Garuda Audio sound issue
Hi,
I am using garuda for like 1 month. From the inception I am having issues with the sound. Tried garuda assistant for changing audio package, tried everything, pipewire sound not working, pluseaudio not working either, now using pipewire and alsa but I have to +-5 volume to play something.
root=UUID=96b7dcb8-2b02-4500-9b13-68483199a220 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.6 info: latte-dock
Type: Desktop System: Gigabyte product: B450 AORUS PRO WIFI v: N/A
Mobo: Gigabyte model: B450 AORUS PRO WIFI-CF v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F60h
date: 02/04/2021
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3677 high: 4209 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3498 2: 3176
3: 4209 4: 3600 5: 3735 6: 3593 7: 3598 8: 3688 9: 3647 10: 4183 11: 3600
12: 3600 bogomips: 86246
protection
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: ZOTAC driver: nvidia
v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
(as of 2022-10) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 07:00.0 chip-ID: 10de:2484 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.4
Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x292mm (20.87x11.50")
s-diag: 605mm (23.82")
Monitor-1: HDMI-0 res: 1920x1080 hz: 75 dpi: 92
size: 530x290mm (20.87x11.42") diag: 604mm (23.79") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2 v: 4.6.0 NVIDIA
520.56.06 direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: ZOTAC
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.1 chip-ID: 10de:228b
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak]
driver: iwlwifi v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 05:00.0 chip-ID: 8086:24fb class-ID: 0280
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-5:2 chip-ID: 8087:0aa7 class-ID: e001
Local Storage: total: 7.39 TiB used: 1.42 TiB (19.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Gigabyte
model: GP-GSM2NE3128GNTD size: 119.24 GiB block-size: physical: 512 B
rev: EDFM00.5 temp: 29.9 C scheme: GPT
model: WD40PURX-69N96Y0 size: 3.64 TiB block-size: physical: 4096 B
rev: 0A80 scheme: GPT
ID-1: / raw-size: 118.95 GiB size: 118.95 GiB (100.00%) used: 34.32 GiB
(28.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 118.95 GiB size: 118.95 GiB (100.00%) used: 34.32
GiB (28.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 118.95 GiB size: 118.95 GiB (100.00%) used: 34.32
ID-5: /var/tmp raw-size: 118.95 GiB size: 118.95 GiB (100.00%) used: 34.32
ID-1: swap-1 type: zram size: 15.56 GiB used: 4.5 MiB (0.0%)
System Temperatures: cpu: 50.5 C mobo: N/A gpu: nvidia temp: 44 C
Processes: 317 Uptime: 1h 35m wakeups: 0 Memory: 15.56 GiB used: 4.56 GiB
(29.3%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1870 libs: 509
Garuda (2.6.9-1):
System install date:     2022-10-19
Last full system update: 2022-10-27 ↻
Failed units:            irqbalance.service
Please, use three ~ in first and last line from terminal output :slight_smile:
I just changed it.
Now it’s working thanks man.
