For some reason, whenever I try to update my system via the setup assistant, after starting the full system upgrade, it attempts to replace
mhwd-db-garuda-git with garuda/mhwd-db-garuda
and
sweet-kde-theme-git with chaotic-aur/plasma5-themes-sweet-kde-git
which then leads to the error
after trying to resolve the dependencies
wondering how to resolve this so I may update my system
here’s my inxi:
root=UUID=269cc547-aec6-4152-940c-e1b85652e8b5 rw rootflags=subvol=@
Desktop: Cinnamon v: 5.8.4 tk: GTK v: 3.24.38 wm: muffin vt: 7
dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: LENOVO product: 20AMS2LK0V v: ThinkPad X240
serial: <superuser required> Chassis: type: 10
Mobo: LENOVO model: 20AMS2LK0V serial: <superuser required>
UEFI: LENOVO v: GIET76WW (2.26 ) date: 08/27/2014
ID-1: BAT1 charge: 60.0 Wh (84.6%) condition: 70.9/71.3 Wh (99.5%)
power: 6.2 W volts: 11.8 min: 10.8 model: SANYO 45N1777 type: Li-ion
Info: model: Intel Core i5-4300U bits: 64 type: MT MCP arch: Haswell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 840 high: 960 min/max: 800/2900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 800 2: 800 3: 800
4: 960 bogomips: 19955
Device-1: Intel Haswell-ULT Integrated Graphics
vendor: Lenovo ThinkPad X240 driver: i915 v: kernel arch: Gen-7.5
process: Intel 22nm built: 2013 ports: active: eDP-1 empty: DP-1,
DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:0a16
Device-2: Lite-On [] driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-8:4 chip-ID: 04ca:7035
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.9 driver: X: loaded: modesetting
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: AU Optronics 0x106c built: 2012 res: 1366x768
hz: 60 dpi: 126 gamma: 1.2 size: 276x155mm (10.87x6.1")
diag: 317mm (12.5") ratio: 16:9 modes: 1366x768
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu
name: Intel HD Graphics 4400 (HSW GT2) driver: mesa intel
v: 23.2.1-arch1.2 device-ID: 8086:0a16 surfaces: xcb,xlib device: 1
type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
surfaces: xcb,xlib
Device-1: Intel Haswell-ULT HD Audio vendor: Lenovo ThinkPad X240
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c
Device-2: Intel 8 Series HD Audio vendor: Lenovo ThinkPad X240
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20
status: active 2: wireplumber status: active 3: pipewire-alsa
type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Intel Ethernet I218-LM vendor: Lenovo ThinkPad X240
driver: e1000e v: kernel port: 3080 bus-ID: 00:19.0 chip-ID: 8086:155a
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:08b2
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-7:3
chip-ID: 8087:07dc class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter>
bt-v: 4.0 lmp-v: 6 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 119.24 GiB used: 3.66 GiB (3.1%)
SMART Message: Required tool smartctl not installed. Check
--recommends
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZ7LN128HAHQ-000L1
size: 119.24 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 4L0Q scheme: GPT
ID-1: / raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
used: 3.66 GiB (3.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-4: /var/log raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-5: /var/tmp raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
zswap: no
ID-1: swap-1 type: zram size: 7.64 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 45.0 C mobo: N/A
Fan Speeds (rpm): fan-1: 3085
Processes: 219 Uptime: 32m wakeups: 1 Memory: total: 8 GiB
available: 7.64 GiB used: 2.34 GiB (30.6%) Init: systemd v: 254
pm: pacman pkgs: 1195 libs: 364 tools: paru Shell: fish v: 3.6.1
running-in: gnome-terminal inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-12-10
Last full system update: 2023-12-10
