I just installed garuda dragonizd gaming and it only connects to my phones wifi and not my router
I use a Dell Latitue 7390 PC
Given it will connect to wifi, why is this an issue with Garuda and not your router?
Restart your router and restart your system then try again...!!
First disconnect your hotspot.
And welcome to forums.
becaue ot keeps asking me for the password to the router
Did it countles nuber of times
Diconnect??? How do you mean?
Try:-
Garuda Network Assistant -> Restart Wi-Fi module…
I mean turn off your mobile hotspot and then try.
You can't connect to 2 networks at same time
But I disconnected from my mobile hotspot. Before trying to connect to my router
Try disabling Network Manager's "MAC Address randomization" there is a toggle for that setting in Garuda's network assistant.
Also changing the connection settings for your wifi in Network Manager can help. Allowing all users to connect can sometimes resolve this issue.
Also are you using auto-login to your desktop?
No i don’t think i use that
It didn’t work it keeps asking me to input password over and over again
Did not work
It keeps asking me to input password
Well don’t do that then.
You did not respond to my other suggestions, considering they were simply a matter of toggling on/off a check mark I’m not sure whyt attempting my suggestions was so difficult .The last several hours since you replied I might have thought sufficient to toggle a check mark or two.
Regardless here’s some more detailed instructions if your confused:
Select your wifi connection in Network Manager and apply these settings:
“All users may connect to this network”
“Automatically connect to this network when it is available”
“Store password for all users (not encrypted)”
Then, reboot both your router and computer once you’ve also done:
Please don’t expect further help until you’ve complied with the previous suggestions.
What you asked me to do didn't work, but i fixed the issue though. thanks for time. I appreciate .
Cool, you fixed it. And how?
We would appreciate if you teach us.
Will do that
By all means, educate us.
Step One 1: Search for "Advanced Network Configuration".
Step Two: Select Prefered Wifi Network and click on settingds icon below:
Step Three: Band Might might be in automatic, so select prefered band (2.4GHz || 5GHz):
then restart PC and connect again.
