Solution
Solution for me was this steps.
- Read and try some tips from https://www.protondb.com/app/9420
- execute this commands in shell
protontricks 9420 dlls xact
protontricks 9420 dlls d3dx9
- add this line into the “Launch Command” field in the Game Properties.
PROTON_NO_ESYNC=1 PROTON_NO_FSYNC=1 PROTON_DUMP_DEBUG_COMMANDS=1 %command% /fullscreen 1920 1080
Original Request
I’m new to Linux Gaming Topic and hope you can help me to fix the following issue.
I’m pretty sure I have over read something or haven’t done any necessary step, any help is really appreciated .
I’m using Linux in various flavors since several years and read Gaming on Garuda | Garuda Linux wiki .
I have installed via “Garuda Welcome” => “Gardua Gamer” Wine and Steam runtime.
I logged in into steam and buyed “Supreme Commander Forged Alliance”, maybe this is the wrong came to start .
Maybe there Is a game which works 100% which I can run to see if the setup works.
After set in the Settings the compatibility for all games and use Proton-9.0-3 I have tried to play the game.
The start button make this round “Play => Cancel => Stop” every time when i press the green Playbutton.
After some searching was I able to find the PROTON_LOG=1
option and start steam with that.
That’s the Steam output when I starting steam and launch the game.
PROTON_LOG=1 steam --help
steam.sh[7335]: Running Steam on garuda Soaring 64-bit
steam.sh[7335]: STEAM_RUNTIME is enabled automatically
setup.sh[7405]: Steam runtime environment up-to-date!
steam.sh[7335]: Steam client's requirements are satisfied
[2024-10-08 21:45:58] Startup - updater built Sep 17 2024 20:02:19
[2024-10-08 21:45:58] Startup - Steam Client launched with: '/home/alex/.local/share/Steam/ubuntu12_32/steam' '-srt-logger-opened' '--help'
10/08 21:45:58 minidumps folder is set to /tmp/dumps
10/08 21:45:58 Init: Installing breakpad exception handler for appid(steam)/version(1726604483)/tid(7467)
[2024-10-08 21:45:58] Loading cached metrics from disk (/home/alex/.local/share/Steam/package/steam_client_metrics.bin)
[2024-10-08 21:45:58] Using the following download hosts for Public, Realm steamglobal
[2024-10-08 21:45:58] 1. https://client-update.akamai.steamstatic.com, /, Realm 'steamglobal', weight was 1000, source = 'update_hosts_cached.vdf'
[2024-10-08 21:45:58] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 1, source = 'update_hosts_cached.vdf'
[2024-10-08 21:45:58] 3. https://client-update.steamstatic.com, /, Realm 'steamglobal', weight was 1, source = 'baked in'
[2024-10-08 21:45:58] Verifying installation...
[2024-10-08 21:45:58] Verification complete
UpdateUI: skip show logo
Steam logging initialized: directory: /home/alex/.local/share/Steam/logs
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xe6d1bdc0
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xe6d1a500
steamwebhelper.sh[7489]: Using supervisor /home/alex/.local/share/Steam/ubuntu12_32/steam-runtime/amd64/usr/bin/steam-runtime-supervisor
steamwebhelper.sh[7489]: Starting steamwebhelper under bootstrap sniper steam runtime via /home/alex/.local/share/Steam/ubuntu12_64/steam-runtime-sniper.sh
steamwebhelper.sh[7489]: Using CEF sandbox \(try with -no-cef-sandbox if this fails\)
steamwebhelper.sh[7489]: Starting steamwebhelper with Sniper steam runtime at /home/alex/.local/share/Steam/ubuntu12_64/steam-runtime-sniper/_v2-entry-point
x86_64-linux-gnu-capsule-capture-libs: warning: Dependencies of libnvidia-pkcs11.so.560.35.03 not found, ignoring: Missing dependencies: Could not find "libcrypto.so.1.1" in LD_LIBRARY_PATH "/home/alex/.local/share/Steam/ubuntu12_32:/home/alex/.local/share/Steam/ubuntu12_32/panorama:/usr/lib32:/usr/lib/libfakeroot:/usr/lib", ld.so.cache, DT_RUNPATH or fallback /lib:/usr/lib
Steam Runtime Launch Service: starting steam-runtime-launcher-service
Steam Runtime Launch Service: steam-runtime-launcher-service is running pid 7590
bus_name=com.steampowered.PressureVessel.LaunchAlongsideSteam
