What happens
On boot, I am prompted to decrypt my LUKS partition with my passphrase. The layout keyboard is in qwerty, while I use azerty.
When I type in my passphrase and fails (because it is in qwerty), I’m prompted with:
error: access denied.
error disk 'cryptouuid/whateverbigid' not found.
Entering rescue mode...
grub rescue >
I’m not sure how relevant this is. It may belong to an other issue but I wanted to provide as much information as I can.
What I tried
I’ve checked vconsole.conf. It is fine:
FONT=ter-220n
KEYMAP=fr
I’ve seen things about mkinitcpio but I’m not concerned as I have Dracut.
I added /etc/vconsole.conf in in install_items+= in /etc/dracut.conf.d/calamares-luks.conf then rebooted but it didn’t fix the issue.
garuda-inxi content
Kernel: 6.1.69-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=92c43eb7-b450-427a-bdef-7908b67325bf rw rootflags=subvol=@
quiet rd.luks.uuid=f0c06df4-c37c-4b4b-be44-1a0989006f94
rd.luks.uuid=d47b0d44-e52a-4d69-a1b0-fb89fe282926
resume=/dev/mapper/luks-d47b0d44-e52a-4d69-a1b0-fb89fe282926 loglevel=3
Type: Laptop System: LENOVO product: 20HRCTO1WW v: ThinkPad X1 Carbon 5th
Mobo: LENOVO model: 20HRCTO1WW v: SDK0J40709 WIN
serial: <superuser required> UEFI: LENOVO v: N1MET37W (1.22 )
date: 07/04/2017
ID-1: BAT0 charge: 46.6 Wh (97.9%) condition: 47.6/57.0 Wh (83.4%)
volts: 12.8 min: 11.6 model: LGC 01AV494 type: Li-poly serial: <filter>
status: not charging cycles: 354
Info: model: Intel Core i7-7600U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check gen: core 7 level: v3 note: check built: 2017
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
microcode: 0xF4
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 500 high: 600 min/max: 400/3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 600 4: 600
bogomips: 23209
Device-1: Intel HD Graphics 620 vendor: Lenovo ThinkPad X1 Carbon 5th Gen
ports: active: HDMI-A-1,eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0
Device-2: Chicony Integrated IR Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 04f2:b5cf
class-ID: 0e02
Device-3: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:5 chip-ID: 04f2:b5ce
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.10 compositor: xfwm v: 4.18.0 driver:
X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
s-diag: 1055mm (41.55")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: right model: Philips PHL 247E6
serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9 modes:
Monitor-2: eDP-1 pos: primary,left model: BOE Display 0x06df built: 2016
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: 1920x1080
API: Vulkan v: 1.3.274 layers: 5 device: 0 type: integrated-gpu name: Intel
HD Graphics 620 (KBL GT2) driver: mesa intel v: 23.3.2-arch1.2
device-ID: 8086:5916 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.2-arch1.2 (LLVM
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo ThinkPad X1 Carbon
5th Gen driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_soc_avs
Device-2: Logitech G735 Gaming Headset
lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 046d:0ad8 class-ID: 0102
Device-3: DisplayLink ThinkPad Hybrid USB-C with USB-A Dock
driver: snd-usb-audio type: USB rev: 3.2 speed: 5 Gb/s lanes: 1
mode: 3.2 gen-1x1 bus-ID: 4-1.2:3 chip-ID: 17e9:6015 class-ID: 0102
API: ALSA v: k6.1.69-1-lts status: kernel-api tools: N/A
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:24fd
Device-3: Lenovo ThinkPad Lan driver: cdc_ether type: USB rev: 3.0
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1.3:4 chip-ID: 17ef:a359
IF: enp60s0u1u3c2 state: down mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:4 chip-ID: 8087:0a2b
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.2
Local Storage: total: 953.87 GiB used: 32.83 GiB (3.4%)
model: MZVLW1T0HMLH-000L7 size: 953.87 GiB block-size: physical: 512 B
fw-rev: 6L7QCXY7 temp: 36.9 C scheme: GPT
ID-1: / raw-size: 936.65 GiB size: 936.65 GiB (100.00%)
used: 32.83 GiB (3.5%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
mapped: luks-f0c06df4-c37c-4b4b-be44-1a0989006f94
used: 728 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 936.65 GiB size: 936.65 GiB (100.00%)
ID-4: /var/log raw-size: 936.65 GiB size: 936.65 GiB (100.00%)
ID-5: /var/tmp raw-size: 936.65 GiB size: 936.65 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.91 GiB used: 0 KiB (0.0%)
mapped: luks-d47b0d44-e52a-4d69-a1b0-fb89fe282926
ID-2: swap-2 type: zram size: 15.37 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 58.0 C mobo: N/A
Processes: 252 Uptime: 32m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.38 GiB used: 4.59 GiB (29.9%) Init: systemd v: 255
pm: pacman pkgs: 1344 libs: 421 tools: paru,yay Shell: Zsh v: 5.9
running-in: terminator inxi: 3.3.31
Garuda (2.6.22-1):
System install date: 2023-11-21
Last full system update: 2024-01-02
Thanks for your help !
