Gammastep gives me
Kernel: 6.17.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=9f4c5651-5ef8-4a9b-9308-eafde2769a6c rw rootflags=subvol=@
loglevel=3 quiet
Desktop: KDE Plasma v: 6.5.1 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Desktop Mobo: Gigabyte model: B550I AORUS PRO AX v: x.x serial: N/A
uuid: 03560274-043c-05cb-2a06-510700080009 UEFI: American Megatrends LLC.
v: FE date: 03/22/2024
Info: model: AMD Ryzen 7 5800X socket: AM4 bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x21 (33) stepping: 2 microcode: 0xA201211
Speed (MHz): avg: 1754 min/max: 556/4854 boost: enabled
base/boost: 3800/4850 scaling: driver: amd-pstate-epp governor: powersave
volts: 1.1 V ext-clock: 100 MHz cores: 1: 1754 2: 1754 3: 1754 4: 1754
5: 1754 6: 1754 7: 1754 8: 1754 9: 1754 10: 1754 11: 1754 12: 1754
13: 1754 14: 1754 15: 1754 16: 1754 bogomips: 121374
Device-1: NVIDIA AD107 [GeForce RTX 4060] vendor: ZOTAC driver: nvidia
v: 580.95.05 alternate: nouveau,nvidia_drm non-free: 550-580.xx+
status: current (as of 2025-08) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
ports: active: DP-3 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 05:00.0
chip-ID: 10de:2882 class-ID: 0300
Display: unspecified server: X.Org v: 24.1.9 with: Xwayland v: 24.1.9
compositor: kwin_wayland driver: gpu: nv_platform,nvidia,nvidia-nvswitch
s-diag: 583mm (22.95")
Monitor-1: DP-3 model: LG (GoldStar) ULTRAGEAR+ serial: <filter>
built: 2024 res: mode: 1920x1080 hz: 144 scale: 100% (1) dpi: 82 gamma: 1.2
size: 597x336mm (23.5x13.23") diag: 801mm (31.5") ratio: 16:9 modes:
max: 3840x2160 min: 640x480
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.95.05
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4060/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.4.328 layers: 7 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4060 driver: nvidia v: 580.95.05
device-ID: 10de:2882 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 21.1.4 256 bits) driver: mesa llvmpipe v: 25.2.6-arch1.1 (LLVM
21.1.4) device-ID: 10005:0000 surfaces: N/A
Device-1: NVIDIA AD107 High Definition Audio vendor: ZOTAC
bus-ID: 05:00.1 chip-ID: 10de:22be class-ID: 0403
lanes: 16 bus-ID: 07:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Realtek LG Monitor HP MIC driver: hid-generic,usbhid type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.4:6
chip-ID: 0bda:4027 class-ID: 0300 serial: <filter>
API: ALSA v: k6.17.6-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.4.9 status: n/a (root, process) with:
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
Device-2: Realtek RTL8852CE PCIe 802.11ax Wireless Network
port: d000 bus-ID: 04:00.0 chip-ID: 10ec:c852 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:3 chip-ID: 0bda:0852
Local Storage: total: 1.82 TiB used: 25.75 GiB (1.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Smart Modular Tech.
model: SHGS31-1000GS-2 family: SATA SSDs size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B sata: 3.2 speed: 6.0 Gb/s tech: SSD
serial: <filter> fw-rev: 0Q00 temp: 27 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 85d 23h cycles: 5031 Old-Age:
threshold: 1
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000MX500SSD1
family: Micron Client SSDs size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 045 temp: 26 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 232d 15h cycles: 2624
written: 7.64 TiB
ID-1: / raw-size: 448.41 GiB size: 448.41 GiB (100.00%)
used: 25.75 GiB (5.7%) fs: btrfs block-size: 4096 B dev: /dev/sdb4
maj-min: 8:20
used: 960 KiB (0.3%) fs: vfat block-size: 512 B dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 448.41 GiB size: 448.41 GiB (100.00%)
maj-min: 8:20
ID-4: /var/log raw-size: 448.41 GiB size: 448.41 GiB (100.00%)
maj-min: 8:20
ID-5: /var/tmp raw-size: 448.41 GiB size: 448.41 GiB (100.00%)
maj-min: 8:20
System Temperatures: cpu: 39.4 C mobo: N/A
Memory: total: 32 GiB available: 31.26 GiB used: 2.21 GiB (7.1%)
Processes: 385 Power: uptime: 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.44 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1273 libs: 324 tools: octopi,paru Compilers:
gcc: 15.2.1 Shell: Bash (sudo) v: 5.3.3 running-in: konsole inxi: 3.3.39
Garuda (2.11.1-1):
System install date:     2025-08-30
Garuda release:          250826
Last full system update: 2025-11-03
Relevant software:       snapper NetworkManager dracut nvidia-utils nvidia-open-dkms garuda-hardware-profile-nvidia garuda-hardware-profile-standard
Windows dual boot:       Yes
25/25 checks run in 0.83 seconds ⌛
Powered by garuda-health 🦅
--- LOW ---
I get – LOW —
󰛓 ❯ gammastep
Error: Could not control gamma, exiting.
Error: Failed to start adjustment method: wayland
Man Nvidia get your control app to work on Wayland already..
.So, I notced it says unspecified aftter graphics server, but info center says it is Wayland. Indx hhas
:down_arrow:
Why doesn’t this work with Wayland compositors like Mutter, KWin, Mir, and Enlightenment?
This program supports the wlroots protocol for gamma adjustments, but several Wayland compositors do not support this protocol. GNOME and KDE have their own built-in mechanisms for adjusting color temperature on Wayland.
And please get into the habit of adding a reasonable description of the issue in future. Single-line help requests do not meet the criteria for receiving support in the Garuda forum.
This is a output if you do it with sudo garuda-inxi if i am right . Do it without sudo will change it . (sudo = root and not user output).
Do it without sudo, that would leave importent info out right?
kwin_wayland
No it would not let important stuff out. It just gives more details about the PC but just very little ones. Example: Serial number or S.M.A.R.T ( Passed the Health Check).
I am not current on KDE, but doesn’t KDE have a baked in way of controlling “night mode” or gamma value?
Night mode, yes Gamma, no in Wayland.
Oh sorry.