exec ./steamwebhelper -lang=en_US -cachedir=/home/alex/.local/share/Steam/config/htmlcache -steampid=7467 -buildid=1726604483 -steamid=0 -logdir=/home/alex/.local/share/Steam/logs -uimode=7 -startcount=0 -userdatadir=/home/alex/.local/share/Steam/config/cefdata -steamuniverse=Public -realm=Global -clientui=/home/alex/.local/share/Steam/clientui -steampath=/home/alex/.local/share/Steam/ubuntu12_32/steam -launcher=0 -use_safe_shutdown_workaround -use_xcomposite_workaround -no-restart-on-ui-mode-change --valve-enable-site-isolation --enable-smooth-scrolling --disable-gpu-compositing --disable-gpu --password-store=basic --log-file=/home/alex/.local/share/Steam/logs/cef_log.txt --disable-quick-menu --disable-features=SpareRendererForSitePerProcess,DcheckIsFatal
steamwebhelper.sh[7775]: Using supervisor /home/alex/.local/share/Steam/ubuntu12_32/steam-runtime/amd64/usr/bin/steam-runtime-supervisor
steamwebhelper.sh[7775]: Starting steamwebhelper under bootstrap sniper steam runtime via /home/alex/.local/share/Steam/ubuntu12_64/steam-runtime-sniper.sh
steamwebhelper.sh[7775]: Using CEF sandbox \(try with -no-cef-sandbox if this fails\)
steamwebhelper.sh[7775]: Starting steamwebhelper with Sniper steam runtime at /home/alex/.local/share/Steam/ubuntu12_64/steam-runtime-sniper/_v2-entry-point
exec ./steamwebhelper -lang=en_US -cachedir=/home/alex/.local/share/Steam/config/htmlcache -steampid=7467 -buildid=1726604483 -steamid=0 -logdir=/home/alex/.local/share/Steam/logs -uimode=7 -startcount=1 -userdatadir=/home/alex/.local/share/Steam/config/cefdata -steamuniverse=Public -realm=Global -clientui=/home/alex/.local/share/Steam/clientui -steampath=/home/alex/.local/share/Steam/ubuntu12_32/steam -launcher=0 -use_safe_shutdown_workaround -use_xcomposite_workaround -no-restart-on-ui-mode-change --valve-enable-site-isolation --enable-smooth-scrolling --disable-gpu-compositing --disable-gpu --password-store=basic --log-file=/home/alex/.local/share/Steam/logs/cef_log.txt --disable-quick-menu --disable-features=SpareRendererForSitePerProcess,DcheckIsFatal
/usr/share/themes/Sweet-Dark/gtk-2.0/main.rc:727: error: unexpected identifier 'direction', expected character '}'
/usr/share/themes/Sweet-Dark/gtk-2.0/apps/chrome.rc:50: error: invalid string constant "button", expected valid string constant
/usr/share/themes/Sweet-Dark/gtk-2.0/apps/xfce.rc:79: error: invalid string constant "entry", expected valid string constant
BRefreshApplicationsInLibrary 1: 0ms
Desktop state changed: desktop: { pos: 0, 0 size: 1920,1080 } primary: { pos: 0, 0 size: 1920,1080 }
BuildCompleteAppOverviewChange: 126 apps
RegisterForAppOverview 1: 1ms
RegisterForAppOverview 2: 1ms
chdir "/home/alex/.local/share/Steam/steamapps/common/Supreme Commander Forged Alliance"
Adding process 8144 for gameID 9420
ERROR: ld.so: object '/home/alex/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
ERROR: ld.so: object '/home/alex/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
Adding process 8145 for gameID 9420
Adding process 8146 for gameID 9420
Adding process 8247 for gameID 9420
Adding process 8248 for gameID 9420
Adding process 8249 for gameID 9420
Adding process 8250 for gameID 9420
Adding process 8253 for gameID 9420
Adding process 8255 for gameID 9420
Adding process 8258 for gameID 9420
Adding process 8268 for gameID 9420
Adding process 8282 for gameID 9420
Adding process 8288 for gameID 9420
Adding process 8303 for gameID 9420
Adding process 8320 for gameID 9420
Game 9420 created interface STEAMAPPS_INTERFACE_VERSION003 / Apps
Game 9420 created interface STEAMAPPTICKET_INTERFACE_VERSION001 /
Game 9420 created interface STEAMREMOTESTORAGE_INTERFACE_VERSION002 / RemoteStorage
Game 9420 created interface STEAMUSERSTATS_INTERFACE_VERSION007 / UserStats
Game 9420 created interface SteamFriends005 / Friends
Game 9420 created interface SteamMatchMaking008 / Matchmaking
Game 9420 created interface SteamMatchMakingServers002 / MatchmakingServers
Game 9420 created interface SteamNetworking003 / Networking
Game 9420 created interface SteamUser013 / User
Game 9420 created interface SteamUser016 / User
Game 9420 created interface SteamUtils005 / Utils
