Hey guys,
I have a problem when using Garuda-Assistant and switching to German as the system language:
In the system settings the checkboxes of installed services are not checked in the translated version despite the services being installed and running. Checking the boxes and applying the changes doesn't do anything. The checkboxes to enable services (e.g. NetworkManager or Bluetooth) do work as intended.
I have a feeling like Garuda-Assistant cant access which applications are installed and in what user groups the current user is while translated. It has normal functionality in reading and writing the status of those services however. I attach two screenshots (English and German) so it's pretty clear what the problem is.
Greetings
System details
System: Kernel: 5.14.14-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=5638347f-a82d-40e9-8dcb-3d97cf6f1cba
systemd.unified_cgroup_hierarchy=1 resume=UUID=bab922b0-7b6b-4b23-ba61-7d290d1cefac loglevel=3
Desktop: KDE Plasma 5.23.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_wayland vt: 2 dm: SDDM
Machine: Type: Laptop System: Timi product: TM1604 v: XMAKB3M0P0705 serial: <filter>
Mobo: Timi model: TM1604 v: XMAKB3M0P0705 serial: <filter> UEFI: Insyde v: XMAKB3M0P0705
date: 08/30/2017
Battery: ID-1: BAT0 charge: 9.6 Wh (96.0%) condition: 10.0/39.0 Wh (25.7%) volts: 8.5 min: 7.6
model: LGC R13B02W type: Li-poly serial: <filter> status: Not charging
CPU: Info: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check family: 6 model-id: 8E (142) stepping: 9 microcode: EA cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21599
Speed: 3100 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 3100 2: 3100 3: 3100 4: 3100
Graphics: Device-1: Intel HD Graphics 620 vendor: Xiaomi driver: i915 v: kernel bus-ID: 00:02.0
Device-2: NVIDIA GP108M [GeForce MX150] vendor: Xiaomi driver: nvidia v: 470.74
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1d12 class-ID: 0302
Device-3: Chicony XiaoMi USB 2.0 Webcam type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 04f2:b5a3 class-ID: 0e02
Display: wayland server: X.Org 1.21.1.2 compositor: kwin_wayland driver: loaded: modesetting
display-ID: :1 screens: 1
Monitor-1: XWAYLAND0 res: 1920x1080 hz: 60 dpi: 168 size: 290x170mm (11.4x6.7")
diag: 336mm (13.2")
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.2.4 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Xiaomi driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.14.14-zen1-1-zen running: yes
Network: Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel bus-ID: 02:00.0
chip-ID: 8086:24fd class-ID: 0280
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-7:5
chip-ID: 8087:0a2b class-ID: e001
Drives: Local Storage: total: 704.24 GiB used: 52.81 GiB (7.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLW256HEHP-00000 size: 238.47 GiB
rev: CXB7401Q temp: 22.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDS500G2B0B size: 465.76 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 90WD
Partition: ID-1: / raw-size: 457.26 GiB size: 457.26 GiB (100.00%) used: 52.81 GiB (11.5%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 580 KiB (0.1%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 457.26 GiB size: 457.26 GiB (100.00%) used: 52.81 GiB (11.5%) fs: btrfs
ID-4: /var/log raw-size: 457.26 GiB size: 457.26 GiB (100.00%) used: 52.81 GiB (11.5%)
ID-5: /var/tmp raw-size: 457.26 GiB size: 457.26 GiB (100.00%) used: 52.81 GiB (11.5%)
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
maj-min: 8:3
ID-2: swap-2 type: zram size: 7.67 GiB used: 350 MiB (4.5%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 57.0 C mobo: 42.0 C
Info: Processes: 247 Uptime: 10h 15m wakeups: 6 Memory: 7.68 GiB used: 3.55 GiB (46.3%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1484 lib: 360
