Strange FPS still on Garuda. Shows 60 fps, but feels like 25-30. The game was medieval dynasty. The game ran smoother on Ubuntu. It’s like it’s slowing down. I installed the driver. I wanted to try cachuos(bore) on a different core, by the way it worked on the previous garuda, but now it doesn’t go beyond the initial ramdisk. 2060 super 16gb ram ryzen 5 3600. The game runs on ultra.
Kernel: 6.6.0-AMD-znver3 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-amd-znver3
root=UUID=03df0426-da0c-48c6-abc6-07c7ff5d4f09 rw rootflags=subvol=@
Type: Desktop System: Micro-Star product: MS-7B89 v: 1.0
Mobo: Micro-Star model: B450M MORTAR MAX (MS-7B89) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 2.H0
date: 07/27/2022
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3600 high: 3603 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3600 2: 3600
3: 3603 4: 3600 5: 3600 6: 3600 7: 3600 8: 3600 9: 3600 10: 3597 11: 3600
12: 3600 bogomips: 86427
Device-1: NVIDIA TU106 [GeForce RTX 2060 SUPER] vendor: ASUSTeK
driver: nvidia v: 545.29.02 alternate: nvidia_drm non-free: 545.xx+
status: current (as of 2023-10; EOL~2026-12-xx) arch: Turing code: TUxxx
lanes: 16 bus-ID: 26:00.0 chip-ID: 10de:1f47 class-ID: 0300
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.02x10.71")
s-diag: 554mm (21.82")
Monitor-1: HDMI-1 res: 1920x1080 hz: 60 dpi: 103
size: 475x267mm (18.7x10.51") diag: 545mm (21.45") modes: N/A
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2060
SUPER/PCIe/SSE2 memory: 7.81 GiB
API: Vulkan v: 1.3.269 layers: 9 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 2060 SUPER driver: nvidia v: 545.29.02 device-ID: 10de:1f47
surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 256
bits) driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6)
Device-1: NVIDIA TU106 High Definition Audio vendor: ASUSTeK
bus-ID: 26:00.1 chip-ID: 10de:10f9 class-ID: 0403
bus-ID: 28:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Kingston HyperX 7.1 Audio
lanes: 1 mode: 1.1 bus-ID: 1-7:2 chip-ID: 0951:16a4 class-ID: 0300
API: ALSA v: k6.6.0-AMD-znver3 status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
IF: enp34s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.02 TiB used: 33.22 GiB (3.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: AMD Radeon model: R5MP120G8
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: T1103F0L temp: 36.9 C
model: WD10EZEX-75WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
ID-1: / raw-size: 552.87 GiB size: 552.87 GiB (100.00%)
used: 33.21 GiB (6.0%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 552.87 GiB size: 552.87 GiB (100.00%)
ID-4: /var/log raw-size: 552.87 GiB size: 552.87 GiB (100.00%)
ID-5: /var/tmp raw-size: 552.87 GiB size: 552.87 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.56 GiB used: 140.1 MiB (0.9%)
System Temperatures: cpu: 57.0 C mobo: N/A gpu: nvidia temp: 44 C
Processes: 334 Uptime: 9h 38m wakeups: 1 Memory: total: 16 GiB
available: 15.56 GiB used: 3.15 GiB (20.2%) Init: systemd v: 254
pm: pacman pkgs: 1427 libs: 449 tools: octopi,pamac,paru Shell: fish
v: 3.6.1 running-in: konsole inxi: 3.3.31
Garuda (2.6.17-1):
System install date: 2023-11-04
Last full system update: 2023-11-05 ↻
So in all games running it does not go smoothly.
Have you tested other kernels? E.g. the standard linux-zen?
I assume AMD kernels are optimized for your hw, is this the correct one?
Just guessing… Not a gamer…
I tried znver 3. Right now I can’t stop talking to the girl, I’ll try cachyos, yesterday it didn’t load, but today it loaded. Everything seemed to be fine with him at the last release. But there were so many bugs, then one thing or another stopped working, just copying it to a flash drive costs. that then nothing opens on it or there were errors from one file system to another. Or when in startup the latest applications were automatically opened after downloading to the entire desktop. This image flies the system itself as if it were on an SSD. Therefore, I remembered how games worked on Ubuntu, there were no glitches, there were no errors in the system, so I switched to it immediately. But if everything in this system is for games, then you have to configure it manually. That’s why I’m switching to garuda again. With some kernels, even the system does not go beyond booting. Kernel bug.
Just a hint, I am not a gamer ![]()
Check
cpupower frequency-info
Add
amd_pstate=active
with garuda-boot-options to the kernel parameters.
Yes, something has to do with the processor frequency. The game goes either smoothly or as if the main character smoked grass and gets crushed. I turned on game boost in the BIOS, ran cachyos-bore and proton experimental on the core and it became smoother than on Windows and without drawdowns 2 times as in Windows than on the ZEN core. But in directx 12 there are slowdowns and FPS drops. But the computer makes noise like an airplane. I’ll try all the options. Or in general, what kind of distribution can be installed, but there would be less dancing with settings for games other than garuda.
I recommend asking on a general Linux forum or r/Linux_Gaming what it could be. I think Arch based distros are good for gaming, since they software is quite new. SteamOS is also Arch based, so I would try to stick with Garuda.
The system needs a reboot .
Edit :And it appears that it needs a quick update if you wish .
