Garuda is running this Appimage (Viva Designer) on my laptop but not on my desktop
I’ve been wanting to try this alternative to InDesign called Viva Designer (also proprietary though), which the publisher provides for Linux as an AppImage. Here I learned that having a cross-distro packaging format doesn’t mean it supports all the distros - the company will look at your problems only if it’s Debian, Ubuntu or Suse Leap.
My problem being that, starting it from the GUI, nothing happens. It tried the terminal, this is the output:
 ./VivaDesigner-11.5.0.9224.appimage
qt.qpa.plugin: Could not find the Qt platform plugin "wayland" in ""
QFont::fromString: Invalid description 'Fira Sans,10,-1,5,400,0,0,0,0,0,0,0,0,0,0,1'
QFont::fromString: Invalid description 'FiraCode Nerd Font Mono,10,-1,5,400,0,0,0,0,0,0,0,0,0,0,1'
fish: Job 1, './VivaDesigner-11.5.0.9224.appi…' terminated by signal SIGSEGV (Adressbereichsfehler)
No, I don’t know how to fix an address range error - do you?
This is the desktop system:
× garuda-inxi
Kernel: 6.18.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=f2f0c810-347a-4c8d-a7e6-7ab94d88296c rw rootflags=subvol=@
quiet resume=UUID=c3653fce-ff77-435e-bd21-efcdc7c6ccaf loglevel=3
Desktop: KDE Plasma v: 6.5.5 tk: Qt v: N/A info: frameworks v: 6.22.0
wm: kwin_wayland tools: avail: lxlock vt: 1 dm: SDDM Distro: Garuda
Type: Desktop System: Micro (HK) Tech product: Neptune series v: N/A
Mobo: Shenzhen Meigao Equipment model: AHBAA serial: <superuser required>
uuid: <superuser required> Firmware: UEFI vendor: American Megatrends LLC.
v: 1.0E date: 06/09/2023
Info: model: 12th Gen Intel Core i7-12650H bits: 64 type: MST AMCP
microcode: 0x43A
Topology: cpus: 1x dies: 1 clusters: 7 cores: 10 threads: 16 mt: 6 tpc: 2
st: 4 smt: enabled cache: L1: 864 KiB desc: d-4x32 KiB, 6x48 KiB; i-6x32
KiB, 4x64 KiB L2: 9.5 MiB desc: 6x1.2 MiB, 1x2 MiB L3: 24 MiB
desc: 1x24 MiB
Speed (MHz): avg: 1009 min/max: 400/4600:4700:3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 1009 2: 1009 3: 1009
4: 1009 5: 1009 6: 1009 7: 1009 8: 1009 9: 1009 10: 1009 11: 1009 12: 1009
13: 1009 14: 1009 15: 1009 16: 1009 bogomips: 86016
Device-1: Intel Alder Lake-P GT1 [UHD Graphics] driver: i915 v: kernel
alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports:
active: none empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:46a3 class-ID: 0380
Device-2: Intel DG2 [Arc A730M] vendor: IP3 Tech driver: i915 v: kernel
alternate: xe arch: Xe-HPG code: Alchemist process: TSMC n6 (7nm)
built: 2022+ pcie: gen: 1 speed: 2.5 GT/s lanes: 1 ports: active: HDMI-A-3
empty: HDMI-A-4 bus-ID: 03:00.0 chip-ID: 8086:5691 class-ID: 0300
Device-3: Microsoft Microsoft LifeCam Cinema
driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 1-1.1:4 chip-ID: 045e:0812 class-ID: 0102
Monitor-1: HDMI-A-3 model: BenQ GW2760 serial: <filter> built: 2015 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 82 gamma: 1.2
device: 1 drv: iris device: 2 drv: swrast gbm: drv: iris surfaceless:
