Here is the Output of your given code :
sudo -E calamares -d
QStandardPaths: runtime directory '/run/user/1000' is not owned by UID 0, but a directory permissions 0700 owned by UID 1000 GID 1001
09:15:55 [6]: Calamares::Settings::Settings(const QString&, bool)
Using Calamares settings file at "/etc/calamares/settings.conf"
WARNING: .. Required settings.conf key hide-back-and-next-during-exec is missing.
09:15:55 [6]: void Logger::setupLogfile()
Using log file: "/home/garuda/.cache/calamares/session.log"
09:15:55 [6]: void CalamaresApplication::init()
Calamares version: 3.2.37-1
.. languages: "ar, as, ast, az, az_AZ, be, bg, bn, ca, cs_CZ, da, de, el, en, en_GB, eo, es, es_MX, es_PR, et, eu, fa, fi_FI, fr, fur, gl, he, hi, hr, hu, id, is, it_IT, ja, ko, lt, ml, mr, nb, nl, pl, pt_BR, pt_PT, ro, ru, sk, sl, sq, sr, [email protected], sv, tg, th, tr_TR, uk, vi, zh_CN, zh_TW"
09:15:55 [6]: bool CalamaresUtils::initQmlModulesDir()
Using Calamares QML directory "/usr/share/calamares/qml"
09:15:55 [6]: Calamares::Branding::Branding(const QString&, QObject*)
Using Calamares branding file at "/usr/share/calamares/branding/garuda/branding.desc"
09:15:55 [2]: void Calamares::flavorAndSide(const YAML::Node&, const char*, Calamares::Branding::PanelFlavor&,Calamares::Branding::PanelSide&)
WARNING: Branding setting for sidebar is missing, using "widget" "left"
WARNING: Branding setting for navigation is missing, using "widget" "bottom"
09:15:55 [2]: Calamares::Branding::Branding(const QString&, QObject*)
WARNING: the branding component "/usr/share/calamares/branding/garuda" does not ship translations.
Loaded branding component "garuda"
.. Loaded QRC translation "tz_" "en_US"
.. Loaded QRC translation "calamares_" "en_US"
.. STARTUP: initSettings, initQmlPath, initBranding done
.. STARTUP: initModuleManager: module init started
09:15:55 [8]: Icon theme "papirus" not found.
09:15:55 [8]: Icon theme "tela" not found.
09:15:55 [8]: Icon theme "adwaita" not found.
09:15:55 [8]: Icon theme "gnome" not found.
09:15:55 [8]: Icon theme "ubuntu-mono" not found.
09:15:55 [8]: Icon theme "Mint-X" not found.
09:15:55 [8]: Icon theme "elementary" not found.
09:15:55 [6]: void Calamares::ModuleManager::doInit()
Found 48 modules
09:15:56 [6]: void CalamaresApplication::initView()
STARTUP: initModuleManager: all modules init done
STARTUP: initJobQueue done
09:15:56 [6]: CalamaresWindow::CalamaresWindow(QWidget*)
Available desktop QSize(1366, 742) minimum size QSize(1024, 520)
.. Proposed window size: 1024 600
09:15:56 [2]: QString Calamares::_stylesheet(const QDir&)
WARNING: The branding component "/usr/share/calamares/branding/garuda" does not ship stylesheet.qss.
STARTUP: CalamaresWindow created; loadModules started
09:15:56 [6]: void Calamares::Module::loadConfigurationFile(const QString&)
Loaded module configuration "/etc/calamares/modules/welcome.conf"
09:15:56 [6]: void Config::initLanguages()
Matching locale QLocale(English, Latin, United States)
.. Matched with index 13 "en_US"
09:15:56 [6]: void Config::setLocaleIndex(int)
Index 13 Selected locale QLocale(English, Latin, United States)
09:15:56 [6]: QPair<CalamaresUtils::Network::RequestStatus, QNetworkReply*> CalamaresUtils::Network::synchronousRun(QNetworkAccessManager*, const QUrl&, const CalamaresUtils::Network::RequestOptions&)
HTTP error QNetworkReply::HostNotFoundError on request for QUrl("https://ipapi.co/json")
09:15:56 [2]: virtual QString CalamaresUtils::GeoIP::GeoIPJSON::rawReply(const QByteArray&)
WARNING: Invalid YAML data for GeoIPJSON
09:15:58 [6]: virtual void Calamares::ViewModule::loadSelf()
ViewModule "[email protected]" loading complete.
