Frozen System on my AMD Laptop
Hello Garuda users.
I try several garuda editons and several Arch distro without solving my issue: when whatching video on internet my system freezing and the only way is force restart the system, (no mouse, no tuochpad, video stop and sound too) I try to see log but restarting the log is from the new session so I'm unable to understand why it happens (I have 1 freeze every 1-2 hour so I can't see a film without needing 2 restarts). I try garuda default kernel. amd kernel, arch default, I try not using powersave tweaks, using powersave ... nothing helps.
Same issue with OpenSuse that I try but less frequently (one freeze in a day of use).
Garuda is my prefered system so if you can help me stay with my deloved garuda ... thanks
  Kernel: 6.1.10-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=5acefd49-dd62-4bbe-9848-d93639d1f154 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: HUAWEI product: KPL-W0X v: M1D
  Mobo: HUAWEI model: KPL-W0X-PCB v: M1D serial: <superuser required>
    UEFI: HUAWEI v: 1.24 date: 04/11/2022
  ID-1: BAT1 charge: 53.4 Wh (99.3%) condition: 53.8/56.3 Wh (95.6%)
    volts: 7.9 min: 7.6 model: DYNAPACK HB4593R1ECW type: Li-ion
    serial: <filter> status: not charging cycles: 113
  Info: model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64
    type: MT MCP arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
    family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x8101007
    L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
    desc: 1x4 MiB
  Speed (MHz): avg: 1600 min/max: 1600/2000 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 1600 2: 1600 3: 1600
    4: 1600 5: 1600 6: 1600 7: 1600 8: 1600 bogomips: 31949
  Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series]
    vendor: Huawei driver: amdgpu v: kernel arch: GCN-5 code: Vega
    ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 02:00.0
    chip-ID: 1002:15dd class-ID: 0300 temp: 31.0 C
  Device-2: Quanta hm1091_techfront type: USB driver: uvcvideo bus-ID: 3-1:2
    chip-ID: 0408:1020 class-ID: 0e02
  Display: x11 server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.7
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x14d4 built: 2016
    res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81")
    diag: 354mm (13.9") ratio: 16:9 modes: max: 1920x1080 min: 640x480
    missing.
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Huawei
    bus-ID: 02:00.1 chip-ID: 1002:15de class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Huawei
    driver: snd_pci_acp3x v: kernel
    alternate: snd_rn_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_rpl_pci_acp6x,snd_pci_ps,snd_sof_amd_renoir,snd_sof_amd_rembrandt
    pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 02:00.5 chip-ID: 1022:15e2
    class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Huawei driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 02:00.6
  Sound API: ALSA v: k6.1.10-arch1-1 running: yes
  Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:24fd class-ID: 0280
    bus-ID: 1-2:2 chip-ID: 8087:0a2b class-ID: e001
    address: <filter>
  Local Storage: total: 238.47 GiB used: 35.77 GiB (15.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: LITE-ON model: CV8-8E256
    type: SSD serial: <filter> rev: 402 scheme: GPT
  ID-1: / raw-size: 22.24 GiB size: 22.24 GiB (100.00%) used: 6.7 GiB (30.1%)
    fs: btrfs dev: /dev/sda6 maj-min: 8:6
    used: 42.5 MiB (44.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 22.24 GiB size: 22.24 GiB (100.00%)
    used: 6.7 GiB (30.1%) fs: btrfs dev: /dev/sda6 maj-min: 8:6
  ID-4: /var/log raw-size: 22.24 GiB size: 22.24 GiB (100.00%)
  ID-5: /var/tmp raw-size: 22.24 GiB size: 22.24 GiB (100.00%)
  ID-1: swap-1 type: zram size: 6.68 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 32.1 C mobo: N/A gpu: amdgpu temp: 32.0 C
  Processes: 244 Uptime: 21m wakeups: 1 Memory: 6.68 GiB
  used: 1.86 GiB (27.9%) Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: N/A Packages: pm: pacman pkgs: 1014
  libs: 296 tools: paru Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.25
Garuda (2.6.14-1):
  System install date:     2023-02-05
  Last full system update: 2023-02-11
  Failed units:            auto-cpufreq.service
As a suggestion I would run btop in the foreground while playing a video and see what it shows when it freezes.
It might give you a indication of what program is causing you problem (ie memory leak,overheating)
You should get to the log using journalctl. IIRC journalctl -b -1 should give you the log from the previous boot. See if there is something wrong on the end of that log.
Also check the timestamps, it should be the right log, but I'm not 100% right now. :grin: (-b means "boot" and -1 should be the previous boot, ie after a crash the one that crashed in the end)
