Garuda Disabled Wallpaper error and high CPU after Booted
Hello, I use Garuda Dragonized Gaming edition. I use Garuda for few weeks now and before few days I booted it and I have from that time black wallpaper but I cant right click on it. I really don't know what happened. Also, when I boot Garuda from that time I have to wait about minute because my CPU goes on 100% and nothing responds.
I wanted to send here image but "new users cant send images".
What could cause it? Any help please?
Also if you want more information, I have dual booted Garuda with Windows but each OS I have in different partition.
For more info ask.
When you create a new post, a message appears with the information that you need to post in order to get assistance, please go back and re-read that message and provide the requested output.
Okay sorry.
System:    Kernel: 5.13.13-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=fb8b5840-cd3d-4ca3-9430-907e12068676
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine:   Type: Laptop System: LENOVO product: 81SX v: Legion Y540-15IRH serial: <filter> Chassis:
type: 10 v: Legion Y540-15IRH serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40700 WIN serial: <filter> UEFI: LENOVO v: BHCN41WW
date: 11/30/2020
Battery:   ID-1: BAT0 charge: 18.9 Wh (38.0%) condition: 49.7/57.0 Wh (87.2%) volts: 12.0 min: 11.5
model: SMP L17M3PG2 type: Li-poly serial: <filter> status: Charging cycles: 498
CPU:       Info: Quad Core model: Intel Core i5-9300H bits: 64 type: MT MCP arch: Kaby Lake note: check
family: 6 model-id: 9E (158) stepping: A (10) microcode: EA cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 38400
Speed: 4000 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 4000 2: 4003 3: 4000 4: 4001
5: 4000 6: 4000 7: 4000 8: 4000
Graphics:  Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Lenovo driver: nvidia v: 470.63.01
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:2191 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-6:5 chip-ID: 04f2:b6d9
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: nvidia display-ID: :0
Screen-1: 0 s-res: 3840x1080 s-dpi: 143 s-size: 682x191mm (26.9x7.5") s-diag: 708mm (27.9")
Monitor-1: HDMI-0 res: 1920x1080 dpi: 102 size: 480x270mm (18.9x10.6") diag: 551mm (21.7")
Monitor-2: DP-2 res: 1920x1080 hz: 144 dpi: 142 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01
direct render: Yes
Audio:     Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA TU116 High Definition Audio vendor: Lenovo driver: snd_hda_intel v: kernel
Sound Server-1: ALSA v: k5.13.13-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
Network:   Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a370 class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169
v: kernel port: 3000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8
bus-ID: 1-14:7 chip-ID: 8087:0aaa class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 2 state: down bt-service: enabled,running rfk-block:
Drives:    Local Storage: total: 1.05 TiB used: 422.29 GiB (39.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: MTFDHBA1T0TCK size: 953.87 GiB
rev: 005 P1LN temp: 51.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Samsung model: Flash Drive size: 119.51 GiB
block-size: physical: 512 B logical: 512 B type: SSD serial: <filter> rev: 1100 scheme: MBR
Partition: ID-1: / raw-size: 652.14 GiB size: 652.14 GiB (100.00%) used: 422.26 GiB (64.7%) fs: btrfs
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 31.9 MiB (12.5%) fs: vfat
ID-3: /home raw-size: 652.14 GiB size: 652.14 GiB (100.00%) used: 422.26 GiB (64.7%) fs: btrfs
ID-4: /var/log raw-size: 652.14 GiB size: 652.14 GiB (100.00%) used: 422.26 GiB (64.7%)
ID-5: /var/tmp raw-size: 652.14 GiB size: 652.14 GiB (100.00%) used: 422.26 GiB (64.7%)
ID-1: swap-1 type: zram size: 15.55 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors:   System Temperatures: cpu: 70.0 C mobo: N/A gpu: nvidia temp: 52 C
Info:      Processes: 297 Uptime: 4m wakeups: 1 Memory: 15.55 GiB used: 3.57 GiB (22.9%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1654 lib: 492
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
Press the keys ALT-D,ALT-S to bring up the Desktop Settings. From there you should be able to set a wallpaper. In the same window, go to "Mouse Actions"->"Right Button" and select "Standard Menu"
The issue with 100% my be baloo. Check for it next time you see high CPU usage.
If it is that, there are various strategies to tame it but I don't recommend removing it as it is increasingly needed by other applications to provide full functionality.
Thx, but when I press ALT-D or ALT-S nothing happens and high CPU usage I have every time I boot my pc and after waiting few minutes it finally responds and its better but still I just have opened browser and CPU is going hot. Before week it didn't do that.
But only my admin account has this error, now I notice.
Idk like what to do?
Use user account :slight_smile:
But in user account I have to again install all games that I have in admin. That is hundreds of GB. I mean in Steam, Heroic... Also, I have other problems there.
It is not a
“Garuda Disabled Wallpaper error and high CPU after Booted”
error, you learned the hard way.
Why you play games as root?
What will we see on black backgrounds? :smiley:
Or on one sentence error messages?
Nothing, so new users can’t post pictures like in telegram or reddit to reduce forum storage space. Sorry about that :slight_smile:
I thought that only when I start them with sudo they have root privileges :smile: okay then I will again install them to new account. Also, what to do when I want to install something and I am not root? Because when I tried it, it wanted pass for new user and after I wrote it, it wrote to me that "new user" isn't root
Do you mean that you are logging into your DE as root?
If your games require root to run something is wrong that you fix. Never run an application as root that doesn't require it. If a game requires root to run, something is broken.
No they doest, I just thought that I am not giving them root. To be clear I use Linux for month :slight_smile:
The problem you are going to find is that once you run something as root, your permissions will be a mess. You probably should reset the permissions of your home directory and if the games are stored outside your home directory, restore those permissions as well.
Thanks for support, you are awesome.
