Hi. Just recently set up Garuda on a “republic of gamers” laptop with an intel core 17, and an idk a GeForce GTX 660m 2 gb. And I keep having problems with it freezing. It has mostly happened when running an internet browser (when using firedragon it takes awhile to freeze, tried Firefox and it freezes faster) it’s like a complete freeze, no ctl alt dlt, no f2, need to hard reset. I’m having trouble figuring out why it is freezing even after checking like htop and other console options
Hello. Could you follow the template and post the output of your garuda-inxi
1. The issue
I
disabled Ananicey and changed to cachys bore kernel and had previously tried xanmod, put a cpu core monitor in the task bar, which showed core 6 (of 8) max out and spiked when it froze usually the mouse and keyboard both stop completely the last time the mouse moved some for awhile before freezing completely again
3. System information
```text
Kernel: 6.7.4-1-cachyos-bore arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
avail: hpet,acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-cachyos-bore
root=UUID=8119a388-b5e5-4d32-8490-b32855e4a1e8 rw rootflags=subvol=@ quiet
resume=UUID=b85cd719-e7e3-4b8b-9946-b7c118af39bc loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 info: frameworks v: 5.115.0 wm: kwin_x11 vt: 2
Type: Laptop System: ASUSTeK product: G75VW v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: G75VW v: 1.0 serial: <superuser required> part-nu: ASUS-NotebookSKU
uuid: <superuser required> BIOS: American Megatrends v: G75VW.218 date: 08/21/2012
ID-1: BAT0 charge: 46.6 Wh (92.1%) condition: 50.6/66.0 Wh (76.7%) power: 21.2 W volts: 16.7
min: 14.8 model: ASUSTek G75--52 type: Li-ion serial: N/A status: charging
Info: model: Intel Core i7-3630QM bits: 64 type: MT MCP arch: Ivy Bridge gen: core 3 level: v2
built: 2012-15 process: Intel 22nm family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3298 high: 3400 min/max: 1200/3400 scaling: driver: intel_cpufreq
governor: performance cores: 1: 3193 2: 3400 3: 3193 4: 3400 5: 3400 6: 3193 7: 3400 8: 3209
bogomips: 38314
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: NVIDIA GK107M [GeForce GTX 660M] vendor: ASUSTeK driver: nouveau v: kernel non-free:
series: 470.xx+ status: legacy-active (EOL~2024-09-xx) arch: Kepler code: GKxxx
process: TSMC 28nm built: 2012-2018 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 ports:
active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 01:00.0 chip-ID: 10de:0fd4 class-ID: 0300
temp: 47.0 C
Device-2: Sunplus Innovation ASUS Webcam driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 2-1.3:4 chip-ID: 1bcf:2885 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4 compositor: kwin_x11 driver: X:
loaded: nouveau unloaded: modesetting alternate: fbdev,nv,vesa dri: nouveau gpu: nouveau
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
Monitor-1: LVDS-1 model: Chi Mei Opto 0x1720 built: 2011 res: 1920x1080 hz: 60 dpi: 128
gamma: 1.2 size: 382x215mm (15.04x8.46") diag: 438mm (17.3") ratio: 16:9 modes: max: 1920x1080
min: 640x350
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau device: 1 drv: swrast
gbm: drv: nouveau surfaceless: drv: nouveau x11: drv: nouveau inactive: wayland
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 23.3.5-arch1.1 glx-v: 1.4 direct-render: yes
renderer: NVE7 device-ID: 10de:0fd4 memory: 1.94 GiB unified: no
API: Vulkan v: 1.3.276 layers: 9 device: 0 type: cpu name: llvmpipe (LLVM 16.0.6 256 bits)
driver: mesa llvmpipe v: 23.3.5-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK 7
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20 class-ID: 0403
Device-2: NVIDIA GK107 HDMI Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
API: ALSA v: k6.7.4-1-cachyos-bore status: kernel-api with: aoss type: oss-emulator tools: N/A
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse status: active
Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: AzureWave driver: ath9k
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00
.0 chip-ID: 168c:0032 class-ID: 0280
Device-2: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet vendor: ASUSTeK driver: atl1c v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 04:00.0 chip-ID: 1969:1083
Device-1: IMC Networks Atheros AR3012 Bluetooth 4.0 Adapter driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.1:5 chip-ID: 13d3:3362 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.0 lmp-v: 6 status:
discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 937.11 GiB used: 17.28 GiB (1.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 PRO 256GB size: 238.47 GiB
fw-rev: 2B6Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HTS727575A9E364 size: 698.64 GiB
block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: A200 scheme: MBR
ID-1: / raw-size: 225.67 GiB size: 225.67 GiB (100.00%) used: 17.28 GiB (7.7%) fs: btrfs
dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 225.67 GiB size: 225.67 GiB (100.00%) used: 17.28 GiB (7.7%) fs: btrfs
ID-3: /var/log raw-size: 225.67 GiB size: 225.67 GiB (100.00%) used: 17.28 GiB (7.7%) fs: btrfs
ID-4: /var/tmp raw-size: 225.67 GiB size: 225.67 GiB (100.00%) used: 17.28 GiB (7.7%) fs: btrfs
ID-1: swap-1 type: zram size: 11.63 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 8 dev: /dev/zram0
ID-2: swap-2 type: partition size: 12.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda2
maj-min: 8:2
System Temperatures: cpu: 57.0 C mobo: N/A gpu: nouveau temp: 47.0 C
Fan Speeds (rpm): cpu: 2700
Memory: total: 12 GiB available: 11.63 GiB used: 3.27 GiB (28.1%)
Processes: 343 Power: uptime: 7m states: freeze,mem,disk suspend: deep avail: s2idle wakeups: 0
hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 4.64 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 255
Packages: pm: pacman pkgs: 1854 libs: 559 tools: octopi,paru Compilers: gcc: 13.2.1
Client: shell wrapper v: 5.2.26-release inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-02-10
Last full system update: 2024-02-10
we also switched from wayland to xorg
The first thing I’d try here is to switch to the proprietary drivers (you see the nouveau drivers are loaded, but the 470.xx nvidia drivers should work).
