Frozen / unmoveable window with telegram-desktop
Hello,
I'm using Telegram-Desktop 4.8.1-2 from the official repositories and Gardua Gnome. Any time that I move the window of Telegram, resize, snap it, etc. that application freezes, and I cannot even click other applications which are not Telegram. Everything in other GNOME windows becomes unclickable. Interestingly, I can still access Dash2Panel and I'm able to kill Telegram this was, and then everything in GNOME returns to normal. I've tried updating all packages, but this didn't help.
╭─s76v2@s76v2 in ~
 ╰─λ garuda-inxi
  Kernel: 6.3.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=542d3ca9-5005-47ad-85d9-21e20ee155e6 rw rootflags=subvol=@
    loglevel=3 ibt=off
  Desktop: GNOME v: 44.1 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.1
  Type: Desktop Mobo: System76 model: Thelio Mira v: thelio-mira-r2
    serial: <superuser required> UEFI: American Megatrends v: 4403
    date: 04/27/2022
  Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 2368 high: 3700 min/max: 2200/4950 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3700 2: 2200
    3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2467 9: 2200 10: 2875 11: 2200
    12: 2200 13: 2200 14: 2200 15: 2200 16: 2200 17: 2200 18: 2200 19: 2378
    20: 2200 21: 2200 22: 2874 23: 2279 24: 2871 bogomips: 177262
  Device-1: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate] vendor: PNY
    status: current (as of 2023-05) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 0a:00.0
    chip-ID: 10de:2216 class-ID: 0300
  Device-2: HD WEBCAM driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 1d6c:0103
    compositor: gnome-shell driver: X: loaded: nvidia unloaded: modesetting
    alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: :1 screens: 1
  Screen-1: 0 s-res: 6000x1440 s-dpi: 96 s-size: 1588x381mm (62.52x15.00")
    s-diag: 1633mm (64.29")
  Monitor-1: DP-0 pos: bottom-l res: 2560x1080 hz: 60 dpi: 79
    size: 820x350mm (32.28x13.78") diag: 892mm (35.1") modes: N/A
  Monitor-2: HDMI-0 pos: primary,top-right res: 3440x1440 hz: 50 dpi: 109
    size: 800x335mm (31.5x13.19") diag: 867mm (34.15") modes: N/A
    missing.
  Device-1: NVIDIA GA102 High Definition Audio vendor: PNY
    link-max: gen: 4 speed: 16 GT/s bus-ID: 0a:00.1 chip-ID: 10de:1aef
  Device-3: HD WEBCAM driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
  Device-4: Razer USA Seiren Mini driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-4:4
    chip-ID: 1532:0531 class-ID: 0300 serial: <filter>
  API: ALSA v: k6.3.2-zen1-1-zen status: kernel-api with: aoss
  Device-1: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 14c3:0608
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0
  Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 06:00.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 0e8d:0608
  Local Storage: total: 495.04 GiB used: 266.77 GiB (53.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 500GB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QGXA7 temp: 37.9 C
  ID-2: /dev/sda maj-min: 8:0 model: USB 3.0 USB Flash Drive size: 29.28 GiB
    block-size: physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s
    lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter> fw-rev: 1.00
    scheme: MBR
    used: 266.77 GiB (57.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 592 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 43.8 C mobo: N/A gpu: nvidia temp: 45 C
  Processes: 448 Uptime: 2h 51m wakeups: 0 Memory: available: 31.26 GiB
  used: 9.05 GiB (29.0%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1719
  libs: 526 tools: pamac,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
  running-in: gnome-terminal inxi: 3.3.27
  System install date:     2022-07-03
  Last full system update: 2023-05-16 ↻
Did you search about?
You did not mention whether the problem persists with different kernels, say the LTS?
I could not find any incidence of similar issues in the Telegram forums.
I have not tried with various kernels… I can’t imagine kernels affect a specific app’s window? But I’ll give it a try.
I've now tried with zen kernel 6.3.2, linux-lts 6.1.29, and linux-mainline 6.4-rc2.
None have an effect. This is clearly a Gnome+application issue, not a kernel issue.