drv: iris wayland: drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc A730M Graphics (DG2)
device-ID: 8086:5691 memory: 5.81 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.335 layers: 10 device: 0 type: discrete-gpu name: Intel
Arc A730M Graphics (DG2) driver: mesa intel v: 25.3.4-arch1.1
device-ID: 8086:5691 surfaces: N/A device: 1 type: integrated-gpu
name: Intel Graphics (ADL GT2) driver: mesa intel v: 25.3.4-arch1.1
device-ID: 8086:46a3 surfaces: N/A device: 2 type: cpu name: llvmpipe
(LLVM 21.1.6 256 bits) driver: mesa llvmpipe v: 25.3.4-arch1.1 (LLVM
Device-1: Intel Alder Lake PCH-P High Definition Audio driver: snd_hda_intel
chip-ID: 8086:51c8 class-ID: 0403
Device-2: Intel DG2 Audio vendor: IP3 Tech driver: snd_hda_intel v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:4f90
API: ALSA v: k6.18.7-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I225-V driver: igc v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0 chip-ID: 8086:15f3
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 07:00.0
IF: wlp7s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:5 chip-ID: 8087:0032
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.4
lmp-v: 13 status: discoverable: no pairing: no class-ID: 6c0104
Local Storage: total: 2.75 TiB used: 572.91 GiB (20.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PGP41024Q-A0
lanes: 4 tech: SSD serial: <filter> fw-rev: ELFK0S.6 temp: 34.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT2000MX500SSD1
tech: SSD serial: <filter> fw-rev: 033 scheme: GPT
ID-1: / raw-size: 919.34 GiB size: 919.34 GiB (100.00%)
used: 572.87 GiB (62.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 668 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 919.34 GiB size: 919.34 GiB (100.00%)
ID-4: /var/log raw-size: 919.34 GiB size: 919.34 GiB (100.00%)
ID-5: /var/tmp raw-size: 919.34 GiB size: 919.34 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.11 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.23 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 48.0 C mobo: N/A
Fan Speeds (rpm): cpu: 1276
Memory: total: 32 GiB note: est. available: 31.11 GiB used: 6.21 GiB (20.0%)
Processes: 431 Power: uptime: 23m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.43 GiB services: org_kde_powerdevil,
Packages: 1960 pm: pacman pkgs: 1923 libs: 448
tools: octopi,pacseek,pamac,paru pm: appimage pkgs: 0 pm: flatpak pkgs: 37
Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Bash v: 5.3.9 default: fish
v: 4.3.3 running-in: konsole inxi: 3.3.40
Garuda (2.12.3-2):
System install date:     2024-12-04
Last full system update: 2026-02-01
25/26 checks run in 1.24 seconds ⌛
Powered by garuda-health 🦅
Anyhow, the strange part is that it does run on my Laptop which also runs Garuda, I just click the AppImage file and it launches.
Terminal output:
╰─λ ./VivaDesigner-11.5.0.9224_453866eddd7c6a6e0a942cc78891a26e.AppImage
QFont::fromString: Invalid description 'Fira Sans,13,-1,5,400,0,0,0,0,0,0,0,0,0,0,1'
That’s all.
