Garuda RANI application fails to authenticate administrator/superuser password.
When attempting to use the Garuda RANI application to make changes to the system or install applications, RANI refuses to accept my administrator/superuser password. The password works in terminal and everywhere else within Garuda Linux.
I did a clean reinstall of Garuda Linux just in case something corrupted during the install. The issue was not resolved. I checked for any selinux or apparmor restrictions which might be causing issues but wasn’t able to find anything. I did several google searches looking for any known information about issues with Garuda RANI and found nothing. I was able to run Garuda RANI in terminal via the command “sudo garuda-rani” and it partially worked. My password was accepted once I ran Garuda RANI as root. I was able to install/remove programs and make some system changes, but I couldn’t run any maintenance operations as they’d immediately fail.
Kernel: 6.13.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=d0448bbc-5121-4e4c-b22c-ff492861db9a rw rootflags=subvol=@
quiet resume=UUID=f2d85756-3787-4f9a-ad77-98e6fe02f346 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.11.0
Type: Desktop Mobo: Micro-Star model: MAG B550 TOMAHAWK MAX WIFI (MS-7C91)
v: 1.0 serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: 2.60 date: 10/10/2023
Info: model: AMD Ryzen 7 5800XT bits: 64 type: MT MCP arch: Zen 3+ gen: 3
Speed (MHz): avg: 3597 min/max: 550/4966 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3597 2: 3597 3: 3597
4: 3597 5: 3597 6: 3597 7: 3597 8: 3597 9: 3597 10: 3597 11: 3597 12: 3597
13: 3597 14: 3597 15: 3597 16: 3597 bogomips: 121600
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21 [Radeon RX 6800/6800 XT
/ 6900 XT] vendor: XFX driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-1,DP-2 empty: DP-3,HDMI-A-1,Writeback-1
bus-ID: 2d:00.0 chip-ID: 1002:73bf class-ID: 0300
gpu: amdgpu d-rect: 3840x1080 display-ID: 0
Monitor-1: DP-1 pos: primary,left model: Samsung C24F390 serial: <filter>
built: 2021 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9 modes:
Monitor-2: DP-2 pos: right model: 100002480 serial: <filter> built: 2020
res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 104 gamma: 1.2
size: 470x290mm (18.66x11.65") diag: 552mm (21.7") ratio: 16:10 modes:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6800 (radeonsi navi21
LLVM 19.1.7 DRM 3.61 6.13.6-zen1-1-zen) device-ID: 1002:73bf
API: Vulkan v: 1.4.304 layers: 14 device: 0 type: discrete-gpu name: AMD
Radeon RX 6800 (RADV NAVI21) driver: N/A device-ID: 1002:73bf
de: kscreen-console,kscreen-doctor gpu: corectrl,lact wl: wayland-info
Device-1: Creative Labs CA0132 Sound Core3D [Sound Blaster Recon3D /
Z-Series BlasterX AE-5 Plus] driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 1102:0012 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
bus-ID: 2d:00.1 chip-ID: 1002:ab28 class-ID: 0403
API: ALSA v: k6.13.6-zen1-1-zen status: kernel-api with: aoss
bus-ID: 29:00.0 chip-ID: 14c3:0616 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 2a:00.0
IF: enp42s0 state: down mac: <filter>
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:6 chip-ID: 0e8d:0616
Local Storage: total: 1.82 TiB used: 19.23 GiB (1.0%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 30.9 C
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 19.23 GiB (1.1%)
used: 19.23 GiB (1.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 40.5 C mobo: 32.2 C gpu: amdgpu temp: 33.0 C
mem: 32.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 940
Memory: total: 32 GiB available: 31.26 GiB used: 4.39 GiB (14.0%)
Processes: 434 Power: uptime: 43m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
Packages: 1836 pm: pacman pkgs: 1827 libs: 537 tools: octopi,paru
pm: flatpak pkgs: 9 Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 4.0.1 running-in: konsole inxi: 3.3.37
System install date: 2025-03-14
Last full system update: 2025-03-14 ↻
Failed units:~~~
SGS
14 March 2025 16:59
2
It’s a known bug, maybe it will be fixed ASAP.
Just do not use special chars like ; \ …
Or just reboot
Would I be assuming correctly not to use _ either?
Well considering when I try to launch any tool from Rani the password box empties and nothing happens it must be most if not all special characters.
FGD
14 March 2025 19:33
5
Probably, at the moment I would not use any char other than letters and numbers.
OK for now I can just install and use Garuda Maintenance and Garuda Assistant if they’re not installed already as independent apps.
This will be solved in the pending update. We still need to finish testing this one however.
