I am having quite the time attempting to adjust threadIRQs for my USB interface for audio recording to prevent audio dropouts and optimize CPU usage. Currently using Xen and an Intel 12th gen CPU (I suspect Intel’s Big-little architecture is secretly to blame for my audio issues but I want to do my due diligence)
The last time I did this for an OS was Manjaro in 2020 - I cannot find where that configuration file is with my Garuda setup. Anyone able to point me at where I would go to adjust those permanently, rather than adding a line to the config at boot time?
Garuda INXI output
Kernel: 6.12.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=a4bd2965-ff43-43af-bf2b-4f77f1abcab0 rw rootflags=subvol=@
resume=UUID=4fc40dca-ca04-41cb-a51b-8895e6280298 loglevel=3 quiet ibt=off
Type: Desktop Mobo: Micro-Star model: PRO Z690-A (MS-7D25) v: 2.0
Megatrends LLC. v: A.00 date: 09/29/2021
Info: model: 12th Gen Intel Core i9-12900KF bits: 64 type: MST AMCP
microcode: 0x37
Topology: cpus: 1x dies: 1 clusters: 10 cores: 16 threads: 24 mt: 8 tpc: 2
st: 8 smt: enabled cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32
KiB, 8x64 KiB L2: 14 MiB desc: 8x1.2 MiB, 2x2 MiB L3: 30 MiB
desc: 1x30 MiB
Speed (MHz): avg: 4901 min/max: 800/5100:5200:3900 scaling:
driver: intel_pstate governor: performance cores: 1: 4901 2: 4901 3: 4901
4: 4901 5: 4901 6: 4901 7: 4901 8: 4901 9: 4901 10: 4901 11: 4901 12: 4901
13: 4901 14: 4901 15: 4901 16: 4901 17: 4901 18: 4901 19: 4901 20: 4901
21: 4901 22: 4901 23: 4901 24: 4901 bogomips: 152985
Device-1: Advanced Micro Devices [AMD/ATI] Navi 24 [Radeon RX 6400/6500
XT/6500M] vendor: XFX driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-1,HDMI-A-1 empty: Writeback-1 bus-ID: 03:00.0
chip-ID: 1002:743f class-ID: 0300
gpu: amdgpu d-rect: 3440x2880 display-ID: 0
Monitor-1: DP-1 pos: bottom res: 3440x1440 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: primary,top res: 3440x1440 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6500 XT (radeonsi
navi24 LLVM 18.1.8 DRM 3.59 6.12.7-zen1-1-zen) device-ID: 1002:743f
memory: 3.91 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.303 layers: 8 device: 0 type: discrete-gpu name: AMD
Radeon RX 6500 XT (RADV NAVI24) driver: N/A device-ID: 1002:743f
Device-1: Intel Alder Lake-S HD Audio vendor: Micro-Star MSI
bus-ID: 00:1f.3 chip-ID: 8086:7ad0 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-3: PreSonus Audio FP2 driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5.1:5 chip-ID: 194f:0205
class-ID: 0103 serial: <filter>
Device-4: Nektar Impact LX88+ driver: snd-usb-audio type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5.2:7 chip-ID: 2467:2018
class-ID: 0103
Device-5: BEHRINGER GmbH UMC1820 driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5.3:9 chip-ID: 1397:0503
Device-6: PreSonus Audio ATOM driver: snd-usb-audio type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8.4:14 chip-ID: 194f:0206
API: ALSA v: k6.12.7-zen1-1-zen status: kernel-api tools: N/A
status: off 2: wireplumber status: active 3: pipewire-alsa type: plugin
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 06:00.0
Device-2: Intel Ethernet I225-V vendor: Micro-Star MSI driver: igc
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-13.1:10 chip-ID: 8087:0032
Local Storage: total: 5.91 TiB used: 1.25 TiB (21.2%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 46.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 500GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QGXA7 temp: 39.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000VN008-2DR166
tech: HDD rpm: 5980 serial: <filter> fw-rev: SC60 scheme: GPT
ID-1: / raw-size: 429.69 GiB size: 429.69 GiB (100.00%)
used: 93.44 GiB (21.7%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:4
used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p3 maj-min: 259:5
used: 1.16 TiB (63.8%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:2
ID-4: /var/log raw-size: 429.69 GiB size: 429.69 GiB (100.00%)
ID-5: /var/tmp raw-size: 429.69 GiB size: 429.69 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.2 GiB used: 4.14 GiB (13.3%)
max-streams: 24 dev: /dev/zram0
ID-2: swap-2 type: partition size: 35.57 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p1 maj-min: 259:3
System Temperatures: cpu: 36.0 C mobo: N/A gpu: amdgpu temp: 54.0 C
mem: 54.0 C
Memory: total: 32 GiB available: 31.2 GiB used: 10.59 GiB (33.9%)
Processes: 496 Power: uptime: 1d 7h 14m states: freeze,mem,disk
suspend: deep avail: s2idle wakeups: 1 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 12.44 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1799 libs: 494 tools: octopi,paru pm: appimage
pkgs: 0 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi
default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.36
System install date: 2022-09-16
Last full system update: 2025-01-01
Relevant software: NetworkManager mkinitcpio
Failed units: mnt-bulwark.mount
I’ve had good results with this guide.
Some of the config files will be in different places with Garuda, but all the main points are covered.
A Pro Audio Tuning Guide for Arch (and other Arch-based distros)
Also, one thing I learned as a noob is that if you want to use an audio interface for playing live instruments in real time like guitar, you’ll want to select “ALSA” for your audio device/mode in your DAW.
system
Closed
19 January 2025 07:05
4