System info:
[🔍] × garuda-inxi
root=UUID=dc229e5a-50c1-478a-b84b-e60401e4d6c0 rw rootflags=subvol=@
resume=UUID=258393c9-45c2-4f11-9c89-8fb56cf7d7ab loglevel=3
Type: Laptop System: TUXEDO product: TUXEDO v: N/A
serial: <superuser required> Chassis: Notebook type: 10
Mobo: TUXEDO model: N141CU serial: <superuser required>
uuid: <superuser required> Firmware: UEFI vendor: INSYDE v: 1.07.07RTR1
date: 11/08/2019
ID-1: BAT0 charge: 28.3 Wh (83.4%) condition: 33.9/35.3 Wh (96.1%)
volts: 11.48 min: 11.4 model: Notebook BAT type: Li-ion serial: <filter>
charging: status: discharging cycles: N/A
Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
stepping: 0xC (12) microcode: 0x100
Speed (MHz): avg: 3400 min/max: 400/4900 scaling: driver: intel_pstate
governor: powersave cores: 1: 3400 2: 3400 3: 3400 4: 3400 5: 3400 6: 3400
7: 3400 8: 3400 bogomips: 36799
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: CLEVO/KAPOK
Device-2: Chicony USB2.0 Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:4 chip-ID: 04f2:b649
class-ID: 0e02
Monitor-1: eDP-1 model: AU Optronics 0x543d built: 2017 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 158 gamma: 1.2
size: 309x174mm (12.17x6.85") diag: 355mm (14") ratio: 16:9
modes: 1920x1080
device-ID: 8086:9b41 memory: 15.07 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.335 layers: 10 device: 0 type: integrated-gpu
name: Intel UHD Graphics (CML GT2) driver: mesa intel v: 25.3.4-arch1.1
device-ID: 8086:9b41 surfaces: N/A device: 1 type: cpu name: llvmpipe
Device-1: Intel Comet Lake PCH-LP cAVS vendor: CLEVO/KAPOK
API: ALSA v: k6.18.7-zen1-1-zen status: kernel-api with: aoss
vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 5000 bus-ID: 3b:00.1 chip-ID: 10ec:8168 class-ID: 0200
IF: enp59s0f1 state: down mac: <filter>
Device-2: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 40:00.0
IF: wlp64s0 state: up mac: <filter>
IF-ID-1: wwp0s20f0u2c3 state: down mac: <filter>
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.1
Local Storage: total: 1.41 TiB used: 643.15 GiB (44.6%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 28.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT525MX300SSD1
size: 489.05 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: R060 scheme: GPT
ID-1: / raw-size: 936.72 GiB size: 936.72 GiB (100.00%)
used: 643.15 GiB (68.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 664 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 936.72 GiB size: 936.72 GiB (100.00%)
ID-4: /var/log raw-size: 936.72 GiB size: 936.72 GiB (100.00%)
ID-5: /var/tmp raw-size: 936.72 GiB size: 936.72 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.43 GiB used: 20 MiB (0.1%) priority: 100
ID-2: swap-2 type: partition size: 16.85 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 55.0 C pch: 43.0 C mobo: N/A
Memory: total: 16 GiB available: 15.43 GiB used: 5.15 GiB (33.4%)
Processes: 308 Power: uptime: 23m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.15 GiB services: org_kde_powerdevil,
Packages: 2198 pm: pacman pkgs: 2144 libs: 508 tools: paru pm: appimage
pkgs: 0 pm: flatpak pkgs: 54 Compilers: clang: 21.1.6 gcc: 15.2.1
Shell: Bash v: 5.3.9 running-in: konsole inxi: 3.3.40
Garuda (2.12.3-2):
System install date:     2023-10-28
Garuda release:          230501
Last full system update: 2026-01-30
25/26 checks run in 1.21 seconds ⌛
The best idea I can come up with for a reason is that the desktop has a dedicated Intel Arc GPU, and the laptop is just IntelHD onboard, but if that should actually be the reason for the problem, I still don’t know where to take it from there - any hints greatly appreciated!
EDIT: I’ve tried launching the app a) with the integrated graphics, prefixing the command with DRI_PRIME=1, as well as b) with software rendering, using LIBGL_ALWAYS_SOFTWARE=1, also c) trying to force X11 with QT_QPA_PLATFORM=xcb, all of these got me the same SIGSEV error
Downloaded the AppImage and it´s working here. Maybe you are missing some QT5/QT6 dependencies. I would compare the installations on desktop with those on Laptop.
Hey.
You need to contact the application developers about this. This has nothing to do with Garuda Linux.
What might fix the issue for you is to create a new user on your desktop and sign in with that new user, and then run the AppImage file again (on that new user). If it works, that means the program 100% has a bug.
Those are not relevant for AppImage files.
Yes, you’re right. After I logged out, it occurred to me too. AppImages usually come with everything they need :upside_down_face:
I tried creating a new user and ran it there. Sad to report, same issue (even the problems I had with Calengoo in the taskbar - different forum topic - are the same).
  • What useful info could I give the devs about this, when it runs on one system but not on another?
