Hello ,
I am new to this forum.
I have booted a live Garuda xfce .iso to determine if it is suitable for me.
I found a few problems that may only be in the live session (I don't know).
- Cannot find package manager to install anything.
- Could not use terminal tom install either as it states that the package cannot be found. Packages tried were 'nemo' and others.
- In the file manager there is an entry 'Network' that shows 'Windows Network'. But clicking that produces nothing. On some other live distros, the computers on the network are shown and furthermore Windows shares in the computers are accessible.
Are these problems restricted to the live session?
As requested the result of garuda-inxi follows:
[[email protected] ~]$ garuda-inxi
Kernel: 5.15.74-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
misobasedir=garuda misolabel=GARUDA_XFCE_TALON quiet
systemd.show_status=1 ibt=off systemd.unified_cgroup_hierarchy=1
driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Dell product: Latitude E6410 v: 0001
Mobo: Dell model: 07XJP9 v: A03 serial: <superuser required> BIOS: Dell
v: A16 date: 12/05/2013
ID-1: BAT0 charge: 21.1 Wh (100.0%) condition: 21.1/57.7 Wh (36.6%)
volts: 12.2 min: 11.1 model: Sanyo DELL KY26695 type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i5 M 560 bits: 64 type: MT MCP arch: Westmere
gen: core 1 level: v2 built: 2010-11 process: Intel 32nm family: 6
model-id: 0x25 (37) stepping: 5 microcode: 0x7
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1463 min/max: 1199/2667 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1463 2: 1463 3: 1463
4: 1463 bogomips: 21277
vulnerable
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
prctl and seccomp
Device-1: NVIDIA GT218M [NVS 3100M] vendor: Dell driver: nouveau v: kernel
non-free: series: 340.xx status: legacy (EOL) last: release: 340.108
kernel: 5.4 xorg: 1.20 arch: Tesla process: 40-80nm built: 2006-13 pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 ports: active: eDP-1
empty: DP-1,DP-2,VGA-1 bus-ID: 01:00.0 chip-ID: 10de:0a6c class-ID: 0300
temp: 57.0 C
Device-2: Ricoh Laptop_Integrated_Webcam_3M type: USB driver: uvcvideo
bus-ID: 1-1.4:3 chip-ID: 05ca:180f class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver:
X: loaded: nouveau unloaded: modesetting alternate: fbdev,nv,vesa
dri: nouveau gpu: nouveau display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1280x800 s-dpi: 96 s-size: 338x211mm (13.31x8.31")
s-diag: 398mm (15.69")
Monitor-1: eDP-1 model: Seiko Epson 0x5441 built: 2010 res: 1280x800
hz: 60 dpi: 107 gamma: 1.2 size: 303x190mm (11.93x7.48")
diag: 358mm (14.1") ratio: 16:10 modes: max: 1280x800 min: 800x600
Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Dell
Latitude E6410 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:3b56 class-ID: 0403
Device-2: NVIDIA High Definition Audio vendor: Dell driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:0be3 class-ID: 0403
Sound API: ALSA v: k5.15.74-1-lts running: yes
Device-1: Intel 82577LM Gigabit Network vendor: Dell Latitude E6410
driver: e1000e v: kernel port: 8040 bus-ID: 00:19.0 chip-ID: 8086:10ea
Device-2: Intel Centrino Advanced-N 6200 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:422c
Local Storage: total: 946.36 GiB used: 100.63 GiB (10.6%)
model: WD10SPZX-00Z10T0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A01 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 type: USB model: General Flash Disk 3.0
size: 14.84 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 1.99 scheme: MBR
ID-1: swap-1 type: zram size: 7.75 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 57.0 C mobo: N/A sodimm: SODIMM C gpu: nouveau
temp: 58.0 C
Fan Speeds (RPM): cpu: 2917
Processes: 206 Uptime: 39m wakeups: 1 Memory: 7.75 GiB used: 1.39 GiB
(17.9%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1239 libs: 332
tools: paru Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.22
Garuda (2.6.8-1):
System install date: 2023-02-06
Last full system update: 2023-02-06 ↻
