Garuda dotfiles with existing home partition
Hi all,
I just installed Garuda sway on my machine. Before I was using EndeavourOS with XFCE/i3. I do have a standalone home partition, which is mounted to /home which works for the most part.
Now what I noticed immediately, the dotfiles of the live environment were not getting copied over after the install. For now, I just grabbed (at least sway, swaylock, waybar) off the live environment and copied them over. But I guess thats not the way things should work here? Never had to do that in the past before
Any suggestions on this? Is this a thing only with the sway edition? Not sure about keeping that though, as I am running this on a Intel iGPU/Nvidia Optimus laptop.
What’s the problem with not posting garuda-inxi?
It contains additional, useful information about the status of your system.
:warning: Missing information requested in the template may result in not receiving assistance
Issue still unresolved? Then:
  • ONE issue per topic.
Without garuda-inxi this request will be moved to 412 Precondition Failed
I move it to Sway
Youre absolutely right, sorry. Dont know how I missed that.
❯ garuda-inxi
    root=UUID=6e33c085-1b23-49d2-a02e-298ac6148f40 rw rootflags=subvol=@
  Desktop: sway v: 1.8.1 info: waybar vt: 1 dm: greetd Distro: Garuda Linux
  Type: Laptop System: Dell product: Precision 5560 v: N/A
  Mobo: Dell model: 0G06MM v: A00 serial: <superuser required> UEFI: Dell
    v: 1.24.0 date: 09/12/2023
  ID-1: BAT0 charge: 57.3 Wh (97.8%) condition: 58.6/84.3 Wh (69.5%)
    volts: 12.7 min: 11.4 model: BYD DELL M59JH19 type: Li-poly serial: <filter>
    status: charging
  Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
    microcode: 0x46
    L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 1655 high: 3861 min/max: 800/4600 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1799 2: 1120 3: 2871
    4: 800 5: 3861 6: 1007 7: 1452 8: 975 9: 1114 10: 800 11: 3072 12: 2376
    13: 2838 14: 800 15: 800 16: 800 bogomips: 73728
  Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Dell driver: i915
    v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
    active: DP-5,DP-6,eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0
    chip-ID: 8086:9a60 class-ID: 0300
  Device-2: NVIDIA GA107GLM [RTX A2000 Mobile] vendor: Dell driver: nouveau
    v: kernel non-free: 545.xx+ status: current (as of 2023-10; EOL~2026-12-xx)
    gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:25b8 class-ID: 0302
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-11:3
    chip-ID: 0c45:672e class-ID: 0e02
  Device-4: Logitech Logi Webcam C920e driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4.3.2.3.4:23 chip-ID: 046d:08b6
  Display: wayland server: Xwayland v: 23.2.4 compositor: sway v: 1.8.1
    driver: X: loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
    dri: iris gpu: i915 d-rect: 7920x1440 display-ID: 1
  Monitor-1: DP-5 pos: center model: Mi Monitor built: 2020 res: 3440x1440
    hz: 50 dpi: 110 gamma: 1.2 scale: 1 size: 797x334mm (31.38x13.15")
    diag: 864mm (34") modes: max: 3440x1440 min: 720x400
  Monitor-2: DP-6 pos: right model: Lenovo LEN P24q-20 serial: <filter>
    built: 2022 res: 2560x1440 hz: 60 dpi: 123 gamma: 1.2 scale: 1
    max: 2560x1440 min: 720x400
  Monitor-3: eDP-1 pos: primary,left model: LG Display 0x06b3 built: 2021
    res: 1920x1200 hz: 60 dpi: 145 gamma: 1.2 scale: 1
    size: 336x210mm (13.23x8.27") diag: 396mm (15.6") ratio: 16:10
    modes: 1920x1200
  API: Vulkan v: 1.3.276 layers: 7 device: 0 type: integrated-gpu name: Intel
    UHD Graphics (TGL GT1) driver: mesa intel v: 23.3.4-arch1.2
    device-ID: 8086:9a60 surfaces: xcb,xlib,wayland device: 1 type: cpu
    v: 23.3.4-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000
  Device-1: Intel Tiger Lake-H HD Audio vendor: Dell driver: snd_hda_intel
    chip-ID: 8086:43c8 class-ID: 0403
  Device-2: HP HyperX SoloCast driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4.3.2.3.1:20
    chip-ID: 03f0:078b class-ID: 0300
  Device-3: Realtek USB Audio driver: snd-usb-audio type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4.3.4:11 chip-ID: 0bda:402e
  Server-2: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
  IF: wlp0s20f3 state: down mac: <filter>
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-4.4:7
  IF: enp0s13f0u4u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-14:4 chip-ID: 8087:0026
  Local Storage: total: 3.96 TiB used: 520.64 GiB (12.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Lexar model: SSD NM790 4TB
    size: 3.73 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 12237 temp: 43.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 model: PCIe SSD size: 238.47 GiB
    tech: SSD serial: <filter> fw-rev: ECFM22.6 temp: 26.9 C scheme: GPT
  ID-1: / raw-size: 500 GiB size: 500 GiB (100.00%) used: 9.08 GiB (1.8%)
    fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:6
    used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:9
  ID-3: /home raw-size: 3.21 TiB size: 3.21 TiB (100.00%)
    used: 511.56 GiB (15.6%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:8
  ID-4: /var/log raw-size: 500 GiB size: 500 GiB (100.00%)
    used: 9.08 GiB (1.8%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:6
  ID-5: /var/tmp raw-size: 500 GiB size: 500 GiB (100.00%)
  ID-1: swap-1 type: partition size: 32.23 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:7
  ID-2: swap-2 type: zram size: 31.08 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 89.0 C mobo: 47.0 C sodimm: SODIMM C
  Fan Speeds (rpm): cpu: 2912
  Processes: 415 Uptime: 22m wakeups: 0 Memory: total: 32 GiB note: est.