  • How exactly? I mean the goal would be to find out what is making the system behave differently (throwing a SIGSEV). In AppImage, there’s no difference between the application installs.
Side note, has someone maybe managed to make Affinity run on Garuda? I followed tutorials, same bad luck. I’m the bug magnet.
This was related to missing dependencies, which do not exist cause it´s an AppImage.
I have Affinity running in Garuda. I’ve used this repo:
Have you tried pre-pending these two env vars, in addition to QT_QPA_PLATFORM=xcb, QT_STYLE_OVERRIDE="" QT_QPA_PLATFORMTHEME="" ?
Also, not sure if it’s relevant, but the error mentions the font. Is it possible it’s missing from your system? Try (re-)installing these: ttf-fira-sans ttf-fira-code.
One last troubleshooting step, that may possibly expose more of the error, is if you extract the AppImage and then run the binary directly inside the extracted directory? See if it throws more useful errors/traces?
Thank you, I tried all your suggestions now.
Installing the font seemed to have no impact at all, also the SIGSEGV persists
I tried first just running the AppImage with the extra variables, then the extracted binary.
╭─ben@golem2 in ~/Apps/VivaDesigner/squashfs-root as 🧙 took 1s
[⚡] × QT_QPA_PLATFORM=xcb QT_STYLE_OVERRIDE="" QT_QPA_PLATFORMTHEME="" ./AppRun
fish: Job 1, 'QT_QPA_PLATFORM=xcb QT_STYLE_OV…' terminated by signal SIGSEGV (Adressbereichsfehler)╭─ben@golem2 in ~/Apps/VivaDesigner/squashfs-root as 🧙 took 1s
If I allow it to use Wayland, it can’t find the Qt platform plugin, otherwise same:
╭─ben@golem2 in ~/Apps/VivaDesigner/squashfs-root as 🧙 took 0s
╰─λ ./AppRun
fish: Job 1, './AppRun' terminated by signal SIGSEGV (Adressbereichsfehler)
This is truly so bizarre! Can we run an strace on the AppRun binary? like this? strace -f ./AppRun. Try with and without the pre-pended env vars. Perhaps the strace will show us which file/library is throwing the error?
Isn’t it? That’s why I said I’m always the bug magnet…
So without env vars, see here: Garuda's PrivateBin
With env vars, here: Garuda's PrivateBin
Honestly I have no idea how to read this, though…
EDIT: the above pastes don’t have the complete output, “only” the last couple hundred lines.
Complete output of
QT_QPA_PLATFORM=xcb strace ./VivaDesigner-11.5.0.9224.appimage 2>&1
Complete output of
QT_STYLE_OVERRIDE="" QT_QPA_PLATFORMTHEME="" QT_QPA_PLATFORM=xcb strace -f ./AppRun 2>&1
The app images must contain everything necessary to run the program. As already mentioned by TNE, please contact the relevant developers.
Will do, thanks. But as I mentioned:
I already did, first thing, their reaction was just generic stuff about running AppImages (“make sure it’s executable”), and that I have the wrong distro:
and
If I tell them it runs on one of my systems - just not this one - what do you think their response is gonna be? My guess is one of the fun quotes we can find on the Garuda Start page, like for isntance this:
grafik
Ok, I’m not entirely certain, but without env vars, it looks like it’s breaking after it’s trying to load /home/ben/Apps/VivaDesigner/squashfs-root/usr/lib/libresolv.so.2, with env vars, it appears to be this one it faults at /home/ben/Apps/VivaDesigner/squashfs-root/usr/lib/libnss_mdns_minimal.so.2 though this may be irrelevant, it does seem like both these libraries have something to do with network/dns stuff. I wonder if there’s a conflict between these libraries and what your system is running by default?
Beyond that, I’m really at a loss, sorry!
wired of course cuz it runs even on my lite version too and their is more packages missing as compared to dragonized or gaming or hypr.
opening on double click -launch or with just Pla..-xcb! no fira ttf installed…
Did you try the x11 session direktly?(login not wayland sddm)
checked qt5-wayland and qt6-wayland or vulkan-headers ?
