I’ve been using Linux for quite some time. All the way to back when opening a .doc or .xls file, playing a .mp3 or streaming a video in web browser were pipe dreams in Linux. Windows games on Linux at that time? Countless hours of compiling first iterations of wine from source and still 9/10 games didn’t work and the 1 that did ran poorly. Nvidia drivers, 3D acceleration in Linux? Don’t be silly.
Fast forward to 21st century and my how the tables turned. I’m aware what I want to showcase below is achievable on any Linux distro nowadays, but Garuda Dr460nized is the only distro I tried where everything worked pretty much out of the box (coincidentally my 1st ever experience with Arch and loving it), the only thing requiring manual intervention was installing EA Desktop in Lutris as there’s some breakage at the moment.
If Xbox Gamepass ran on Linux I would get rid of the Win11 dual-boot partition.
I’m using Dell G15, i7-11800H, RTX3060, 16G RAM.
Kernel: 6.13.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=fd9b2a0b-0332-4450-a369-6931fedf036e rw rootflags=subvol=@
quiet loglevel=3 psi=1 splash ibt=off
Desktop: KDE Plasma v: ERR-101 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Laptop System: Dell product: Dell G15 5511 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0YC2KJ v: A00 serial: <filter> part-nu: 0A70
uuid: 4c4c4544-004e-5210-8042-b8c04f584633 UEFI: Dell v: 1.34.0
date: 12/16/2024
ID-1: BAT0 charge: 62.9 Wh (100.0%) condition: 62.9/84.3 Wh (74.6%)
volts: 12.0 min: 11.4 model: BYD DELL M59JH15 type: Li-poly serial: <filter>
status: full
Info: model: 11th Gen Intel Core i7-11800H socket: U3E1 bits: 64
type: MT MCP arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
microcode: 0x54
smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 10 MiB
desc: 8x1.2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1895 min/max: 800/4600 base/boost: 2277/5000 scaling:
driver: intel_pstate governor: powersave volts: 0.7 V ext-clock: 100 MHz
cores: 1: 1895 2: 1895 3: 1895 4: 1895 5: 1895 6: 1895 7: 1895 8: 1895
9: 1895 10: 1895 11: 1895 12: 1895 13: 1895 14: 1895 15: 1895 16: 1895
bogomips: 73728
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Dell driver: i915
v: kernel alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports:
active: eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:9a60
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Dell
gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 ports: active: none
empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2560 class-ID: 0300
Display: unspecified server: X.Org v: 24.1.6 with: Xwayland v: 24.1.6
s-diag: 583mm (22.95")
Monitor-1: eDP-1 model: AU Optronics 0xae8b built: 2020 res:
mode: 1920x1080 hz: 165 scale: 100% (1) dpi: 142 gamma: 1.2
modes: 1920x1080
API: EGL v: 1.5 hw: drv: intel iris platforms: surfaceless: drv: swrast
x11: drv: iris inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (TGL GT1)
device-ID: 8086:9a60 memory: 7.5 GiB unified: yes
API: Vulkan v: 1.4.303 layers: 10 device: 0 type: integrated-gpu
name: Intel UHD Graphics (TGL GT1) driver: N/A device-ID: 8086:9a60
surfaces: xcb,xlib device: 1 type: discrete-gpu name: NVIDIA GeForce RTX
3060 Laptop GPU driver: N/A device-ID: 10de:2560 surfaces: xcb,xlib
device: 2 type: cpu name: llvmpipe (LLVM 19.1.7 256 bits) driver: N/A
Device-1: Intel Tiger Lake-H HD Audio vendor: Dell
snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0401
Device-2: NVIDIA GA106 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16
API: ALSA v: k6.13.4-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.7 status: n/a (root, process) with:
Device-2: Realtek Killer E2600 GbE vendor: Dell driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 2e:00.0
chip-ID: 10ec:2600 class-ID: 0200
IF: enp46s0 state: down mac: <filter>
IF-ID-3: wg0-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-14:2 chip-ID: 8087:0026
Local Storage: total: 1.6 TiB used: 839.85 GiB (51.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P3SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 39.9 C
SMART: yes health: PASSED on: 372d 23h cycles: 747
read-units: 103,174,769 [52.8 TB] written-units: 90,838,128 [46.5 TB]
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: PM991a NVMe 512GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 26304039 temp: 40.9 C
SMART: yes health: PASSED on: 88d 10h cycles: 2,796
read-units: 91,451,586 [46.8 TB] written-units: 46,844,035 [23.9 TB]
ID-3: /dev/sda maj-min: 8:0 vendor: SanDisk model: SanDisk 3.2 Gen1
size: 233.13 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: DL17 scheme: GPT
ID-1: / raw-size: 146.48 GiB size: 146.48 GiB (100.00%)
used: 69.09 GiB (47.2%) fs: btrfs block-size: 4096 B dev: /dev/nvme1n1p8
maj-min: 259:12
ID-2: /boot/efi raw-size: 250 MiB size: 246 MiB (98.40%)
used: 99 MiB (40.3%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1
maj-min: 259:5
ID-3: /home raw-size: 146.48 GiB size: 146.48 GiB (100.00%)
maj-min: 259:12
ID-4: /var/log raw-size: 146.48 GiB size: 146.48 GiB (100.00%)
maj-min: 259:12
ID-5: /var/tmp raw-size: 146.48 GiB size: 146.48 GiB (100.00%)
maj-min: 259:12
ID-1: swap-1 type: zram size: 15.35 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 47.0 C mobo: 40.0 C
Fan Speeds (rpm): cpu: 0 fan-2: 0
Memory: total: 16 GiB available: 15.35 GiB used: 5.11 GiB (33.3%)
igpu: 60 MiB
Processes: 425 Power: uptime: 14m states: freeze,mem,disk suspend: s2idle
image: 6.05 GiB services: org_kde_powerdevil, power-profiles-daemon,
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 2272 libs: 593
tools: octopi,pacseek,paru pm: rpm pkgs: 0 Compilers: clang: 19.1.7
gcc: 14.2.1 alt: 13 Shell: garuda-inxi (sudo) default: Bash v: 5.2.37
running-in: yakuake inxi: 3.3.37
Garuda (2.6.26-1.1):
System install date: 2024-04-20
Last full system update: 2025-02-27
Windows dual boot: Yes
Total system updates: 1046
--> Updates per week: 23
Now for some screenshots/benchmarks/videos ![]()
Some benchmarks in both OS:
for w/e reason the seq write is slow in Win, I ran the bench 3 times.
Videos (all from Garuda, MangoHUD included) recorded with gpu-screen-recoder:
AC Valhalla via Ubisoft Connect
Cyberpunk 2077 via Steam, RTX on
Cyberpunk 2077 via Steam, RTX off
Dead Space Remake via EA Desktop, RTX on
None of that would be possible >20 years ago.
So, on behalf of this old guy still addicted to games, a heartfelt
thanks to everyone who makes Garuda what it is!
