Dear Garuda users,
I have NVRM, ACPI problems while booting system.
journalctl -p3
journalctl -p3
jan 15 17:53:02 GarudaPC kernel:
jan 15 17:53:02 GarudaPC kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 545.29.06 Thu Nov 16 01:59:>
jan 15 17:53:02 GarudaPC kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG1.PEGP._D>
jan 15 17:53:02 GarudaPC kernel: ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20230628/dswload2->
jan 15 17:53:02 GarudaPC kernel: ACPI Error: Aborting method \_SB.PC00.PEG1.PEGP._DSM due to previous error (>
jan 15 17:53:03 GarudaPC kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG1.PEGP._D>
jan 15 17:53:03 GarudaPC kernel: ACPI Error: AE_ALREADY_EXISTS, CreateBufferField failure (20230628/dswload2->
jan 15 17:53:03 GarudaPC kernel: ACPI Error: Aborting method \_SB.PC00.PEG1.PEGP._DSM due to previous error (>
jan 15 17:53:03 GarudaPC systemd-modules-load[242]: Failed to find module 'vboxpci'
jan 15 17:53:04 GarudaPC systemd-modules-load[576]: Failed to find module 'vboxpci'
jan 15 17:53:05 GarudaPC (udev-worker)[730]: event4: Failed to call EVIOCSKEYCODE with scan code 0x7c, and ke>
jan 15 17:53:05 GarudaPC kernel: snd_hda_intel 0000:00:1f.3: no codecs found!
jan 15 17:53:05 GarudaPC kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
jan 15 17:53:06 GarudaPC kernel: nvidia-gpu 0000:01:00.3: i2c timeout error e0000000
jan 15 17:53:06 GarudaPC kernel: ucsi_ccg 5-0008: i2c_transfer failed -110
jan 15 17:53:06 GarudaPC kernel: ucsi_ccg 5-0008: ucsi_ccg_init failed - -110
jan 15 17:53:07 GarudaPC kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
jan 15 17:53:19 GarudaPC sddm-helper[2214]: gkr-pam: unable to locate daemon control file
jan 15 17:53:23 GarudaPC systemd[2217]: Failed to start BTRFS Assistant Snapper check.
jan 15 17:53:40 GarudaPC sudo[3868]: ekrisztian : a password is required ; TTY=pts/0 ; PWD=/home/ekrisztian ;>
lines 39-65/65 (END)
Kernel: 6.7.0-zen3-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=82dbfbcd-596d-43fa-ab71-d3e9e5b4c3ff rw rootflags=subvol=@
nvidia-drm.modeset=1 quiet quiet rd.udev.log_priority=3
vt.global_cursor_default=0
resume=UUID=eea8b27e-fe2b-447e-a67a-7abda6c42bdc loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_wayland vt: 1
Mobo: ASUSTeK model: ROG STRIX B660-A GAMING WIFI v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 2212
date: 12/13/2022
Info: model: 13th Gen Intel Core i5-13500 bits: 64 type: MST AMCP
process: Intel 7 (10nm) family: 6 model-id: 0xBF (191) stepping: 2
microcode: 0x32
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 800 min/max: 800/4800:3500 scaling: driver: intel_pstate
17: 800 18: 800 19: 800 20: 800 bogomips: 99840
Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] vendor: ASUSTeK driver: nvidia
(as of 2023-10; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 ports: active: none off: DP-1
empty: DVI-D-1,HDMI-A-1,HDMI-A-2 bus-ID: 0000:01:00.0 chip-ID: 10de:2182
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: 0
Monitor-1: DP-1 res: 3440x1440 size: N/A modes: N/A
x11: drv: zink inactive: device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2
memory: 5.86 GiB display-ID: :1.0
API: Vulkan v: 1.3.274 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1660 Ti driver: nvidia v: 545.29.06 device-ID: 10de:2182
Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
Device-2: NVIDIA TU116 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:1aeb
Device-3: Tenx USB AUDIO driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-11.3:8
chip-ID: 1130:1620 class-ID: 0300
Device-4: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3
chip-ID: 0b05:1a16 class-ID: 0300
API: ALSA v: k6.7.0-zen3-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
bus-ID: 0000:00:14.3 chip-ID: 8086:7af0 class-ID: 0280
port: N/A bus-ID: 0000:04:00.0 chip-ID: 8086:15f3 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:6 chip-ID: 8087:0026
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 5 TiB used: 400 GiB (7.8%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 34.9 C
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung
fw-rev: 1B2QEXM7 temp: 32.9 C scheme: GPT
model: WD20EURX-64HYZY0 size: 1.82 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: MBR
ID-4: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MQ04UBD200
size: 1.82 TiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.0
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5400
serial: <filter> scheme: MBR
ID-1: / raw-size: 431.26 GiB size: 431.26 GiB (100.00%)
used: 147.92 GiB (34.3%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:6
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:5
ID-3: /home raw-size: 431.26 GiB size: 431.26 GiB (100.00%)
ID-4: /var/log raw-size: 431.26 GiB size: 431.26 GiB (100.00%)
ID-5: /var/tmp raw-size: 431.26 GiB size: 431.26 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.2 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:7
ID-2: swap-2 type: zram size: 31.09 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 20 dev: /dev/zram0
System Temperatures: cpu: 27.0 C mobo: N/A
Processes: 410 Uptime: 8m wakeups: 0 Memory: total: 32 GiB note: est.
available: 31.09 GiB used: 4.39 GiB (14.1%) Init: systemd v: 255
Packages: pm: pacman pkgs: 1627 libs: 504 tools: octopi,pamac,paru
Shell: fish v: 3.7.0 running-in: konsole inxi: 3.3.31
Garuda (2.6.22-1):
System install date: 2024-01-14
Last full system update: 2024-01-15
For some reason my monitor is not turn on after sleeping, or hibernating the system.
Could you help me, please?
Thanks a lot,
Krisz
