There is any way to disable fish from terminal ?
I'm having trouble with nvm and i like to use bash with zsh . There is any way ?
You can change shell in Garuda Assistant.
If using Alacritty, also edit .config/alacritty/alacritty.yml to use zsh.
To switch to bash
chsh -s /bin/bash
Off course I know that it exists in Garuda Assistant.
But terminal is best in case you are trying things out because you can see logs.
NVM does not support Fish but there is a way to fix that. Luckily I found this article, check it out.
And, just use fisher install edc/bass
instead of fisher add edc/bass
as there is no add
command in latest version of fisher.
