Hi there, Garuda folks!
I was planning to try Garuda (with Qtile), but unfortunately, I failed to install it.
I downloaded the latest ISO and initiated the installation, but after entering the password into the login manager, my installation got stuck at "Reached target Graphical Interface".
Ctrl-Alt-F2 does not work, so I'm unable to run anything and have no idea what to do in this situation.
Apologies for the attached photo, and thank you in advance for your help.
p.s. I was going to attach a photo, but new users can't do it... so the last 5 lines are:
[ OK ] Finished Hold until boot process finishes up.
[ OK ] Finished Terminate Plymouth Boot Screen.
[ OK ] Reached target Multi-User System.
[ OK ] Started Simple Desktop Display Manager.
[ OK ] Reached target Graphical Interface.
p.p.s it's not an nvidia issue (as Google suggests me), I have an AMD gpu
Welcome
Please, can you post your garuda-inxi from live ISO?
Did you use the free driver from settings if live ISO start?
This has happened to me a few times in the past when trying to use the live USB. Make sure to try multiple times and if you manage to get to sddm, ensure you don't choose the Wayland session, as it doesn't work (yet). Make sure to choose the default session, not Wayland.
If you can't get the garuda-inxi
on the Qtile version, try the dr460nized live ISO. That one boots normally for me most of the time - not sure what it is about the Qtile one but it likes to get stuck sometimes.
Welcome btw
Sure, here is the garuda-inxi output Garuda's PrivateBin
I've tried both free and proprietary drivers, but the issue persists with both of themsame
Nice, chroot and install other kernel.
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_AU keytable=us tz=Europe/Athens
misobasedir=garuda root=miso:LABEL=GARUDA_QTILE_RAPTOR quiet systemd.show_status=1 ibt=off
systemd.unified_cgroup_hierarchy=1 driver=free nouveau.modeset=1 i915.modeset=1
radeon.modeset=1
Console: tty 2 DM: SDDM Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: MPG X670E CARBON WIFI (MS-7D70) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.60 date: 03/24/2023
Info: model: AMD Ryzen 9 7950X bits: 64 type: MT MCP arch: Zen 4 gen: 5 level: v4 note: check
built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25) model-id: 0x61 (97) stepping: 2
microcode: 0xA601203
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache: L1: 1024 KiB desc: d-16x32
KiB; i-16x32 KiB L2: 16 MiB desc: 16x1024 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3160 high: 4500 min/max: 3000/5880 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 4500 2: 3000 3: 3623 4: 3000 5: 3000 6: 3000
7: 3000 8: 3000 9: 3000 10: 4500 11: 4500 12: 3000 13: 3000 14: 3000 15: 3000 16: 3000
17: 3000 18: 3000 19: 3000 20: 3000 21: 3000 22: 3000 23: 3000 24: 3000 25: 3000 26: 3000
27: 3000 28: 3000 29: 3000 30: 3000 31: 3000 32: 3000 bogomips: 288027
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX] vendor: Gigabyte driver: amdgpu v: kernel
arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-1 empty: DP-2,HDMI-A-1,HDMI-A-2 bus-ID: 03:00.0 chip-ID: 1002:744c
Device-2: AMD Raphael vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2
code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: none empty: DP-3, DP-4, DP-5, HDMI-A-3 bus-ID: 19:00.0 chip-ID: 1002:164e
class-ID: 0300 temp: 44.0 C
Display: server: X.org v: 1.21.1.8 driver: X: loaded: amdgpu unloaded: modesetting,radeon
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu tty: 384x108
Monitor-1: DP-1 model: Dell U2723QE serial: <filter> built: 2022 res: 3840x2160 dpi: 163
gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9 modes: max: 3840x2160
min: 720x400
API: OpenGL Message: GL data unavailable in console and glxinfo missing.
Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 3-4:5 pcie: chip-ID: 03f0:078b gen: 4
class-ID: 0300 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab30 class-ID: 0403
Device-2: AMD Rembrandt Radeon High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 19:00.1
Device-3: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 19:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: HP HyperX SoloCast type: USB driver: hid-generic,snd-usb-audio,usbhid
Device-5: Micro Star USB Audio type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 3-9:7 chip-ID: 0db0:d6e7 class-ID: 0300
API: ALSA v: k6.2.13-zen-1-zen status: kernel-api tools: alsamixer,amixer
Server-1: PipeWire v: 0.3.70 status: off with: 1: pipewire-pulse status: off 2: wireplumber
status: off 3: pipewire-alsa type: plugin 4: pw-jack type: plugin
Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter driver: mt7921e
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 0f:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp15s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: e000 bus-ID: 10:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp16s0 state: down mac: <filter>
Device-1: MediaTek Wireless_Device type: USB driver: btusb v: 0.8 bus-ID: 3-8:6
chip-ID: 0e8d:0616 class-ID: e001 serial: <filter>
Local Storage: total: 2.74 TiB used: 0 KiB (0.0%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Western Digital model: WD BLACK SN850X 1000GB
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 620311WD temp: 48.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 2TB size: 1.82 TiB
block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 1B2QJXD7 temp: 47.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 type: USB model: USB DISK 3.0 size: 14.46 GiB block-size:
physical: 512 B logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: MBR
ID-1: swap-1 type: zram size: 61.96 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 48.2 C mobo: N/A
GPU: device: amdgpu temp: 44.0 C device: amdgpu temp: 49.0 C mem: 56.0 C fan: 12 watts: 18.00
Processes: 480 Uptime: 3m wakeups: 0 Memory: 61.96 GiB used: 2.23 GiB (3.6%) Init: systemd
v: 253 default: graphical tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1122
libs: 323 tools: pamac,paru Shell: Bash v: 5.1.16 running-in: tty 2 inxi: 3.3.26
System install date: 2023-06-22
Last full system update: 2023-06-22 ↻
Thank you so much. I've never used login screens or SDDM before, and this thing looked so appealing that I didn't even notice the different sessions are available to choose from.
However, it's disappointing that Wayland isn't supported yet, as that's the main reason I wanted to try Qtile.
I've just tested it with Xorg, and the issue disappeared. If there's a way to initiate a Wayland session though, I'd be keen to give it a try
Please forgive me if this question seems simple, but I'm still learning about Linux. If I use Xorg for a while to experiment with (or even grow accustomed to) Garuda and Qtile, would I be able to easily switch to Wayland later on (when it's operational) just by changing the session in SDDM? Or would this constitute a major change requiring most packages/system to be reinstalled?
Later on you can just simply select Wayland, no need to reinstall anything.
Good to know
Thank you all for help, folks
system
Closed
24 June 2023 17:07
10
