 TiB used: 1.36 TiB (74.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: PM9A1 NVMe 1024GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 36310229 temp: 37.9 C
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Western Digital
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731100WD temp: 44.9 C scheme: GPT
ID-1: / raw-size: 293.66 GiB size: 288.49 GiB (98.24%)
used: 38.14 GiB (13.2%) fs: ext4 dev: /dev/nvme1n1p9 maj-min: 259:13
used: 332 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p7 maj-min: 259:11
ID-1: swap-1 type: zram size: 30.53 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme1n1p8 maj-min: 259:12
System Temperatures: cpu: 73.9 C mobo: 41.8 C
Memory: total: 32 GiB note: est. available: 30.53 GiB used: 3.42 GiB (11.2%)
Processes: 401 Power: uptime: 1m states: freeze,mem,disk suspend: s2idle
image: 12.15 GiB services: org_kde_powerdevil, power-profiles-daemon,
Packages: pm: pacman pkgs: 1809 libs: 535 tools: octopi,paru pm: flatpak
pkgs: 0 Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 4.0.1 running-in: konsole inxi: 3.3.37
System install date:     2025-04-17
Last full system update: 2025-04-18
And I’m getting laggy experience in apps like blender
Output from:
