Garuda Hyprland February .iso
New user to Garuda here, but certainly not new to linux. I’ve been using linux since 1994 and was using Unix on PDP10/11 and AIX before that. I currently use Kali rolling on my other laptop and have been using that for the past several years. I was using the December .iso available on the site, but just found the February 18th .iso and installed it instead.
Running the Hyprland edition and I’ve got to say, the improvement to boot up time as well as the much improved waybar are outstanding!!
Here’s my inxi:
  Kernel: 6.7.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc
    v: 13.2.1 clocksource: tsc avail: hpet,acpi_pm
    root=UUID=a4a49def-8f04-4ef5-840b-90f375735347 rw
    rootflags=subvol=@ quiet loglevel=3 ibt=off
  Desktop: Hyprland v: 0.35.0-45-g7e8bcd67 with: waybar
    tools: avail: swayidle,swaylock vt: 1 dm: SDDM
  Type: Laptop System: TOSHIBA product: Satellite C55t-A
    v: PSCF6U-01T00D serial: <superuser required>
  Mobo: TOSHIBA model: Portable PC v: MP
    serial: <superuser required> part-nu: PSCF6U
    uuid: <superuser required> UEFI-[Legacy]: Insyde v: 1.40
    date: 04/28/2014
  ID-1: BAT0 charge: 27.2 Wh (100.0%)
    condition: 27.2/47.5 Wh (57.2%) volts: 10.8 min: 10.8
    model: PA5109U-1BRS type: Li-ion serial: <filter>
    status: full
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse
    M325 serial: <filter> charge: 100% (should be ignored)
    rechargeable: yes status: discharging
  Info: model: Intel Celeron 1005M bits: 64 type: MCP
    arch: Ivy Bridge level: v2 built: 2012-15
    process: Intel 22nm family: 6 model-id: 0x3A (58)
    stepping: 9 microcode: 0x21
  Topology: cpus: 1x cores: 2 smt: <unsupported> cache:
    L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
    desc: 2x256 KiB L3: 2 MiB desc: 1x2 MiB
  Speed (MHz): avg: 1720 high: 1882 min/max: 1200/1900
    scaling: driver: intel_cpufreq governor: schedutil cores:
    1: 1882 2: 1559 bogomips: 7582
  Device-1: Intel 3rd Gen Core processor Graphics
    vendor: Toshiba driver: i915 v: kernel arch: Gen-7
    process: Intel 22nm built: 2012-13 ports: active: LVDS-1
    empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0
    chip-ID: 8086:0156 class-ID: 0300
  Device-2: Importek TOSHIBA Web Camera - HD
    driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
    mode: 2.0 bus-ID: 1-1.3:4 chip-ID: 10f1:1a52
    class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.11 with: Xwayland
    v: 23.2.4 compositor: Hyprland v: 0.35.0-45-g7e8bcd67
    driver: X: loaded: modesetting alternate: fbdev,intel,vesa
    dri: crocus gpu: i915 display-ID: 1
  Monitor-1: LVDS-1 model: Samsung 0x4147 built: 2012
    res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 scale: 1
    size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 1366x768
  API: Vulkan v: 1.3.276 layers: 3 device: 0
    type: integrated-gpu name: Intel HD Graphics 2500 (IVB GT1)
    driver: mesa intel v: 24.0.1-arch1.1 device-ID: 8086:0156
    surfaces: xcb,xlib,wayland device: 1 type: cpu
    name: llvmpipe (LLVM 16.0.6 128 bits)
    driver: mesa llvmpipe v: 24.0.1-arch1.1 (LLVM 16.0.6)
  API: EGL Message: EGL data requires eglinfo. Check
    --recommends.
    vendor: Toshiba 7 driver: snd_hda_intel v: kernel
    bus-ID: 00:1b.0 chip-ID: 8086:1e20 class-ID: 0403
  API: ALSA v: k6.7.5-zen1-1-zen status: kernel-api
    tools: N/A
  Server-1: sndiod v: N/A status: off
    tools: aucat,midicat,sndioctl
  Server-2: PipeWire v: 1.0.3 status: active with:
    1: pipewire-pulse status: active 2: wireplumber
    status: active 3: pipewire-alsa type: plugin 4: pw-jack
    type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Qualcomm Atheros AR8162 Fast Ethernet
    vendor: Toshiba driver: alx v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0
    chip-ID: 1969:1090 class-ID: 0200
  IF: enp1s0 state: up speed: 100 Mbps duplex: full
    mac: <filter>
  Device-2: Realtek RTL8188EE Wireless Network Adapter
    driver: rtl8188ee v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8179
  Info: services: NetworkManager, systemd-timesyncd,
    wpa_supplicant
  Local Storage: total: 465.76 GiB used: 4.82 GiB (1.0%)
  SMART Message: Required tool smartctl not installed.
    Check --recommends
  ID-1: /dev/sda maj-min: 8:0 vendor: PNY
    model: CS900 500GB SSD size: 465.76 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD
    serial: <filter> fw-rev: 0P13 scheme: MBR
  ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
    used: 4.82 GiB (1.0%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
  ID-2: /home raw-size: 465.76 GiB
    size: 465.76 GiB (100.00%) used: 4.82 GiB (1.0%) fs: btrfs
  ID-3: /var/log raw-size: 465.76 GiB
  ID-4: /var/tmp raw-size: 465.76 GiB
  Kernel: swappiness: 133 (default 60)
    cache-pressure: 100 (default) zswap: no
  ID-1: swap-1 type: zram size: 15.5 GiB used: 0 KiB (0.0%)
    priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842
    max-streams: 2 dev: /dev/zram0
  System Temperatures: cpu: 56.0 C mobo: N/A
  Memory: total: 16 GiB available: 15.5 GiB
    used: 2.35 GiB (15.2%)
  Processes: 173 Power: uptime: 16m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 0 hibernate: platform
    avail: shutdown, reboot, suspend, test_resume
    image: 6.19 GiB services: upowerd Init: systemd v: 255
  Packages: pm: pacman pkgs: 1271 libs: 368
    tools: octopi,pacseek,paru Compilers: gcc: 13.2.1
    Shell: garuda-inxi default: fish v: 3.7.0
    running-in: xfce4-terminal inxi: 3.3.33
Garuda (2.6.23-1):
  System install date:     2024-02-18
  Last full system update: 2024-02-18 ↻
This is installed on an old as heck Toshiba Satellite C55 touchscreen with 16gb ram and a 500gb SSD. I was running the KDE version of Garuda and this is a million times faster on this dated machine (though Garuda KDE was faster then Kali KDE even with all effects turned on!)
Keep up the outstanding work guys!
Many thanks for the praise and
garuda welcome 2 :slight_smile:
