inxi -Faz
❯ inxi -Faz
System: Kernel: 5.14.14-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=03ae8764-9655-49fc-b610-9ccf6206853d rw
Desktop: KDE Plasma 5.23.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: LENOVO product: 81LK v: IdeaPad L340-15IRH Gaming serial: <filter> Chassis: type: 10
Mobo: LENOVO model: LNVNB161216 v: SDK0Q55722 WIN serial: <filter> UEFI: LENOVO v: BGCN24WW date: 08/19/2019
Battery: ID-1: BAT0 charge: 36.7 Wh (100.0%) condition: 36.7/45.0 Wh (81.5%) volts: 12.8 min: 11.5 model: Celxpert L18C3PF1
type: Li-poly serial: <filter> status: Full cycles: 254
CPU: Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 9E (158) stepping: A (10) microcode: EA cache: L2: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 62399
Speed: 2422 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 2422 2: 4156 3: 4200 4: 4087 5: 3992 6: 4204 7: 3513
8: 4179 9: 4200 10: 4201 11: 3931 12: 4195
Graphics: Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo driver: nvidia v: 470.74
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0300
Device-3: Lite-On Integrated Camera type: USB driver: uvcvideo bus-ID: 1-8:2 chip-ID: 04ca:7070 class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: modesetting,nvidia display-ID: :0
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.2.4 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Sound Server-1: ALSA v: k5.14.14-zen1-1-zen running: yes
Network: Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:a370
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169 v: kernel port: 3000
bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8 bus-ID: 1-14:3
Drives: Local Storage: total: 1.03 TiB used: 310.53 GiB (29.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM128GDHTNG-8310A size: 119.24 GiB block-size:
physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter> rev: 80060C00 temp: 40.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-24Z10 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 1A05 scheme: GPT
Partition: ID-1: / raw-size: 118.99 GiB size: 118.99 GiB (100.00%) used: 45.36 GiB (38.1%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 562 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 931.51 GiB size: 931.51 GiB (100.00%) used: 265.17 GiB (28.5%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
ID-4: /var/log raw-size: 118.99 GiB size: 118.99 GiB (100.00%) used: 45.36 GiB (38.1%) fs: btrfs
ID-5: /var/tmp raw-size: 118.99 GiB size: 118.99 GiB (100.00%) used: 45.36 GiB (38.1%) fs: btrfs
ID-1: swap-1 type: zram size: 7.64 GiB used: 3.67 GiB (48.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 55.0 C mobo: N/A
Info: Processes: 393 Uptime: 1h 48m wakeups: 1 Memory: 7.64 GiB used: 4.85 GiB (63.5%) Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 2066 lib: 556 Shell: Zsh v: 5.8
running-in: yakuake inxi: 3.3.08
Hello everyone,
I have bought a redgear pro series gamepad. It has both XInput and Dinput stype input. I am having issues in getting it to work in games that I am running on wine (using Lutris). I am having this issue in multiple games that I tried.
I notice that when I run the game with gamepad connected in XInput mode, this is the output of wine (I have censored the game name and path.) :-
002c:fixme:winediag:LdrInitializeThunk wine-staging 6.20 is a testing version containing experimental patches.
002c:fixme:winediag:LdrInitializeThunk Please mention your exact version when filing bug reports on winehq.org.
