I have not made any changes to the Install of Garuda. I keep having an issue where I can move the mouse on the login screen but it wont let me click anything. This seems to happen after I wake the computer the next day.
Here are my specs:
OS: Garuda Linux
Host: M17xR4 A15
Kernel: 5.14.14-zen1-1-zen
Uptime: 32 mins
Packages: 1666 (pacman)
Shell: bash
DE: Plasma 5.23.1
WM: KWin
WM Theme: Sweet-Dark
Terminal: konsole
CPU: Intel i7-3630QM (8) @ 3.4GHz
GPU: Intel 3rd Gen Core processor Graphics Controller
GPU: NVIDIA GeForce GTX 675M
Memory: 2.82GiB / 15.51GiB
chaotic-aur/garuda-common-settings 2.6.4-2 -- /usr/bin/garuda-inxi
chaotic-aur/garuda-common-settings-git 2.6.4.r0.gef5d7f4-1 -- /usr/bin/garuda-inxi
SGS
July 7, 2022, 1:46pm
2
Please Edit your post and give us the complete
Updated the post with the information, sorry if its not right, I am still new to Linux.
garuda-inxi is a command.
Just type garuda-inxi
SGS
July 7, 2022, 1:56pm
5
Hello Garuda users.
Refusing to post the output of the required "garuda-inxi" on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Before opening a new help request, please search the Arch and Garuda Wiki's, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum's search engine and on the web. For in depth information on how to search for answers to Linux issues effectively read the tips on the Garuda Wiki:
filo
July 7, 2022, 1:57pm
6
You should provide the output of that command.
But I see your system is terribly out-dated
so garuda-inxi didn’t even exist at that time.
First of all try:
update
currently also garuda-update (I don’t remember at that time)
I get this error when I try to update:
WARNING: failed to rate http(s) download (https://archlinux.thaller.ws/community/os/x86_
64/community.db): Download timed out after 5 second(s).
Failed to update mirrorlist
filo
July 7, 2022, 2:02pm
9
In case of further error, I'd go for a:
update remote fix
in the hope it existed at that time.
If not, you could try:
sudo bash -c ". <(wget -qO- https://gitlab.com/garuda-linux/themes-and-settings/settings/garuda-common-settings/-/snippets/2147440/raw/main/remote-update)"
I guess if I would have tried it multiple times, it would have worked. Its updating a lot right now. It is on 18/269. Guess next time I will try it more than once. Thank you for your help on this. I will come back one the updates have finished if the frozen login screen issue persists.
filo
July 7, 2022, 2:29pm
11
That's not necessarily the root cause, but something to do anyway.
This is a rolling release, you should try to update at least weekly or so.
Don't forget to provide you garuda-inxi after updating. This could give other hints.
There is a lot of information on the inxi, do I need to paste all of it?
SGS
July 7, 2022, 3:03pm
13
Yes, otherwise something else would be written here.
Kernel: 5.14.14-zen1-1-zen arch: x86_64 bits: 64 c
ompiler: gcc v: 11.1.0
root=UUID=26dbe17b-c245-43ba-95e4-300eaa30b288 rw rootflags=subvol=@
Console: pty pts/0 wm: kwin_x11
DM: SDDM D
istro: Garuda Linux
///////Machine:
Type: Portable System: Alienware product: M17xR4 v: A15 serial:
Mobo: Alienware model: M17xR4 v: A15 serial: UEFI: Alienware
v: A15 date: 05/28/2018
//////Battery:
ID-1: BAT1 charge: 44.3 Wh (100.0%) condition: 44.3/93.2 Wh (47.5%)
volts: 12.6 min: 11.1 model: SIMPLO PABAS0241231 type: Li-ion
serial: status: full
//////CPU:
Info: model: Intel Core i7-3630QM socket: rPGA988B (U3E1) note: check
bits: 64 type: MT MCP arch: Ivy Bridge gen: core 3 built: 2012-15
process: Intel 22nm family: 6 model-id: 0x3A (58) stepping: 9
microcode: 0x21
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2480 high: 3296 min/max: 1200/3400
base/boost: 2400/4000 scaling: driver: intel_cpufreq governor: performance
volts: 0.9 V ext-clock: 100 MHz cores: 1: 1495 2: 3215 3: 1322 4: 3255
5: 1982 6: 3261 7: 2015 8: 3296 bogomips: 38312
///////Vulnerabilities:
Type: l1tf
//////Graphics:
Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915
v: kernel arch: Gen7 process: Intel 22nm built: 2012-13 ports:
active: VGA-1 off: LVDS-1
empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:0166 class-ID: 0300
Device-2: NVIDIA GF114M [GeForce GTX 675M] vendor: Dell driver: nouveau
v: kernel non-free: 390.xx+ status: legacy-active (EOL~late 2022)
arch: Fermi process: 40/28nm built: 2010-16 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 ports: active: none empty: DP-4 bus-ID: 01:00.0
chip-ID: 10de:1212 class-ID: 0300
Device-3: Suyin Laptop_Integrated_Webcam_FHD type: USB driver: uvcvideo
bus-ID: 1-1.5:4 chip-ID: 064e:8127 class-ID: 0e02
Display: x11 server: X.Org v: 1.20.13 with: Xwayland v: 22.1.2
compositor: kwin_x11 driver: X: loaded: intel,nouveau unloaded: modesetting
alternate: fbdev,nv,vesa gpu: i915 display-ID: :0 screens: 1
Monitor-1: LVDS-1 mapped: LVDS1 note: disabled model: LG Display 0x0357
built: 2011 res: N/A dpi: 106 gamma: 1.2 size: 382x215mm (15.04x8.46")
diag: 438mm (17.3") ratio: 16:9 modes: 1600x900
Monitor-2: VGA-1 mapped: VGA1 pos: primary model: Dell P2719H
serial: built: 2019 res: 1920x1080 hz: 60 dpi: 81 gamma: 1.2
size: 600x340mm (23.62x13.39") diag: 686mm (27") ratio: 16:9 modes:
OpenGL: renderer: Mesa Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 22.1.3 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
Device-2: NVIDIA GF114 HDMI Audio vendor: Dell driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:0e0c class-ID: 0403
Sound Server-1: ALSA v: k5.14.14-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.54 running: yes
///////Network:
Device-1: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet vendor: Dell
driver: atl1c v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000
bus-ID: 07:00.0 chip-ID: 1969:1083 class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac:
Device-2: Intel Centrino Wireless-N 2230 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.0 chip-ID: 8086:0887
IF: wlp8s0 state: up mac:
IF-ID-1: anbox0 state: down mac:
////////Bluetooth:
Device-1: Intel Centrino Bluetooth Wireless Transceiver type: USB
driver: btusb v: 0.8 bus-ID: 2-1.5:3 chip-ID: 8087:07da class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address:
v: 3.0 port: 4060 bus-ID: 00:1f.2 chip-ID: 8086:282a rev: N/A
class-ID: 0104
///////Drives:
Local Storage: total: 465.76 GiB used: 61.7 GiB (13.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST9500423AS
family: Momentus 7200.5 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B sata: 2.6 speed: 3.0 Gb/s type: HDD rpm: 7200
serial: rev: DEM1 temp: 51 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 189d 5h cycles: 2668
read: 1.22 TiB written: 1.4 TiB Old-Age: g-sense error rate: 123 Pre-Fail:
attribute: Spin_Retry_Count value: 100 worst: 100 threshold: 97
////////Partition:
ID-1: / raw-size: 465.5 GiB size: 465.5 GiB (100.00%)
used: 61.7 GiB (13.3%) fs: btrfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
used: 562 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 465.5 GiB size: 465.5 GiB (100.00%)
maj-min: 8:2
ID-4: /var/log raw-size: 465.5 GiB size: 465.5 GiB (100.00%)
maj-min: 8:2
ID-5: /var/tmp raw-size: 465.5 GiB size: 465.5 GiB (100.00%)
maj-min: 8:2
ID-1: swap-1 type: zram size: 15.51 GiB used: 87.2 MiB (0.5%)
System Temperatures: cpu: 62.0 C mobo: N/A gpu: nouveau temp: 47.0 C
Processes: 277 Uptime: 1h 48m wakeups: 2 Memory: 15.51 GiB
used: 3.49 GiB (22.5%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: pacman: 1800
lib: 524 Shell: garuda-inxi (sudo) default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.19
Garuda (2.6.4-2):
System install date: 2021-08-08
Last full system update: 2022-07-07 ↻
Snapshots: Timeshift
SGS
July 7, 2022, 3:38pm
15
Please, it means your first post and check the ~ I edit for you.
filo
July 7, 2022, 4:20pm
16
And remember to reboot! You had important changes, so this is needed for them to be effective.
filo
July 7, 2022, 8:13pm
17
Next time it happens, please check if you can:
switch to another tty with Ctrl+Alt+F2
restart sddm with sudo systemctl restart sddm
go back to your login with Ctrl+Alt+F1
system
Closed
July 23, 2022, 5:32am
21
