Garuda gaming discovery problem?
To use Discovery for apps, install your preferred module under Missing Backends on the Settings page. How do I do it? Thanks for your help
I assume you mean Discover. As the error suggests, Garuda is a distro that doesn’t ship with it as it already has its preferred ways of getting packages:
You can install flatpak to make it work but, NOTE its not supported on garuda.
So if you have a issue with a pkg or app you must go to that apps maintainer. Personally I use flatpak for 1 app, bottles cause that’s the only one the maintainer supports when you have issues. “Thanks to fedora”
One more thing to note when there is a discover update it will only update the flatpaks. So you will still have to use garuda-update / -a
or open garuda assistant an click system update.
