Hi , I installed artix on virtual box and their repo is too short... I managed to make the pacman in artix look like garuda qtile edition which i have(i looked the garuda qtile pacman.conf file and edited the artix pacman.conf accordingly). but i want to add garuda repo in artix for additional softwares . Any guidance please
Hi,
You can add chaotic AUR repo with the help provided on
For additional packages.
Garuda repo has Garuda specific packages, and is hosted on same mirrors as Chaotic repo. So you can easily add chaotic repo, then add garuda in pacman.conf file.
I hope it is understandable and your problem is solved.
