Garuda Hardware acceleration problem
Hello,
I’ve noticed some issues with my Garuda system when using certain apps like Brave, VSCode, and Notion. There is a noticeable latency when typing in these apps, and they also seem to run a bit slowly, despite my having a good GPU. Sometimes, the apps even start blinking.
@Kayo Thanks :slight_smile:
We do not support
Please, follow the template and post log from terminal as text
Open the apps in terminal, check the log for warnings and errors.
Kernel: 6.9.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=422ec04c-6bb8-42ff-9f58-71efee96dd8f rw rootflags=subvol=@
quiet loglevel=3 nvidia-drm.modeset=1 ibt=off
Desktop: KDE Plasma v: 6.1.0 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Laptop System: LENOVO product: 81Y6 v: Lenovo Legion 5 15IMH05H
serial: <superuser required> Chassis: type: 10 v: Lenovo Legion 5 15IMH05H
Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN
serial: <superuser required> part-nu: LENOVO_MT_81Y6_BU_idea_FM_Legion 5
15IMH05H uuid: <superuser required> UEFI: LENOVO v: EFCN52WW
date: 07/27/2021
ID-1: BAT0 charge: 21.8 Wh (42.1%) condition: 51.8/60.0 Wh (86.3%)
power: 32.7 W volts: 14.8 min: 15.4 model: Celxpert L19C4PC0 type: Li-poly
serial: <filter> status: discharging cycles: 827
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xFA
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 849 high: 900 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 900 3: 900 4: 800
5: 900 6: 900 7: 800 8: 800 9: 800 10: 894 11: 900 12: 800 bogomips: 62399
Device-1: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Lenovo
driver: nvidia v: 550.90.07 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none off: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1f15 class-ID: 0300
Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2 chip-ID: 174f:244c
compositor: kwin_wayland driver: X: loaded: nvidia gpu: nvidia display-ID: 0
x11: drv: zink inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.90.07
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
memory: 5.86 GiB display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 7 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 2060 driver: nvidia v: 550.90.07
device-ID: 10de:1f15 surfaces: xcb,xlib,wayland
Device-1: Intel Comet Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_soc_skl, snd_soc_avs, snd_sof_pci_intel_cnl
Device-2: NVIDIA TU106 High Definition Audio vendor: Lenovo
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f9
API: ALSA v: k6.9.6-zen1-1-zen status: kernel-api with: aoss
IF: wlp0s20f3 state: down mac: <filter>
port: 3000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp7s0 state: up speed: 100 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0026
Local Storage: total: 1.82 TiB used: 51.61 GiB (2.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: MSI model: M450 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: EJFM61.0 temp: 37.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPSX-08A6W
tech: HDD rpm: 7200 serial: <filter> fw-rev: 1A01 scheme: GPT
ID-1: / raw-size: 210.7 GiB size: 210.7 GiB (100.00%)
used: 51.58 GiB (24.5%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-2: /boot/efi raw-size: 1015.6 MiB size: 1013.6 MiB (99.80%)
used: 30.6 MiB (3.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 210.7 GiB size: 210.7 GiB (100.00%)
ID-4: /var/log raw-size: 210.7 GiB size: 210.7 GiB (100.00%)
ID-5: /var/tmp raw-size: 210.7 GiB size: 210.7 GiB (100.00%)
System Temperatures: cpu: 52.0 C pch: 55.0 C mobo: N/A
Memory: total: 16 GiB available: 15.53 GiB used: 6.48 GiB (41.8%)
Processes: 401 Power: uptime: 14h 5m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 2 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 6.17 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2174 libs: 581 tools: octopi,paru,yay
Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: fish
v: 3.7.1 running-in: konsole inxi: 3.3.35
System install date:     2024-06-13
Last full system update: 2024-06-26
Try x11 instead of wayland. You can switch from wayland to x11 on the login screen at the bottom left.
And you can also try disabling hardware acceleration in brave.
