Kernel: 6.13.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=a54fd2cf-8abc-45f3-b2fd-7082d1f51b08 rw rootflags=subvol=@
Type: Desktop System: Gigabyte product: X870 AORUS ELITE WIFI7 v: -CF-WCP
Mobo: Gigabyte model: X870 AORUS ELITE WIFI7 v: x.x
Megatrends LLC. v: F2 date: 08/14/2024
Info: model: AMD Ryzen 9 9950X3D bits: 64 type: MT MCP arch: N/A level: v4
note: check family: 0x1A (26) model-id: 0x44 (68) stepping: 0
microcode: 0xB40401A
Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 16 threads: 32 tpc: 2
smt: enabled cache: L1: 1.2 MiB desc: d-16x48 KiB; i-16x32 KiB L2: 16 MiB
desc: 16x1024 KiB L3: 128 MiB desc: 1x32 MiB, 1x96 MiB
Speed (MHz): avg: 4399 min/max: 600/5752 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 4399 2: 4399 3: 4399
4: 4399 5: 4399 6: 4399 7: 4399 8: 4399 9: 4399 10: 4399 11: 4399 12: 4399
13: 4399 14: 4399 15: 4399 16: 4399 17: 4399 18: 4399 19: 4399 20: 4399
21: 4399 22: 4399 23: 4399 24: 4399 25: 4399 26: 4399 27: 4399 28: 4399
29: 4399 30: 4399 31: 4399 32: 4399 bogomips: 274675
Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 [RX 9070/9070 XT]
vendor: Tul / PowerColor driver: amdgpu v: kernel pcie: gen: 5
speed: 32 GT/s lanes: 16 ports: active: DP-3 empty: DP-1, DP-2, HDMI-A-1,
Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:7550 class-ID: 0300
vendor: Gigabyte driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: none empty: DP-4, DP-5, HDMI-A-2, HDMI-A-3,
Writeback-2 bus-ID: 75:00.0 chip-ID: 1002:13c0 class-ID: 0300 temp: 42.0 C
Device-3: Logitech Logi Webcam C920e driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-2.1.1.3:7 chip-ID: 046d:08b6
gpu: amdgpu display-ID: 0
Monitor-1: DP-3 model: Samsung Odyssey G95NC serial: <filter> built: 2024
res: mode: 3840x2160 hz: 120 scale: 100% (1) dpi: 70 gamma: 1.2
size: 1400x400mm (55.12x15.75") diag: 1456mm (57.3") modes: max: 3840x2160
min: 640x480
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.0-devel
gfx1201 ACO DRM 3.61 6.13.7-zen1-1-zen) device-ID: 1002:7550
API: Vulkan v: 1.4.304 layers: 11 device: 0 type: discrete-gpu name: AMD
Radeon Graphics (RADV GFX1201) driver: N/A device-ID: 1002:7550
surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu name: AMD
Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: N/A device-ID: 1002:13c0
Device-1: Advanced Micro Devices [AMD/ATI] driver: snd_hda_intel v: kernel
pcie: gen: 5 speed: 32 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab40
speed: 16 GT/s lanes: 16 bus-ID: 75:00.1 chip-ID: 1002:1640 class-ID: 0403
lanes: 16 bus-ID: 75:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.13.7-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 08:00.0
Device-2: MEDIATEK vendor: Foxconn driver: mt7925e v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 09:00.0 chip-ID: 14c3:7925
IF: wlp9s0 state: up mac: <filter>
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:3 chip-ID: 0489:e124
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: N/A
Local Storage: total: 2.29 TiB used: 506.7 GiB (21.7%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Crucial model: CT2000T705SSD3
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 126 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: PACR5111 temp: 30.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Kingston model: OM3PDP3512B-A01
lanes: 4 tech: SSD serial: <filter> fw-rev: EDFK0S03 temp: 34.9 C
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 506.7 GiB (27.2%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
used: 506.7 GiB (27.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
ID-1: swap-1 type: zram size: 60.43 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 32
System Temperatures: cpu: 49.0 C mobo: 35.0 C
GPU: device: amdgpu temp: 42.0 C device: amdgpu temp: 33.0 C mem: 56.0 C
watts: 39.00
Memory: total: 60 GiB note: est. available: 60.43 GiB used: 3.57 GiB (5.9%)
Processes: 601 Power: uptime: 0m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.15 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1921 libs: 563 tools: octopi,pamac,paru,yay
pm: rpm pkgs: 0 pm: flatpak pkgs: 0 Compilers: clang: 19.1.7 gcc: 14.2.1
Shell: garuda-inxi default: fish v: 4.0.1 running-in: konsole inxi: 3.3.37
System install date: 2025-03-12
Last full system update: 2025-03-18
