Hi all,
I downloaded and compiled the linux-cacule
(5.15 for native ntfs3
support) kernel from the AUR repo. Following the documentation here on the new ntfs3
mount option:
https://www.kernel.org/doc/html/latest/filesystems/ntfs3.html
You can specify the umask
(files and directories) or fmask
and dmask
separately. I have an NTFS
partition on one of my drives which is being mounted via UUID
in my /etc/fstab
file like so:
UUID=B29AC1289AC0EA45 /Windows8_OS ntfs3 ro,nosuid,nodev,relatime,nohidden,sys_immutable,acl,uhelper=udisks2,umask=0022,uid=1000,gid=1000,iocharset=utf8,user 0 0
You'll notice that my umask
specifies 0022, which should result in 0755 for directories and 0644 for files. However, when I run the mount
command, this is what my output shows:
/dev/sda5 on /Windows8_OS type ntfs3 (ro,nosuid,nodev,noexec,relatime,uid=1000,gid=1000,fmask=37777600022,dmask=37777600022,iocharset=utf8,sys_immutable,nohidden,acl,uhelper=udisks2,user)
What are these fmask
and dmask
values? Does it not matter since I'm mounting the partition as ro
I tried manually mounting another NTFS
partition from /dev/sda7
with the following command:
sudo mount -t ntfs3 -o rw,nosuid,nodev,relatime,nohidden,sys_immutable,acl,uhelper=udisks2,umask=0022,uid=1000,gid=1000,iocharset=utf8,user /dev/sda7 /home/user/test
and after it successfully mounted, I ran the mount
again and it displayed the same long number for fmask
and dmask
. I traversed into /home/user/test
and typed touch hi
and that worked just fine and the file perm was 644.
I even tried remounting but with umask=022
instead to see if that would have made a difference, but the subsequent mount
indicated the same long values. I then tried remounting again but instead of umask
, I specified fmask=022,dmask=022
but after it mounted, the mount
showed the same long integer. I tried googling for the string fmask=37777600022
but couldn't find anything.
Anyone have any insight into this?
EDIT: Here's my inxi -Faz
❯ inxi -Faz
System: Kernel: 5.15.1-1-cacule x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-cacule root=UUID=12979374-b0c5-4bc8-8f21-3b53bd02741b
systemd.unified_cgroup_hierarchy=1 loglevel=3 sysrq_always_enabled=1 intel_iommu=on iommu=pt
acpi_backlight=vendor delayacct
Desktop: KDE Plasma 5.23.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: LENOVO product: 20175 v: Lenovo IdeaPad Yoga 13 serial: <filter> Chassis:
type: 10 v: Lenovo IdeaPad Yoga 13 serial: <filter>
Mobo: LENOVO model: INVALID v: 31900003WIN8 STD MLT serial: <filter> UEFI: LENOVO v: 66CN55WW
date: 02/28/2013
Battery: ID-1: BAT1 charge: 38.4 Wh (100.0%) condition: 38.4/49.3 Wh (78.0%) volts: 16.2 min: 14.8
model: Lenovo IdeaPad Mocca2 type: Unknown serial: <filter> status: Full
CPU: Info: Dual Core model: Intel Core i7-3537U bits: 64 type: MT MCP arch: Ivy Bridge family: 6
model-id: 3A (58) stepping: 9 microcode: 21 cache: L2: 4 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19963
Speed: 1896 MHz min/max: 800/1900 MHz Core speeds (MHz): 1: 1896 2: 1895 3: 1862 4: 1882
Graphics: Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: Chicony Lenovo EasyCamera type: USB driver: uvcvideo bus-ID: 2-1.7:4 chip-ID: 04f2:b322
class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel unloaded: modesetting
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4") s-diag: 485mm (19.1")
Monitor-1: LVDS1 res: 1600x900 hz: 60 dpi: 140 size: 290x170mm (11.4x6.7") diag: 336mm (13.2")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 21.2.4 compat-v: 3.0
direct render: Yes
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20 class-ID: 0403
Device-2: DisplayLink Kensington SD4000 USB Dock type: USB driver: cdc_ncm,snd-usb-audio
bus-ID: 4-2.1:3 chip-ID: 17e9:4344 class-ID: 0a00 serial: <filter>
Sound Server-1: ALSA v: k5.15.1-1-cacule running: yes
Network: Message: No device data found.
IF-ID-1: br-1a91b0dd2206 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-3: enp0s20u2u1i5 state: up speed: 100 Mbps duplex: half mac: <filter>
IF-ID-4: veth572b238 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-5: veth7f8e138 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-6: vetha9407d4 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-7: vethe2f0fbe state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-8: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-9: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-10: wlp0s26u1u4i2 state: down mac: <filter>
Bluetooth: Device-1: Realtek RTL8723AU 802.11n WLAN Adapter type: USB driver: btusb,rtl8723au bus-ID: 1-1.4:4
chip-ID: 0bda:1724 class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block:
Drives: Local Storage: total: 1.14 TiB used: 458.95 GiB (39.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZMTD256HAGM-000L1 size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s type: SSD serial: <filter> rev: 2L0Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital model: WD My Passport 0820
size: 931.48 GiB block-size: physical: 512 B logical: 512 B type: N/A serial: <filter> rev: 1007
Partition: ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 263.29 GiB (28.3%) fs: btrfs
dev: /dev/sdb2 maj-min: 8:18
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 562 KiB (0.2%) fs: vfat
dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 263.29 GiB (28.3%) fs: btrfs
ID-4: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 263.29 GiB (28.3%) fs: btrfs
ID-5: /var/tmp raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 263.29 GiB (28.3%) fs: btrfs
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 58.0 C mobo: N/A
Info: Processes: 289 Uptime: 3h 49m wakeups: 1 Memory: 7.64 GiB used: 4.28 GiB (55.9%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1868 pacman: 1858 lib: 481
flatpak: 10 Shell: Zsh v: 5.8 running-in: alacritty inxi: 3.3.08