MESA-INTEL: warning: Performance support disabled, consider sysctl dev.i915.perf_stream_paranoid=0
007c:err:ole:start_rpcss Failed to start RpcSs service
003c:err:service:process_send_command receiving command result timed out
003c:fixme:service:scmdatabase_autostart_services Auto-start service L"wineusb" failed to start: 1053
003c:fixme:service:scmdatabase_autostart_services Auto-start service L"winebus" failed to start: 1053
0124:fixme:ntdll:EtwEventSetInformation (deadbeef, 2, 00000001812C5B48, 43) stub
0124:fixme:ntdll:EtwEventSetInformation (deadbeef, 2, 0000000140012360, 43) stub
Mono path[0] = '<path-to-game>/<game-name>/<game-name>_Data/Managed'
Mono config path = '<path-to-game>/<game-name>/<game-name>_Data/Mono/etc'
0124:fixme:imm:ImmReleaseContext (0000000000010064, 00000000001BC440): stub
0124:fixme:wbemprox:client_security_SetBlanket 00000002419C2D40, 00000000001C4170, 10, 0, (null), 3, 3, 0000000000000000, 0x00000000
0124:fixme:wbemprox:client_security_Release 00000002419C2D40
0124:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
01f4:fixme:ver:GetCurrentPackageId (000000000869FE10 0000000000000000): stub
01f4:fixme:avrt:AvSetMmThreadCharacteristicsW (L"Audio",000000000869FDB8): stub
0124:fixme:service:I_ScRegisterDeviceNotification Notification filters are not yet implemented.
0124:fixme:win:RegisterTouchWindow (0000000000010064 00000000): stub
0124:fixme:wbemprox:client_security_SetBlanket 00000002419C2D40, 0000000009D55330, 10, 0, (null), 3, 3, 0000000000000000, 0x00000000
0124:fixme:wbemprox:wbem_services_CreateInstanceEnum unsupported flags 0x00000030
0110:fixme:imm:ImeSetActiveContext (0x25ea30, 0): stub
0110:fixme:imm:ImmReleaseContext (0000000000030046, 000000000025EA30): stub
019c:fixme:toolhelp:CreateToolhelp32Snapshot Unimplemented: heap list snapshot
019c:fixme:toolhelp:Heap32ListFirst : stub
^C023c:fixme:console:default_ctrl_handler Terminating process 20 on event 0
I see these as the problematic lines (because the name USB in it):-
By the way, this is the output when I connect my gamepad in Dinput mode. In this mode, the game recognizes the gamepad and works
0108:fixme:ntdll:EtwEventSetInformation (deadbeef, 2, 00000001812C5B48, 43) stub
0108:fixme:ntdll:EtwEventSetInformation (deadbeef, 2, 0000000140012360, 43) stub
0108:fixme:imm:ImmReleaseContext (0000000000010064, 00000000001BC460): stub
0108:fixme:wbemprox:client_security_SetBlanket 00000002419C2D40, 00000000001C4190, 10, 0, (null), 3, 3, 0000000000000000, 0x00000000
0108:fixme:wbemprox:client_security_Release 00000002419C2D40
0108:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
01d8:fixme:ver:GetCurrentPackageId (000000000869FE10 0000000000000000): stub
01d8:fixme:avrt:AvSetMmThreadCharacteristicsW (L"Audio",000000000869FDB8): stub
01e8:fixme:service:I_ScRegisterDeviceNotification Notification filters are not yet implemented.
0108:fixme:service:I_ScRegisterDeviceNotification Notification filters are not yet implemented.
0108:fixme:win:RegisterTouchWindow (0000000000010064 00000000): stub
0108:fixme:wbemprox:client_security_SetBlanket 00000002419C2D40, 000000000A0A1790, 10, 0, (null), 3, 3, 0000000000000000, 0x00000000
0108:fixme:wbemprox:wbem_services_CreateInstanceEnum unsupported flags 0x00000030
0088:fixme:imm:ImeSetActiveContext (0x25ea80, 0): stub
0088:fixme:imm:ImmReleaseContext (0000000000010020, 000000000025EA80): stub
017c:fixme:toolhelp:CreateToolhelp32Snapshot Unimplemented: heap list snapshot
017c:fixme:toolhelp:Heap32ListFirst : stub
I also notice this that if I switch rapidly from Dinput mode to Xinput mode and start the game, the gamepad works. I think maybe some process is using the gamepad and does not allow wine to mount it.
So I tried running watch lsof /dev/input/js0
while running the game, but it comes empty.
Please help me resolve the issue. Thank you very much in advance.
Steps taken to resolve:-
- Checked that the controller works in Xinput mode by using jstest.
- Created a new wineprefix. Still the same issue.
- Enabled winusb in winecfg with native, builtin setting. No difference.