Game 9420 method call count for IClientUserStats::GetNumberOfCurrentPlayers : 1
Game 9420 method call count for IClientUserStats::FindOrCreateLeaderboard : 119
Game 9420 method call count for IClientUserStats::RequestUserStats : 2
Game 9420 method call count for IClientAppManager::GetCurrentLanguage : 1
Game 9420 method call count for IClientUtils::RecordSteamInterfaceCreation : 12
Game 9420 method call count for IClientUtils::GetAppID : 16
Game 9420 method call count for IClientFriends::GetFriendGamePlayed : 1
Game 9420 method call count for IClientUser::BIsSubscribedApp : 1
Game 9420 method call count for IClientUser::GetAppOwnershipTicketExtendedData : 1
Game 9420 method call count for IClientUser::GetSteamID : 124
Game 9420 method call count for IClientUser::BLoggedOn : 2
Uploaded AppInterfaceStats to Steam
Removing process 8320 for gameID 9420
Removing process 8303 for gameID 9420
Removing process 8288 for gameID 9420
Removing process 8282 for gameID 9420
Removing process 8268 for gameID 9420
Removing process 8258 for gameID 9420
Removing process 8255 for gameID 9420
Removing process 8253 for gameID 9420
Removing process 8250 for gameID 9420
Removing process 8249 for gameID 9420
Removing process 8248 for gameID 9420
Removing process 8247 for gameID 9420
Removing process 8146 for gameID 9420
Removing process 8145 for gameID 9420
Removing process 8144 for gameID 9420
[2024-10-08 21:46:33] Shutdown
There are some errors in less /home/alex/.local/share/Steam/logs/cef_log.txt
egrep -i error /home/alex/.local/share/Steam/logs/cef_log.txt
[1008/214612.183617:ERROR:angle_platform_impl.cc(43)] Display.cpp:1021 (initialize): ANGLE Display::initialize error 0: Internal Vulkan error (-3):Initialization of an object could not be completed for implementation-specific reasons, in ../../third_party/angle/src/libANGLE/renderer/vulkan/RendererVk.cpp, initialize:1404.
[1008/214612.183676:ERROR:gl_display.cc(508)] EGL Driver message (Critical) eglInitialize: Internal Vulkan error (-3): Initialization of an object could not be completed for implementation-specific reasons, in ../../third_party/angle/src/libANGLE/renderer/vulkan/RendererVk.cpp, initialize:1404.
[1008/214612.183713:ERROR:gl_display.cc(932)] eglInitialize SwANGLE failed with error EGL_NOT_INITIALIZED
[1008/214612.183745:ERROR:gl_ozone_egl.cc(23)] GLDisplayEGL::Initialize failed.
[1008/214612.184520:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
[1008/214612.223361:ERROR:angle_platform_impl.cc(43)] Display.cpp:1021 (initialize): ANGLE Display::initialize error 0: Internal Vulkan error (-3):Initialization of an object could not be completed for implementation-specific reasons, in ../../third_party/angle/src/libANGLE/renderer/vulkan/RendererVk.cpp, initialize:1404.
[1008/214612.223442:ERROR:gl_display.cc(508)] EGL Driver message (Critical) eglInitialize: Internal Vulkan error (-3): Initialization of an object could not be completed for implementation-specific reasons, in ../../third_party/angle/src/libANGLE/renderer/vulkan/RendererVk.cpp, initialize:1404.
[1008/214612.223525:ERROR:gl_display.cc(932)] eglInitialize SwANGLE failed with error EGL_NOT_INITIALIZED
[1008/214612.223596:ERROR:gl_ozone_egl.cc(23)] GLDisplayEGL::Initialize failed.
[1008/214612.224334:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
[1008/214612.234510:ERROR:angle_platform_impl.cc(43)] Display.cpp:1021 (initialize): ANGLE Display::initialize error 0: Internal Vulkan error (-3):Initialization of an object could not be completed for implementation-specific reasons, in ../../third_party/angle/src/libANGLE/renderer/vulkan/RendererVk.cpp, initialize:1404.
[1008/214612.234599:ERROR:gl_display.cc(508)] EGL Driver message (Critical) eglInitialize: Internal Vulkan error (-3): Initialization of an object could not be completed for implementation-specific reasons, in ../../third_party/angle/src/libANGLE/renderer/vulkan/RendererVk.cpp, initialize:1404.
[1008/214612.234633:ERROR:gl_display.cc(932)] eglInitialize SwANGLE failed with error EGL_NOT_INITIALIZED
[1008/214612.234665:ERROR:gl_ozone_egl.cc(23)] GLDisplayEGL::Initialize failed.
