Ich nutze garuda KDE auf meinem Laptop. Wenn ich in den Energieoptionen die maxmimale Akkuladung auf 85% begrenze, funktioniert es erstmal, aber nach einem Neustart steht wieder 100% in den Einstellungen.
Kann man da was machen?
Kernel: 6.7.0-zen3-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
root=UUID=78b03f8f-972f-4050-baa3-7db8ef1a7aee rw rootflags=subvol=@
resume=UUID=53133d09-797f-4dc0-a5e8-84c4e044a87d loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 vt: 2
Type: Laptop System: ASUSTeK product: ROG Strix G713QR_G713QR v: 1.0
Mobo: ASUSTeK model: G713QR v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G713QR.327 date: 03/29/2022
ID-1: BAT0 charge: 82.0 Wh (97.0%) condition: 84.5/90.0 Wh (93.9%)
volts: 17.0 min: 15.9 model: AS3GWYF3KC GA50358 type: Li-ion
microcode: 0xA50000B
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3359 high: 4566 min/max: 400/4890 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3652 2: 3633 3: 3653
4: 3652 5: 4566 6: 3758 7: 4418 8: 3654 9: 3678 10: 400 11: 4038 12: 3653
13: 3652 14: 3289 15: 3653 16: 400 bogomips: 105407
Device-1: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: ASUSTeK
status: current (as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
off: DP-1 empty: none bus-ID: 01:00.0 chip-ID: 10de:249d class-ID: 0300
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 06:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 51.0 C
gpu: amdgpu,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
s-diag: 1245mm (49.01")
Monitor-1: DP-1 mapped: DP-1-0 note: disabled pos: bottom-l
model: EIZO NANAO CG241W serial: <filter> built: 2013 res: 1920x1200 hz: 60
dpi: 94 gamma: 1.2 size: 519x324mm (20.43x12.76") diag: 616mm (24.2")
ratio: 16:10 modes: max: 1920x1200 min: 640x480
Monitor-2: eDP-1 mapped: eDP pos: primary,top-right
model: BOE Display 0x0a08 built: 2021 res: 2560x1440 hz: 165 dpi: 171
gamma: 1.2 size: 381x214mm (15x8.43") diag: 437mm (17.2") ratio: 16:9
modes: max: 2560x1440 min: 640x480
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast surfaceless:
drv: nvidia x11: drv: radeonsi inactive: gbm,wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 23.3.3-arch1.1
renoir LLVM 16.0.6 DRM 3.56 6.7.0-zen3-1-zen) device-ID: 1002:1638
memory: 500 MiB unified: no
API: Vulkan v: 1.3.274 layers: 8 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 23.3.3-arch1.1
device-ID: 1002:1638 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 3070 Laptop GPU driver: nvidia v: 545.29.06
device-ID: 10de:249d surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.3-arch1.1 (LLVM
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637
snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
API: ALSA v: k6.7.0-zen3-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
Device-3: Realtek RTL8152 Fast Ethernet Adapter driver: r8152 type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.2:4
chip-ID: 0bda:8152 class-ID: 0000 serial: <filter>
IF: enp6s0f3u1u2 state: up speed: 100 Mbps duplex: full mac: <filter>
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 13d3:3563
Local Storage: total: 1.4 TiB used: 201.35 GiB (14.1%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Samsung
model: MZVLQ1T0HBLB-00B00 size: 953.87 GiB block-size: physical: 512 B
fw-rev: FXM7201Q temp: 28.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
model: MZVLB512HAJQ-000L2 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 4L1QEXA7 temp: 31.9 C scheme: GPT
ID-1: / raw-size: 459.76 GiB size: 459.76 GiB (100.00%)
used: 201.35 GiB (43.8%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-3: /home raw-size: 459.76 GiB size: 459.76 GiB (100.00%)
ID-4: /var/log raw-size: 459.76 GiB size: 459.76 GiB (100.00%)
ID-5: /var/tmp raw-size: 459.76 GiB size: 459.76 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.04 GiB used: 1.43 GiB (9.5%)
ID-2: swap-2 type: partition size: 16.89 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:3
System Temperatures: cpu: 63.1 C mobo: 32.0 C gpu: amdgpu temp: 52.0 C
Fan Speeds (rpm): cpu: 2500
Processes: 418 Uptime: 1h 16m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.05 GiB used: 9.87 GiB (65.6%) Init: systemd v: 255
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1650
pm: pacman pkgs: 1642 libs: 515 tools: octopi,paru pm: flatpak pkgs: 8
Shell: fish v: 3.7.0 default: Bash v: 5.2.21 running-in: konsole
inxi: 3.3.31
Garuda (2.6.22-1):
System install date: 2023-01-01
Last full system update: 2024-01-16
