Hi, I have been using the dragonized edition for quite some time (close to a year), it used to be super responsive right from logging in until a few months back. When I log in now, it takes close to 10 to 15 seconds to get to the Desktop (a spinning dragon will be shown until the DE loads). Even after I get the Desktop screen it takes 5 to 8 secs to load the dock etc. Any idea why I am facing such an issue or is it just the KDE startup time? Here is my garuda-inxi
Kernel: 5.18.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=c86ec1a0-7254-48c4-9823-df77cca3f8a9 rw [email protected]
systemd.unified_cgroup_hierarchy=1 loglevel=3 ibt=off
Type: Laptop System: Acer product: Nitro AN515-52 v: V1.19 serial: <filter>
Mobo: CFL model: Freed_CFS v: V1.19 serial: <filter> UEFI: Insyde v: 1.19
date: 07/13/2018
ID-1: BAT1 charge: 32.3 Wh (100.0%) condition: 32.3/48.9 Wh (66.0%)
volts: 16.6 min: 15.2 model: LG PABAS0241231 type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i7-8750H socket: U3E1 bits: 64 type: MT MCP
arch: Coffee Lake gen: core 8 built: 2018 process: Intel 14nm family: 6
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 4091 high: 4102 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave volts: 1.2 V ext-clock: 100 MHz
cores: 1: 4101 2: 4102 3: 4101 4: 4083 5: 4100 6: 4100 7: 4099 8: 4101
9: 4100 10: 4029 11: 4085 12: 4098 bogomips: 52799
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630]
vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen9.5
process: Intel 14nm built: 2016-20 ports: active: eDP-1 empty: none
bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 515.57
alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Pascal process: TSMC 16nm
built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: none empty: HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:1c8c class-ID: 0300
Device-3: Quanta HD Webcam type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 0408:a060 class-ID: 0e02 serial: <filter>
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia gpu: i915
Monitor-1: eDP-1 model: AU Optronics 0x61ed built: 2016 res: 1920x1080
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: N/A v: N/A direct render: N/A
Device-1: Intel Cannon Lake PCH cAVS vendor: Acer Incorporated ALI
Device-2: NVIDIA GP107GL High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie:
speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s bus-ID: 01:00.1
chip-ID: 10de:0fb9 class-ID: 0403
Sound Server-1: ALSA v: k5.18.12-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.55 running: yes
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 06:00.1 chip-ID: 10ec:8168
IF: enp6s0f1 state: down mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0aaa class-ID: e001
address: <filter>
Local Storage: total: 1.03 TiB used: 99.48 GiB (9.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: SK Hynix model: HFS128G39TND-N210A
family: SATA SSDs size: 119.24 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 1P10 temp: 39 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 252d 3h cycles: 5428
Pre-Fail: retired block: 100 threshold: 36
ID-2: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi)
model: HTS721010A9E630 family: Travelstar 7K1000 size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: A3J0 temp: 37 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 280d 15h cycles: 5378
ID-1: / raw-size: 149.91 GiB size: 149.91 GiB (100.00%)
used: 99.45 GiB (66.3%) fs: btrfs block-size: 4096 B dev: /dev/sdb3
maj-min: 8:19
used: 31.8 MiB (33.2%) fs: vfat block-size: 512 B dev: /dev/sda2
maj-min: 8:2
ID-3: /home raw-size: 149.91 GiB size: 149.91 GiB (100.00%)
maj-min: 8:19
ID-4: /var/log raw-size: 149.91 GiB size: 149.91 GiB (100.00%)
maj-min: 8:19
ID-5: /var/tmp raw-size: 149.91 GiB size: 149.91 GiB (100.00%)
maj-min: 8:19
ID-1: swap-1 type: zram size: 15.47 GiB used: 2 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 976 MiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb4 maj-min: 8:20
System Temperatures: cpu: 52.0 C pch: 56.0 C mobo: N/A
Processes: 323 Uptime: 45m wakeups: 1 Memory: 15.47 GiB
used: 3.53 GiB (22.8%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.1 alt: 11 clang: 14.0.6 Packages: 1597
pacman: 1590 lib: 356 snap: 7 Shell: garuda-inxi (sudo) default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.19
Garuda (2.6.5-1):
System install date: 2022-05-16
Last full system update: 2022-07-18 ↻
Windows dual boot: Yes