[1008/214612.235559:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
[1008/214612.241382:ERROR:gpu_init.cc(523)] Passthrough is not supported, GL is disabled, ANGLE is
[1008/214631.812483:WARNING:connection.cc(41)] X error received. Request: Shm::PutImageRequest, Error: DrawableError{.sequence = 1412, .bad_value = 35651606, .minor_opcode = 3, .major_opcode = 130}
[1008/214631.829529:WARNING:connection.cc(41)] X error received. Request: Shm::PutImageRequest, Error: DrawableError{.sequence = 1417, .bad_value = 35651606, .minor_opcode = 3, .major_opcode = 130}
[1008/214631.829712:WARNING:connection.cc(41)] X error received. Request: Shm::PutImageRequest, Error: DrawableError{.sequence = 1418, .bad_value = 35651673, .minor_opcode = 3, .major_opcode = 130}
[1008/214631.846528:WARNING:connection.cc(41)] X error received. Request: Shm::PutImageRequest, Error: DrawableError{.sequence = 1419, .bad_value = 35651673, .minor_opcode = 3, .major_opcode = 130}
[1008/214631.846642:WARNING:connection.cc(41)] X error received. Request: SendEventRequest, Error: WindowError{.sequence = 2656, .bad_value = 35651604, .minor_opcode = 0, .major_opcode = 25}
[1008/214631.846837:WARNING:connection.cc(41)] X error received. Request: SendEventRequest, Error: WindowError{.sequence = 2658, .bad_value = 35651612, .minor_opcode = 0, .major_opcode = 25}
[1008/214631.846995:WARNING:connection.cc(41)] X error received. Request: SendEventRequest, Error: WindowError{.sequence = 2660, .bad_value = 35651616, .minor_opcode = 0, .major_opcode = 25}
[1008/214631.847150:WARNING:connection.cc(41)] X error received. Request: SendEventRequest, Error: WindowError{.sequence = 2662, .bad_value = 35651620, .minor_opcode = 0, .major_opcode = 25}
[1008/214631.847332:WARNING:connection.cc(41)] X error received. Request: SendEventRequest, Error: WindowError{.sequence = 2664, .bad_value = 35651624, .minor_opcode = 0, .major_opcode = 25}
[1008/214631.847487:WARNING:connection.cc(41)] X error received. Request: SendEventRequest, Error: WindowError{.sequence = 2666, .bad_value = 35651628, .minor_opcode = 0, .major_opcode = 25}
[1008/214631.847640:WARNING:connection.cc(41)] X error received. Request: SendEventRequest, Error: WindowError{.sequence = 2668, .bad_value = 35651632, .minor_opcode = 0, .major_opcode = 25}
[1008/214631.847783:WARNING:connection.cc(41)] X error received. Request: SendEventRequest, Error: WindowError{.sequence = 2670, .bad_value = 35651636, .minor_opcode = 0, .major_opcode = 25}
[1008/214631.847924:WARNING:connection.cc(41)] X error received. Request: SendEventRequest, Error: WindowError{.sequence = 2672, .bad_value = 35651640, .minor_opcode = 0, .major_opcode = 25}
[1008/214631.848070:WARNING:connection.cc(41)] X error received. Request: SendEventRequest, Error: WindowError{.sequence = 2674, .bad_value = 35651644, .minor_opcode = 0, .major_opcode = 25}
[1008/214631.848217:WARNING:connection.cc(41)] X error received. Request: SendEventRequest, Error: WindowError{.sequence = 2676, .bad_value = 35651648, .minor_opcode = 0, .major_opcode = 25}
[1008/214631.848378:WARNING:connection.cc(41)] X error received. Request: SendEventRequest, Error: WindowError{.sequence = 2678, .bad_value = 35651652, .minor_opcode = 0, .major_opcode = 25}
[1008/214631.848575:WARNING:connection.cc(41)] X error received. Request: SendEventRequest, Error: WindowError{.sequence = 2680, .bad_value = 35651671, .minor_opcode = 0, .major_opcode = 25}
[1008/214631.848910:WARNING:connection.cc(41)] X error received. Request: Shm::PutImageRequest, Error: DrawableError{.sequence = 1420, .bad_value = 35651622, .minor_opcode = 3, .major_opcode = 130}
FULL output of garuda-inxi
Kernel: 6.11.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=09a3a151-27d7-4b8b-803a-dbe0801b56dc rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
Type: Laptop System: TUXEDO product: TUXEDO Book XP1511 v: N/A
Mobo: NB01 model: PCX0DX serial: <superuser required>
uuid: <superuser required> UEFI: INSYDE v: 1.07.09RTR2 date: 10/23/2020
ID-1: BAT0 charge: 42.0 Wh (78.9%) condition: 53.2/70.7 Wh (75.2%)