  available: 31.08 GiB used: 6.75 GiB (21.7%) Init: systemd v: 255
  pm: pacman pkgs: 1204 libs: 369 tools: paru Shell: fish v: 3.7.0
  running-in: alacritty inxi: 3.3.31
Garuda (2.6.22-1):
  System install date:     2024-01-30
  Last full system update: 2024-01-30 ↻
This topic has been discussed several times in the forum.
I’d like to mention this one: the solution is OK, but especially good to explain “the context”. Also the suggestion two posts after to use symlinking is a very very common approach to this “issue”.
and reboot
local/linux-zen 6.7.2.zen1-1
That does make a lot of sense with the background, thanks. Of course I searched for issues with the dotfiles, not with the home partition.
So in my current state, the /home partition is formatted in BTRFS, but not as a subvolume. Is there a best practice how to handle that? I could go and convert it to a subvolume (thats something I also found in my search), but the symlinks also make sense.
Im asking out of the perspective of very possible distro-hopping, as I would want to avoid as much issues there as possible. In sense of BTRFS, I guess coverting it to a subvolume would be the way to go?
Personally, I would prefer to go ahead with symlinks, so your home remains there and you continue to use it even if you have new “hops”. Which hopefully you won’t do :wink:
Great, than my thought was not that bad :smiley: Well currently Im settling in, but I really like some of the Garuda approaches, as a bit of a “quality of life” improvement over the more stock arch EndeavourOS.
But, there still is the issue with my device having that Nvidia GPU and the struggle to set that up in combiantion with wayland. So maybe I get back to i3, but definitely will try Garuda for now :slight_smile:
Edit: I just looked through my current BTRFS volumes, and I think as I mounted the /home partition right in the installation, there was no @home created on / or am I missing something?
❯ sudo btrfs subvolume list /
[sudo] password for daniel:
ID 256 gen 170 top level 5 path @
ID 257 gen 164 top level 5 path @root
ID 258 gen 45 top level 5 path @srv
ID 259 gen 138 top level 5 path @cache
ID 260 gen 169 top level 5 path @log
ID 261 gen 170 top level 5 path @tmp
ID 262 gen 113 top level 256 path .snapshots
ID 263 gen 99 top level 262 path .snapshots/1/snapshot
ID 264 gen 104 top level 262 path .snapshots/2/snapshot
ID 265 gen 110 top level 262 path .snapshots/3/snapshot
ID 266 gen 112 top level 262 path .snapshots/4/snapshot
~ took 2s
You first need to reboot before anything is going to work correctly. That’s what the stylized ‘swoosh’ at the end of the garuda-inxi means.
Done already, before the output of the btrfs subvolumes
I agree with Filo, I think this is going to be the best/easiest option for getting set up but still making it easy to hop to another distro if you want to. If you are not to deep in already I would reinstall first.
  • Reinstall, leaving the extra disk with the “mobile” /home out of it altogether. Don’t even touch that disk in the installer, just pretend it isn’t there.
  • After the installation is complete, make a mount point for the extra disk. It doesn’t matter where you mount it. Add it to /etc/fstab so it will be automatically mounted at boot.
  • Delete the (empty!) directories in the new installation that you have on the extra disk. For example:
rmdir ~/Documents ~/Pictures ~/Videos
  • Set up symlinks to point to your extra disk wherever you mounted it, so the directories there appear to be in your normal home directory. Make the directory target ~, for example:
ln -s /mnt/my_other_drive/Documents /mnt/my_other_drive/Pictures /mnt/my_other_drive/Videos ~
This way your separate drive won’t be cluttered with dotfiles and such from the Garuda installation (in case you want to hop), but you can still get to all your stuff and interact with normally while using Garuda Linux.
That sounds like the way to go, thanks a lot. The /home is on the same drive, but not mounting it in the installer should do the trick.
Yeah I also planned for re-install as I did not really configure anything anyway until now. I guess I switch to hyprland also at the same time, as my research so far regarding sway and NVIDIA drivers looks everything but good.
Getting proprietary Nvidia drivers working on Sway is more complicated than with any other spin. I have a wiki doc for how to do it drafted, but the doc refers to changes made to the Sway spin that aren’t in the ISO yet due to an ongoing issue with the Calamares installer (since December now).
So a new Sway ISO and a wiki doc for Nvidia drivers are both Coming SoonTM. :wink:
Hyprland is quite new but looks already great.
Make sure to check this thread:
I’m not a Nvidia user, so I skipped the relevant hints.
