well .... finished testing the kde dragonized iso on a VM.
Seems there are some new applets on the latte-dock
Well, everything worked well, installed, and running nicelly.
But then I went into Garuda Assistant, and tried changing some settings, because there were some issues there in the previous ISO. This time.... I changed some settings ( just to test, for example adding firewalld or uresourced and irqbalance ) ... clicked "apply", and nothing happened, with the previous settings getting back enabled after 1 or 2 seconds.
Can anyone test this ? its a VM, with normal install ( use all new disk ).
Do you have a working pacman? Try running update first.
The behavior you are describing sounds like what happens if you try to use it from the ISO where you have no pacman databases sync’d for the first time.
vmware = closed source = no and kvm/qemu I use when is anything serious. When is just to test something, VB does it. I guess the 3d was even fast, but has some issues ( which its strange, since as shown in the video, was doing kwin animations and blurs nicelly )
