plamen
11 December 2024 06:13
1
Hellow guys yesterday i installed Garuda KDE Dr460nized and after i tryed anothers ked editions but in all of them i ges same issue:
after fresh install and update when start Garuda setup Asssistant and check “pamac” or zen 4 kernel i get this error
Installing packages…
error: no targets specified (use -h for help)
Error! Press enter to return to setup assistant.
Can someone explain me how to resolve this problem?
filo
11 December 2024 07:32
2
Please provide the output of garuda-inxi
, as required in the topic template.
Have you tried again after rebooting after the initial update?
The linux-amd kernel (currently linked to the zen4 entry in the assitant) is probably not maintained anymore (I guess we should remove this from the set-up assistant), see:
I don’t think there is one (yet).
The previous maintainer of all linux-amd* kernels left a while back and ever since some others took over but don’t keep it updated as precisely and thoroughly as the previous one. Many kernel CONFIGs are missing completely from the corresponding znver* config.x86_64 files.
As far as I understood, the mainline linux-amd (which Garuda offers part of its Garuda Setup Assistant even though it’s only at 6.10.5!) will work with Zen5, but won’t take advantage of its …
But Pamac should be there.
plamen
11 December 2024 17:37
4
Ok let explain situation for more details:I have two mashines - new build for my work and old for daily driver.When i go home i will list `garuda-inxi’.Now i will list inxi from my old mashine but here i get same issue whit garuda setup assistant.On this mashine i have already pamac but when i check it for installation error is same as error on new mashine.
This is post from inxi of old mashine.
Kernel: 6.12.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=4d73d6ed-24dc-458b-86c6-634600930cae rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Desktop Mobo: ASUSTeK model: P7P55 LX v: Rev X.0x
BIOS: American Megatrends v: 1102 date: 01/03/2011
Info: model: Intel Xeon X3470 bits: 64 type: MT MCP arch: Nehalem level: v2
built: 2008-10 process: Intel 45nm family: 6 model-id: 0x1E (30) stepping: 5
microcode: 0xA
Speed (MHz): avg: 1677 min/max: 1200/2934 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 1677 2: 1677 3: 1677
4: 1677 5: 1677 6: 1677 7: 1677 8: 1677 bogomips: 47096
Device-1: Advanced Micro Devices [AMD/ATI] Juniper PRO [Radeon HD 6750]
vendor: PC Partner / Sapphire driver: radeon v: kernel alternate: amdgpu
arch: TeraScale-2 code: Evergreen process: TSMC 32-40nm built: 2009-15
pcie: gen: 2 speed: 5 GT/s lanes: 16 ports: active: DP-1
empty: DVI-I-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 1002:68bf class-ID: 0300
temp: 47.0 C
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
alternate: fbdev,vesa dri: r600 gpu: radeon display-ID: :0 screens: 1
s-diag: 777mm (30.58")
Monitor-1: DP-1 mapped: DisplayPort-0 model: AOC Q3279WG5B
serial: <filter> built: 2019 res: 2560x1440 hz: 60 dpi: 90 gamma: 1.2
size: 725x428mm (28.54x16.85") diag: 842mm (33.1") ratio: 15:9 modes:
max: 2560x1440 min: 720x400
API: EGL v: 1.5 hw: drv: amd r600 platforms: device: 0 drv: r600 device: 1
drv: swrast gbm: drv: kms_swrast surfaceless: drv: r600 x11: drv: r600
inactive: wayland
API: OpenGL v: 4.5 vendor: mesa v: 24.3.1-arch1.3 glx-v: 1.4
direct-render: yes renderer: AMD JUNIPER (DRM 2.50.0 / 6.12.1-zen1-1-zen
LLVM 18.1.8) device-ID: 1002:68bf memory: 1000 MiB unified: no
API: Vulkan v: 1.4.303 layers: 4 device: 0 type: cpu name: llvmpipe (LLVM
18.1.8 128 bits) driver: N/A device-ID: 10005:0000 surfaces: xcb,xlib
Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3b56
Device-2: Advanced Micro Devices [AMD/ATI] Juniper HDMI Audio [Radeon HD
5700 Series] vendor: PC Partner / Sapphire driver: snd_hda_intel v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aa58
API: ALSA v: k6.12.1-zen1-1-zen status: kernel-api
Device-1: Realtek RTL-8100/8101L/8139 PCI Fast Ethernet Adapter
driver: 8139too v: 0.9.28 modules: 8139cp port: e800 bus-ID: 07:03.0
chip-ID: 10ec:8139 class-ID: 0200
IF: enp7s3 state: unknown speed: 100 Mbps duplex: full mac: <filter>
IF-ID-2: virbr1 state: down mac: <filter>
Local Storage: total: 2.3 TiB used: 1.38 TiB (60.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM008-2UB102
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Philips model: USB Flash Drive
size: 28.91 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
fw-rev: PMAP scheme: MBR
ID-1: / raw-size: 200 GiB size: 200 GiB (100.00%) used: 118.25 GiB (59.1%)
fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 250 GiB size: 250 GiB (100.00%)
used: 163.84 GiB (65.5%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /var/log raw-size: 200 GiB size: 200 GiB (100.00%)
used: 118.25 GiB (59.1%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-4: /var/tmp raw-size: 200 GiB size: 200 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.6 GiB used: 1.46 GiB (9.4%) priority: 100
System Temperatures: cpu: 37.0 C mobo: 27.0 C gpu: radeon temp: 48.0 C
Fan Speeds (rpm): cpu: 1222 psu: 0 case-1: 1074
Power: 12v: 12.15 5v: N/A 3.3v: 3.33 vbat: N/A
Memory: total: 16 GiB available: 15.6 GiB used: 4.52 GiB (29.0%)
Processes: 345 Power: uptime: 1d 16h 21m states: freeze,mem,disk
reboot, suspend, test_resume image: 6.23 GiB
services: org_kde_powerdevil,upowerd Init: systemd v: 256
Packages: 2124 pm: nix-default pkgs: 52 pm: nix-sys pkgs: 0 pm: nix-usr
pkgs: 0 pm: pacman pkgs: 2072 libs: 491 tools: octopi,pamac Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.37
System install date: 2024-11-30
Last full system update: 2024-12-11 ↻
Failed units: samba.service
Tonight i will post from another.`Preformatted text`
FGD
12 December 2024 00:52
5
Yeah you are right, I just did it.
Next inline is ZNVER2, we could say it’s not maintained anymore, been 2 months, but maybe we can wait a little more.
system
Closed
26 December 2024 00:53
6