Try with Garuda settings manager → HW configuration → autoinstall proprietary drivers.
Apart from that, what looks strange to me is that the iGPU is missing in the specs. Did you disable it in the BIOS?
In my opinion you should enable and use it for the normal work, then use the dGPU when needed with prime-run. See the wiki.
So when I went to the HW configuration page, it had a button for autoinstalling opensource drivers, but not a button for autoinstalling proprietary drivers? is there some other way I can get the nvidia drivers actually installed and running?
<System:
Kernel: 6.6.16-x64v-xanmod1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-xanmod
quiet resume=UUID=b85cd719-e7e3-4b8b-9946-b7c118af39bc loglevel=3 ibt=off
serial:
part-nu: ASUS-NotebookSKU uuid:
ID-1: BAT0 charge: 50.6 Wh (100.0%) condition: 50.6/66.0 Wh (76.7%)
volts: 16.6 min: 14.8 model: ASUSTek G75–52 type: Li-ion serial: N/A
status: full
Speed (MHz): avg: 2957 high: 3400 min/max: 1200/3400 scaling:
driver: intel_cpufreq governor: performance cores: 1: 2708 2: 3400 3: 3195
4: 2599 5: 3250 6: 3193 7: 2000 8: 3313 bogomips: 38315
v: kernel alternate: nvidiafb non-free: series: 470.xx+
ports: active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 01:00.0
chip-ID: 10de:0fd4 class-ID: 0300 temp: 49.0 C
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.3:4
compositor: kwin_x11 driver: X: loaded: nouveau unloaded: modesetting
alternate: fbdev,nv,vesa dri: nouveau gpu: nouveau display-ID: :0
hz: 60 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46") diag: 438mm (17.3")
ratio: 16:9 modes: max: 1920x1080 min: 640x350
device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau x11:
direct-render: yes renderer: NVE7 device-ID: 10de:0fd4 memory: 1.94 GiB
unified: no
API: Vulkan v: 1.3.276 layers: 14 device: 0 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.5-arch1.1 (LLVM
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 bus-ID: 01:00.1
API: ALSA v: k6.6.16-x64v-xanmod1-1 status: kernel-api with: aoss
driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 168c:0032 class-ID: 0280
IF: wlp3s0 state: up mac:
driver: atl1c v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 04:00.0 chip-ID: 1969:1083 class-ID: 0200
IF: enp4s0 state: down mac:
v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.1:3
chip-ID: 13d3:3362 class-ID: e001 serial:
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: bt-v: 4.0
lmp-v: 6 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 937.11 GiB used: 57.21 GiB (6.1%)
tech: SSD serial: fw-rev: 2B6Q scheme: MBR
size: 698.64 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: fw-rev: A200 scheme: MBR
used: 57.21 GiB (25.4%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
zswap: no
ID-1: swap-1 type: zram size: 15.58 GiB used: 0 KiB (0.0%) priority: 100
priority: -2 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 51.0 C mobo: N/A gpu: nouveau temp: 49.0 C
Fan Speeds (rpm): cpu: 2100
Memory: total: 16 GiB available: 15.58 GiB used: 2.34 GiB (15.0%)
Processes: 335 Power: uptime: 27m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.22 GiB services: org_kde_powerdevil,upowerd
Packages: pm: pacman pkgs: 1856 libs: 559 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.0 running-in: konsole
inxi: 3.3.33
Garuda (2.6.23-1):
Last full system update: 2024-02-11 ↻
Windows dual boot:
Failed units:>
this is what the inxi shows now btw
Hey, thanks for the help everybody. It turned out our ram chip was not installed properly so this problem is now fixed
