Hello.
Somebody knows about what drivers should install with a 2080 rtx graphic card on garuda linux? i maked some research and I try it by myself, but whenever I try to install some drivers, it does not even start the operating system.
I tried to install the nvidia drivers from the garuda settings manager > hardware configuration, but dosnt worked at all. Also i tried to download the nvidia drivers for linux from the official page but dosnt work to...
Sorry for my english and
This is the result from the "inxi -Faz":
Kernel: 5.10.87-1-lts x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/.snapshots/41/snapshot/boot/vmlinuz-linux-lts
root=UUID=82278974-75ec-4f28-986b-3283659c1888 quiet splash
rootflags=defaults,noatime,autodefrag,compress=zstd,subvol=@/.snapshots/41/snapshot
Type: Desktop System: Micro-Star product: MS-7B10 v: 1.0
Mobo: Micro-Star model: MEG Z390 GODLIKE (MS-7B10) v: 1.0
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: 1.00
date: 09/11/2018
Info: model: Intel Core i7-8086K bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEA
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 814 high: 973 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 973 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
bogomips: 95999
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: NVIDIA TU104 [GeForce RTX 2080 Rev. A] vendor: Micro-Star MSI
driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:1e87 class-ID: 0300
Device-2: Logitech C922 Pro Stream Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-4:3 chip-ID: 046d:085c
loaded: modesetting,nouveau alternate: fbdev,nv,vesa display-ID: :0
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
s-diag: 777mm (30.6")
Monitor-1: DP-1 res: 2560x1440 dpi: 109 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
Device-2: NVIDIA TU104 HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f8
Device-3: YUAN High-Tech Development driver: N/A bus-ID: 05:00.0
chip-ID: 12ab:0371 class-ID: 0480
Device-4: YUAN High-Tech Development driver: N/A bus-ID: 06:00.0
Device-5: YUAN High-Tech Development driver: N/A bus-ID: 07:00.0
Device-6: YUAN High-Tech Development driver: N/A bus-ID: 08:00.0
Device-7: Logitech C922 Pro Stream Webcam type: USB
Sound Server-1: ALSA v: k5.10.87-1-lts running: yes
Device-1: Qualcomm Atheros Killer E2500 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel port: 4000 bus-ID: 0a:00.0
chip-ID: 1969:e0b1 class-ID: 0200
IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel port: 3000 bus-ID: 0b:00.0
IF: enp11s0 state: down mac: <filter>
Device-3: Intel Wireless-AC 9260 vendor: Rivet Networks driver: iwlwifi
v: kernel bus-ID: 0c:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlp12s0 state: down mac: <filter>
v: 0.8 bus-ID: 1-10:7 chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 931.52 GiB used: 82.49 GiB (8.9%)
model: SSD 970 EVO 500GB size: 465.76 GiB block-size: physical: 512 B
rev: 2B2QEXE7 temp: 31.9 C scheme: MBR
model: WD5000AAKX-22ERMA0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: N/A serial: <filter> rev: 1H17
ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 82.49 GiB (17.7%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-3: /var/log raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-4: /var/tmp raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.29 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 27.8 C pch: 47.0 C mobo: N/A gpu: nouveau
temp: 37.0 C
Fan Speeds (RPM): fan-2: 1494 fan-3: 1494 fan-4: 1488 fan-5: 1501
fan-6: 1503 gpu: nouveau fan: 0
Processes: 336 Uptime: 28m wakeups: 1 Memory: 31.3 GiB
used: 4.45 GiB (14.2%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 2011 lib: 438 Shell: fish
v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
