Hello friends
first congratulate Garuda, it’s something incredible, thank you.
I can’t boot with Gamescope from steam…
I would like to mount an HTPC with Garuda Gamer and Gamescope in my room, it is a Beelink SER7 PRO mini pc. Full AMD.
I have followed a thread on the forum and I can’t.
Is there someone who boots the system directly with Gamescope??
I would appreciate your help if you explain how.
Yes. I currently use Bazzite on the Steamdeck and Nobara on the htpc.
I have a lot of freezes when I play and I don’t have a way to fix it. I wanted to try the garuda distro that I love so much and use on my pc and laptop. I had thought about putting the zen4 kernel and garuda gamescope in the htpc.
Thanks to you I have found a way to install it and it works.
