Garuda is also randomly camera error- internal usb controller after full update
My garuda-inxi :-
 ╰─λ garuda-inxi
    root=UUID=2ed2acf4-12e7-497f-8e9e-ffd85e2b465f rw rootflags=subvol=@
    quiet resume=UUID=2f3ba04a-a237-4756-a5f2-6aab596e0917 loglevel=3 ibt=off
  Desktop: GNOME v: 45.1 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM
    v: 45.0.1 Distro: Garuda Linux base: Arch Linux
  Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X412DA_X412DA
  Mobo: ASUSTeK model: X412DA v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: X412DA.316 date: 10/08/2021
  ID-1: BAT0 charge: 18.8 Wh (72.0%) condition: 26.1/37.1 Wh (70.4%)
    power: 5.2 W volts: 7.8 min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion
    serial: N/A status: discharging cycles: 432
  Info: model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64
    L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
    desc: 1x4 MiB
  Speed (MHz): avg: 1556 high: 2100 min/max: 1400/2100 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2100 2: 1255
    3: 1400 4: 1400 5: 1400 6: 2100 7: 1400 8: 1400 bogomips: 33537
    ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:15d8
    class-ID: 0300 temp: 37.0 C
  Device-2: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.1:3
    chip-ID: 13d3:56dd class-ID: 0e02 serial: <filter>
    compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
  Monitor-1: eDP-1 model: BOE Display 0x07f6 built: 2018 res: 1920x1080
    dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
  API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: AMD
    Radeon Vega 8 Graphics (RADV RAVEN) driver: mesa radv v: 23.2.1-arch1.2
    device-ID: 1002:15d8 surfaces: xcb,xlib,wayland device: 1 type: cpu
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.1
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_acp3x
    v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
    snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 3 speed: 8 GT/s
    lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
  API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api tools: N/A
  Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:24fd class-ID: 0280
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2.2:4
    chip-ID: 8087:0a2b class-ID: e001
  Local Storage: total: 476.94 GiB used: 6.35 GiB (1.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston
    model: RBUSNS8154P3512GJ3 size: 476.94 GiB block-size: physical: 512 B
    logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
    fw-rev: E8FK1A.2 temp: 29.9 C scheme: GPT
    used: 6.35 GiB (1.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-1: swap-1 type: zram size: 5.73 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 38.2 C mobo: N/A gpu: amdgpu temp: 38.0 C
  Fan Speeds (rpm): cpu: 2000
  Processes: 320 Uptime: 4m wakeups: 0 Memory: total: 6 GiB
  available: 5.73 GiB used: 1.91 GiB (33.4%) Init: systemd v: 254
  pm: pacman pkgs: 1096 libs: 364 tools: paru pm: flatpak pkgs: 0 Shell: Bash
  v: 5.2.15 running-in: gnome-terminal inxi: 3.3.31
Garuda (2.6.19-2):
  System install date:     2023-11-17
  Last full system update: 2023-11-18
After full update … ```
sudo pacman -Syu … System camera starts then stops… In nix it sometimes works sometimes not…
The first thing I would try is a different kernel.
First linux-lts going “back”, then linux-mainline “onwards”.
Then check the logs at the time the issue occurs.
Maybe you could try logging to x11 instead of Wayland, but I doubt this will help.
Loggin-n but setting Gnome_on_xorg before Pass-word entered system into working condition with specs of camera working again so x11 did the trick… Thanks