09:15:58 [6]: void Calamares::Module::loadConfigurationFile(const QString&)
Loaded module configuration "/etc/calamares/modules/locale.conf"
Loaded module configuration "/usr/share/calamares/modules/keyboard.conf"
09:15:58 [6]: KeyboardModelsModel::KeyboardModelsModel(QObject*)
Loaded 188 keyboard models
09:15:58 [6]: KeyboardPage::KeyboardPage(Config*, QWidget*)
Variants now 0 -1
09:15:58 [6]: void Config::detectCurrentKeyboardLayout()
("pc", "us", "inet(evdev)", "terminate(ctrl_alt_bksp)\"")
09:16:11 [6]: virtual void Calamares::ViewModule::loadSelf()
09:16:11 [6]: void Calamares::Module::loadConfigurationFile(const QString&)
Loaded module configuration "/usr/share/calamares/modules/partition.conf"
09:16:11 [6]: CalamaresUtils::Partition::InternalManager::InternalManager()
KPMCore backend starting ..
09:16:11 [8]: Loaded backend plugin: "pmsfdiskbackendplugin"
.. Backend @0x556331131160 "pmsfdiskbackendplugin" "1"
09:16:11 [6]: CalamaresUtils::Partition::KPMManager::KPMManager()
KPMManager 1 created.
09:16:11 [6]: virtual void PartitionViewStep::setConfigurationMap(const QVariantMap&)
Setting firmwareType to "bios"
09:16:11 [6]: QString PartUtils::findFS(QString, FileSystem::Type*)
Found filesystem "btrfs"
Partition-module setting *defaultFileSystemType* "btrfs"
09:16:11 [2]: virtual void PartitionViewStep::setConfigurationMap(const QVariantMap&)
WARNING: Partition-module setting *defaultPartitionTableType* is unset, will use gpt for efi or msdos for bios
Loaded module configuration "/etc/calamares/modules/users.conf"
09:16:11 [6]: void Calamares::ModuleManager::loadModules()
Module "[email protected]" already loaded.
09:16:11 [6]: Calamares::SlideshowQML::SlideshowQML(QWidget*)
QML import paths:
"/usr/bin"
"qrc:/qt-project.org/imports"
"/usr/lib/qt/qml"
Loaded module configuration "/usr/share/calamares/modules/mount.conf"
Loaded module configuration "/etc/calamares/modules/unpackfs.conf"
Loaded module configuration "/etc/calamares/modules/machineid.conf"
09:16:11 [2]: virtual void MachineIdJob::setConfigurationMap(const QVariantMap&)
WARNING: MachineId: configuration setting *symlink* is deprecated, use *dbus-symlink*.
09:16:11 [6]: virtual void Calamares::CppJobModule::loadSelf()
CppJobModule "[email protected]" loading complete.
