G-Hyprland - LH Sidebar Thingy
I’ve been using Garuda Dr460nized for a few years now with great success. It has completely replaced my Windows PC.
I’ve recently moved onto Garuda Hyprland with a good result as well. So onto Garuda G-Hyprland. I’m 98% there with my own configs but I have one small question. My Desktop has a sidebar on the left, I don’t think its a Waybar and I can’t find any reference to it in Eww.
So, I want to remove it but how?
  Kernel: 6.9.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    root=UUID=049a7e57-694d-4436-984f-445a058e376f rw rootflags=subvol=@
  Desktop: Hyprland v: N/A with: waybar tools: avail: swayidle,swaylock
  Type: Desktop System: HP product: HP EliteDesk 800 G2 DM 35W v: N/A
    serial: <filter> Chassis: type: 15 serial: <filter>
  Mobo: HP model: 8055 v: KBC Version 05.39 serial: <filter>
    part-nu: L1W21AV uuid: 8aa92c8f-3fa1-11e6-9c43-bc0000160000 UEFI: HP
    v: N21 Ver. 02.61 date: 03/17/2023
  Info: model: Intel Core i5-6500T socket: U3E1 bits: 64 type: MCP
    arch: Skylake-S gen: core 6 level: v3 note: check built: 2015
    process: Intel 14nm family: 6 model-id: 0x5E (94) stepping: 3
    microcode: 0xF0
    desc: 1x6 MiB
  Speed (MHz): avg: 2474 high: 3100 min/max: 800/3100 base/boost: 2400/3100
    scaling: driver: intel_pstate governor: powersave volts: 1.0 V
    ext-clock: 100 MHz cores: 1: 3000 2: 3100 3: 800 4: 2997 bogomips: 19999
  Device-1: Intel HD Graphics 530 vendor: Hewlett-Packard driver: i915
    v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports:
    active: HDMI-A-1 empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:1912
  Display: unspecified server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.1
    compositor: Hyprland driver: X: loaded: modesetting
    alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: :1
  Monitor-1: HDMI-A-1 model: Dell S2721H serial: <filter> built: 2020
    res: 1920x1080 dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23")
    diag: 686mm (27") ratio: 16:9 modes: max: 1920x1080 min: 720x400
    vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
    alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a170 class-ID: 0403
  API: ALSA v: k6.9.9-zen1-1-zen status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.2.1 status: n/a (root, process) with:
    v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b7 class-ID: 0200
  IF-ID-1: nordlynx state: unknown speed: N/A duplex: N/A mac: N/A
  Local Storage: total: 119.24 GiB used: 10.36 GiB (8.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD7TB3Q-128G-1006
    size: 119.24 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 0306 scheme: GPT
  ID-1: / raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
    used: 10.36 GiB (8.7%) fs: btrfs block-size: 4096 B dev: /dev/sda2
    maj-min: 8:2
    used: 584 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
    maj-min: 8:2
  ID-4: /var/log raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
    maj-min: 8:2
  ID-5: /var/tmp raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
    maj-min: 8:2
  ID-1: swap-1 type: zram size: 7.05 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 39.0 C pch: 46.5 C mobo: N/A
  Memory: total: 8 GiB available: 7.05 GiB used: 1.66 GiB (23.5%)
    igpu: 512 MiB
  Processes: 218 Power: uptime: 2h 3m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 2.81 GiB services: upowerd Init: systemd
    v: 256 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 1290 libs: 387 tools: pacseek,paru Compilers:
    gcc: 14.1.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.26
    running-in: xfce4-terminal inxi: 3.3.35
  System install date:     2024-07-16
  Last full system update: 2024-07-17
It seems Kayo edited my post, but why and what change did you make?
Fixing the small typo :slight_smile:
The G(UM) part is made by the Garuda Hyprland Co-maintainer @Ankur ,
But I am sure it is somewhere in the
.config/gum_implementation/gum_files/brain/config/waybar_themes ...
:smiley:
sudo pacman -R nwg-dock-hyprland
.config/nwg-dock-hyprland/
:sweat_smile:
For anyone coming to this via a search after its closed -
Show/Hide nwg-dock	ALT + SHIFT + H
Also works :slight_smile:
