Kernel: 6.11.8-arch1-2 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=0c56ec49-20ad-4aa0-a88b-55b47e733bc9 rw rootflags=subvol=@
quiet rd.luks.uuid=d79b9435-2941-4ab1-b7b1-6436232809f7
rd.luks.uuid=49c27010-0fe7-452f-b43e-2b305ff69240
resume=/dev/mapper/luks-49c27010-0fe7-452f-b43e-2b305ff69240 loglevel=3
Desktop: KDE Plasma v: 6.2.3 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Desktop Mobo: ASRock model: 970M Pro3 serial: <superuser required>
uuid: <superuser required> UEFI-[Legacy]: American Megatrends v: P1.60
date: 06/17/2016
Info: model: AMD FX-8350 bits: 64 type: MCP arch: Piledriver level: v2
built: 2012-13 process: GF 32nm family: 0x15 (21) model-id: 2 stepping: 0
microcode: 0x6000852
Topology: cpus: 1x dies: 1 clusters: 1 cores: 8 smt: <unsupported> cache:
L1: 384 KiB desc: d-8x16 KiB; i-4x64 KiB L2: 8 MiB desc: 4x2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 4000 min/max: 1400/4000 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 4000 2: 4000 3: 4000
4: 4000 5: 4000 6: 4000 7: 4000 8: 4000 bogomips: 63881
Device-1: Advanced Micro Devices [AMD/ATI] Baffin [Radeon RX 460/560D / Pro
450/455/460/555/555X/560/560X] vendor: Tul / PowerColor driver: amdgpu
v: kernel arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20
pcie: gen: 2 speed: 5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s ports:
active: HDMI-A-1 empty: DP-1,DVI-D-1 bus-ID: 01:00.0 chip-ID: 1002:67ef
class-ID: 0300 temp: 38.0 C
gpu: amdgpu display-ID: 0
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.7-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 560 Series (radeonsi
polaris11 LLVM 18.1.8 DRM 3.59 6.11.8-arch1-2) device-ID: 1002:67ef
memory: 3.91 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.295 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 560 Series (RADV POLARIS11) driver: mesa radv v: 24.2.7-arch1.1
device-ID: 1002:67ef surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.2.7-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
Device-1: Advanced Micro Devices [AMD/ATI] SBx00 Azalia vendor: ASRock
driver: snd_hda_intel v: kernel bus-ID: 00:14.2 chip-ID: 1002:4383
Device-2: Advanced Micro Devices [AMD/ATI] Baffin HDMI/DP Audio [Radeon
RX 550 640SP / 560/560X] vendor: Tul / PowerColor driver: snd_hda_intel
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 1002:aae0 class-ID: 0403
API: ALSA v: k6.11.8-arch1-2 status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
Device-1: Broadcom BCM4360 802.11ac Dual Band Wireless Network Adapter
bus-ID: 04:00.0 chip-ID: 14e4:43a0 class-ID: 0280
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: TP-Link TP%TP) UB500 Adapter driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:4 chip-ID: 2357:0604
Local Storage: total: 931.51 GiB used: 792.97 GiB (85.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
tech: SSD serial: <filter> fw-rev: 3B6Q scheme: MBR
ID-1: / raw-size: 922.71 GiB size: 922.71 GiB (100.00%)
used: 792.97 GiB (85.9%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
mapped: luks-d79b9435-2941-4ab1-b7b1-6436232809f7
ID-2: /home raw-size: 922.71 GiB size: 922.71 GiB (100.00%)
ID-3: /var/log raw-size: 922.71 GiB size: 922.71 GiB (100.00%)
ID-4: /var/tmp raw-size: 922.71 GiB size: 922.71 GiB (100.00%)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-0 maj-min: 254:0
mapped: luks-49c27010-0fe7-452f-b43e-2b305ff69240
ID-2: swap-2 type: zram size: 7.73 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 25.4 C mobo: N/A gpu: amdgpu temp: 39.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1113
Memory: total: 8 GiB available: 7.73 GiB used: 3.4 GiB (44.0%)
Processes: 288 Power: uptime: 6m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.08 GiB services: org_kde_powerdevil,
Packages: 2119 pm: pacman pkgs: 2111 libs: 537 tools: octopi,paru,yay
pm: flatpak pkgs: 8 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.36
System install date: 2023-11-27
Last full system update: 2024-11-16
Hello.
After doing a system update last night, it appears that Garuda no longer detects the front audio of my computer. The only audio device that is now detected is the hdmi audio.
Here is a screenshot:
Any idea what might be wrong? Thanks.