Loaded module configuration "/usr/share/calamares/modules/fstab.conf"
Loaded module configuration "/usr/share/calamares/modules/luksopenswaphookcfg.conf"
Loaded module configuration "/etc/calamares/modules/plymouthcfg.conf"
No config file for "initcpiocfg" found anywhere at
"/home/garuda/src/modules/initcpiocfg/initcpiocfg.conf"
"/etc/calamares/modules/initcpiocfg.conf"
"/usr/share/calamares/modules/initcpiocfg.conf"
Loaded module configuration "/etc/calamares/modules/initcpio.conf"
Loaded module configuration "/etc/calamares/modules/displaymanager.conf"
Loaded module configuration "/etc/calamares/modules/mhwdcfg.conf"
Loaded module configuration "/etc/calamares/modules/services.conf"
Loaded module configuration "/usr/share/calamares/modules/grubcfg.conf"
Loaded module configuration "/etc/calamares/modules/bootloader.conf"
Loaded module configuration "/etc/calamares/modules/postcfg.conf"
Loaded module configuration "/usr/share/calamares/modules/umount.conf"
Loaded module configuration "/etc/calamares/modules/finished.conf"
09:16:11 [2]: void Config::setConfigurationMap(const QVariantMap&)
WARNING: Configuring the finished module with deprecated restartNowEnabled settings
09:16:11 [6]: setGeoIP(Config*, const QVariantMap&)::<lambda()>
GeoIP result for welcome= ""
09:16:11 [6]: void setCountry(Config*, const QString&, CalamaresUtils::GeoIP::Handler*)
Unusable country code ""
.. Obtained from "https://ipapi.co/json" ( 1 "country" )
09:16:12 [6]: Config::Config(QObject*)::<lambda(int)>::<lambda()>
xkbmap selection changed to: "us" - ""
09:16:12 [6]: void CalamaresApplication::initViewSteps()
STARTUP: loadModules for all modules done
09:16:12 [6]: void Calamares::ModuleManager::checkRequirements()
Checking module requirements ..
09:16:15 [6]: void CalamaresApplication::initViewSteps()
STARTUP: Window now visible and ProgressTreeView populated
.. 8 view steps loaded.
.. Loaded QRC translation "kb_" "en_US"
09:16:15 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
Got 0 requirement results from "bootloader"
Got 0 requirement results from "displaymanager"
Got 0 requirement results from "finished"
Got 0 requirement results from "fstab"
Got 0 requirement results from "grubcfg"
Got 0 requirement results from "hwclock"
Got 0 requirement results from "initcpio"
Got 0 requirement results from "initcpiocfg"
Got 0 requirement results from "keyboard"
Got 0 requirement results from "locale"
Got 0 requirement results from "localecfg"
Got 0 requirement results from "luksbootkeyfile"
Got 0 requirement results from "luksopenswaphookcfg"
Got 0 requirement results from "machineid"
Got 0 requirement results from "mhwdcfg"
Got 0 requirement results from "mount"
Got 0 requirement results from "networkcfg"
09:16:16 [6]: QPair<CalamaresUtils::Network::RequestStatus, QNetworkReply*> CalamaresUtils::Network::synchronousRun(QNetworkAccessManager*, const QUrl&, const CalamaresUtils::Network::RequestOptions&)
09:16:16 [6]: void Calamares::RequirementsChecker::reportProgress()
Remaining modules: 9
"partition"
"plymouthcfg"
"postcfg"
"services"
"summary"
"umount"
"unpackfs"
"users"
"welcome"
09:16:17 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
"plymouthcfg"
"postcfg"
"services"
"summary"
"umount"
"unpackfs"
"users"
"welcome"
09:16:18 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
"plymouthcfg"
"postcfg"
"services"
"summary"
"umount"
"unpackfs"
"users"
"welcome"
09:16:20 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
"plymouthcfg"
"postcfg"
"services"
"summary"
"umount"
"unpackfs"
"users"
"welcome"
09:16:21 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
"plymouthcfg"
"postcfg"
"services"
"summary"
"umount"
"unpackfs"
"users"
"welcome"
09:16:22 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
"plymouthcfg"
"postcfg"
"services"
"summary"
"umount"
"unpackfs"
"users"
"welcome"
09:16:23 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
"plymouthcfg"
"postcfg"
"services"
"summary"
"umount"
"unpackfs"
"users"
"welcome"
09:16:24 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
"plymouthcfg"
"postcfg"
"services"
"summary"
"umount"
"unpackfs"
"users"
"welcome"
09:16:26 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
"plymouthcfg"
"postcfg"
"services"
"summary"
"umount"
"unpackfs"
"users"
"welcome"
09:16:27 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
"plymouthcfg"
"postcfg"
"services"
"summary"
"umount"
"unpackfs"
"users"
"welcome"
