I have a 14 TB hard drive that I wanted to save all data but moved to a BTRFS partition, I formatted it all to NTFS despite knowing I’d do a full move to linux in the future, but enough about that. Earlier I decided instead of deleting all partitions off the drive and formatting it I decided I should shrink the partition, then turn the empty partition to btrfs, then move all data to the new partition then grow the btrfs to the whole drive. Well, after it finished shrinking I can no longer mount the drive, the partitioning program failed to create the empty space to brtfs as I set in the program, and I can no longer mount the ntfs drive in garuda like I used to. The ntfs partition is still usable in the Windows 10 OS I still have on the 3rd drive I have on this PC.
Now that you know my dilema I’m looking for a way to get my old data to the btrfs partition.
╰─λ garuda-inxi
Kernel: 6.7.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=7b56fc96-0e19-473d-badd-73a065550c34 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.1 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Desktop Mobo: Micro-Star model: MPG B550 GAMING EDGE WIFI (MS-7C91)
v: 1.0 serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: 1.80 date: 12/15/2021
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3710 high: 4005 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3601 2: 3700
3: 3609 4: 3600 5: 3713 6: 3973 7: 3653 8: 3600 9: 3700 10: 4005 11: 3700
12: 3667 bogomips: 88801
vendor: Tul / PowerColor Red Devil driver: amdgpu v: kernel arch: RDNA-2
speed: 16 GT/s lanes: 16 ports: active: DP-2,HDMI-A-1 empty: DP-1,DP-3
bus-ID: 2d:00.0 chip-ID: 1002:73df class-ID: 0300
gpu: amdgpu d-rect: 4480x2520 display-ID: 0
Monitor-1: DP-2 pos: top-right res: 2560x1440 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: bottom-l res: 1920x1080 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.2-arch1.2
navi22 LLVM 17.0.6 DRM 3.57 6.7.9-zen1-1-zen) device-ID: 1002:73df
API: Vulkan v: 1.3.279 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 24.0.2-arch1.2
device-ID: 1002:73df surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.2-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2d:00.1 chip-ID: 1002:ab28
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.7.9-zen1-1-zen status: kernel-api with: aoss
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 29:00.0
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 2a:00.0
IF: enp42s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:6 chip-ID: 8087:0032
Local Storage: total: 14.81 TiB used: 715.21 GiB (4.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-256G-1006 size: 238.47 GiB block-size: physical: 512 B
fw-rev: HPS2 temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST14000NM001G-2KJ103
size: 12.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: SN02 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 2TB
ID-4: /dev/sdc maj-min: 8:32 vendor: SanDisk model: Ultra size: 28.64 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: 1.00
scheme: MBR
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 715.21 GiB (38.4%)
fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 584 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
used: 715.21 GiB (38.4%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-1: swap-1 type: zram size: 15.54 GiB used: 251.2 MiB (1.6%)
System Temperatures: cpu: 59.4 C mobo: N/A gpu: amdgpu temp: 56.0 C
mem: 54.0 C
Memory: total: 16 GiB available: 15.54 GiB used: 5.23 GiB (33.6%)
Processes: 378 Power: uptime: 1h 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.21 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1970 libs: 558 tools: octopi,paru,yay
Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: fish
v: 3.7.0 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2023-12-16
Last full system update: 2024-03-12
