Garuda hyprland with Mac Studio Display
Setting up Hyprland with Mac Studio Display.
I’m new to Hyprland and was able to install on my Asus G14 laptop and it works great. Just trying to see how to use my external display Mac Studio Display.
Would like to know if I can just use external display only with Hyprland and use both monitors at the same time. any examples will be great. Tried a few things but it’s not showing up on my external display and I end up breaking the config.
thanks for your help.
In the hustle and bustle of everyday life or perhaps in the heat of battle, it seems you overlooked the obligation to post the garuda-inxi terminal output requested in the template of your post.
The lack of terminal output from garuda-inxi makes it unnecessarily difficult for users to help and your post will be moved to 412 Precondition Failed Category.