volts: 11.9 min: 11.4 model: Notebook BAT type: Li-ion serial: <filter>
status: not charging
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xFC
Speed (MHz): avg: 800 min/max: 800/5000 scaling: driver: intel_pstate
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: CLEVO/KAPOK
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA TU106M [GeForce RTX 2070 Mobile / Max-Q Refresh]
vendor: CLEVO/KAPOK driver: nvidia v: 560.35.03
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: none empty: DP-1,DP-2,HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:1f14 class-ID: 0300
Device-3: Bison BisonCam NB Pro driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3 chip-ID: 5986:9102
class-ID: 0e02
compositor: kwin_wayland driver: X: loaded: intel,nvidia
unloaded: fbdev,modesetting,nouveau alternate: nv,vesa dri: i965
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.2.4-arch1.1
device-ID: 8086:9bc4 memory: 30.52 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.295 layers: 8 device: 0 type: integrated-gpu name: Intel
UHD Graphics (CML GT2) driver: mesa intel v: 24.2.4-arch1.1
device-ID: 8086:9bc4 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce RTX 2070 with Max-Q Design
driver: nvidia v: 560.35.03 device-ID: 10de:1f14
18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.4-arch1.1 (LLVM 18.1.8)
Device-1: Intel Comet Lake PCH cAVS vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl, snd_soc_avs,
snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: CLEVO/KAPOK
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
API: ALSA v: k6.11.2-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 42:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp66s0 state: down mac: <filter>
speed: 5 GT/s lanes: 1 bus-ID: 44:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp68s0 state: up mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0029
Local Storage: total: 1.82 TiB used: 26.96 GiB (1.4%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung
fw-rev: 2B2QEXM7 temp: 38.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
fw-rev: 2B2QEXM7 temp: 39.9 C scheme: GPT
used: 26.96 GiB (2.9%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:3
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.5 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 47.0 C pch: 63.0 C mobo: N/A
Memory: total: 64 GiB note: est. available: 62.5 GiB used: 5.8 GiB (9.3%)
Processes: 339 Power: uptime: 16m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.95 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1393 libs: 407 tools: octopi,paru Compilers:
gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.36
System install date: 2024-10-07
Last full system update: 2024-10-08
That’s the installed packages.
LC_ALL=C.UTF-8 pacman -Q|egrep -i 'wine|lut|proton|steam|vulkan|nvi'
freeglut 3.6.0-1
garuda-nvidia-config 2:1.1.6-1
garuda-nvidia-prime-config 2:1.1.6-1
lib32-freeglut 3.6.0-1
lib32-nvidia-utils 560.35.03-1
lib32-opencl-nvidia 560.35.03-1
lib32-vulkan-icd-loader 1.3.295-1
lib32-vulkan-intel 1:24.2.4-1
lib32-vulkan-mesa-layers 1:24.2.4-1
lib32-vulkan-radeon 1:24.2.4-1
lutris 0.5.17-6
mhwd-nvidia 560.35.03.5-1
mhwd-nvidia-390xx 390.143-1
mhwd-nvidia-470xx 470.94-1
nvidia-dkms 560.35.03-5
nvidia-prime 1.0-5
nvidia-settings 560.35.03-1
nvidia-utils 560.35.03-5
opencl-nvidia 560.35.03-5
steam 1.0.0.81-2
vulkan-headers 1:1.3.295-1
vulkan-swrast 1:24.2.4-1
vulkan-tools 1.3.269-1
wine 9.18-2
wine-gecko 2.47.4-2
wine-installer 5.0.3-2.4
wine-meta 1-6
wine-mono 9.3.0-1
wine-nine 0.9-1
wineasio 1.2.0-10
winetricks 20240105-1
That’s the os release.
cat /etc/os-release
File: /etc/os-release
NAME="Garuda Linux"
PRETTY_NAME="Garuda Linux"
ID=garuda
ID_LIKE=arch
BUILD_ID=rolling
ANSI_COLOR="38;2;23;147;209"
HOME_URL="https://garudalinux.org/"
DOCUMENTATION_URL="https://wiki.garudalinux.org/"
SUPPORT_URL="https://forum.garudalinux.org/"
BUG_REPORT_URL="https://gitlab.com/groups/garuda-linux/"
PRIVACY_POLICY_URL="https://terms.archlinux.org/docs/privacy-policy/"
LOGO=garudalinux
