From r2.garudalinux.org : Recv failure: Connection reset by peer
hello guys
im having problem with the new update " raptor " 23-3-5" it keeps giving every time im trying to update the system , " from r2.garudalinux.org : Recv failure: Connection reset by peer "
╭─[email protected] in ~
╰─λ update
[sudo] password for krampus:
garuda is up to date
core is up to date
extra                                1744.7 KiB  1829 KiB/s 00:01 [------------------------------------] 100%
community                               7.3 MiB  6.37 MiB/s 00:01 [------------------------------------] 100%
multilib is up to date
chaotic-aur                             2.4 MiB  2042 KiB/s 00:01 [------------------------------------] 100%
Packages (1) garuda-update-4.1.0-1
Total Installed Size:  0.02 MiB
Net Upgrade Size:      0.00 MiB
:: Retrieving packages...
garuda-update-4.1.0-1-any is up to date
error: failed retrieving file 'garuda-update-4.1.0-1-any.pkg.tar.zst.sig' from r2.garudalinux.org : Recv failure: Connection reset by peer
warning: failed to retrieve some files
error: failed to commit transaction (download library error)
my garuda-inxi
╭─[email protected] in ~ as 🧙 took 5s
[🔴] × garuda-inxi
Kernel: 6.2.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=141ae163-7acf-4515-9a1d-7a9881ac440f rw [email protected]
Desktop: KDE Plasma v: 5.27.2 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: B450M DS3H WIFI v: N/A
Mobo: Gigabyte model: B450M DS3H WIFI-CF v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F63b
date: 09/06/2021
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3803 high: 4274 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4265 2: 3600
3: 4037 4: 3600 5: 3600 6: 3591 7: 3600 8: 3718 9: 4246 10: 4269 11: 3600
12: 3600 13: 3600 14: 4274 15: 3653 16: 3600 bogomips: 114991
Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: ASUSTeK driver: nouveau
v: kernel non-free: 525.xx+ status: current (as of 2023-02) arch: Pascal
code: GP10x process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-2
empty: DP-1,DP-3,HDMI-A-1 bus-ID: 09:00.0 chip-ID: 10de:1b06
class-ID: 0300 temp: 42.0 C
compositor: kwin_x11 driver: X: loaded: nouveau unloaded: modesetting
alternate: fbdev,nv,vesa dri: nouveau gpu: nouveau display-ID: :0
Monitor-1: DP-2 model: BenQ ZOWIE XL LCD serial: <filter> built: 2021
res: 1920x1080 dpi: 92 gamma: 1.2 size: 531x299mm (20.91x11.77")
diag: 609mm (24") ratio: 16:9 modes: max: 1920x1080 min: 720x400
API: OpenGL v: 4.3 Mesa 22.3.6 renderer: NV132 direct-render: Yes
Device-1: NVIDIA GP102 HDMI Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 09:00.1 chip-ID: 10de:10ef class-ID: 0403
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound API: ALSA v: k6.2.2-zen1-1-zen running: yes
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 2.05 TiB used: 8.38 GiB (0.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Lexar model: 256GB SSD
type: SSD serial: <filter> rev: 117H scheme: MBR
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 8.38 GiB (0.4%)
used: 8.38 GiB (0.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 31.28 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 48.1 C mobo: 35.0 C gpu: nouveau temp: 42.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 1016
Processes: 326 Uptime: 12m wakeups: 0 Memory: 31.28 GiB
used: 2.19 GiB (7.0%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1782
libs: 512 tools: octopi,paru Shell: fish v: 3.6.0 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.25
Garuda (2.6.15-1):
System install date:     2023-03-10
Last full system update: 2023-03-10
Is partially upgraded:   Yes
Post your /etc/pacman.conf and /etc/pacman.d/chaotic-mirrorlist
my etc/pacman.conf
# /etc/pacman.conf
# See the pacman.conf(5) manpage for option and repository directives
# GENERAL OPTIONS
[options]
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir     = /
#DBPath      = /var/lib/pacman/
CacheDir = /var/cache/pacman/pkg/
#LogFile     = /var/log/pacman.log
#GPGDir      = /etc/pacman.d/gnupg/
#HookDir     = /etc/pacman.d/hooks/
HoldPkg     = pacman glibc
#XferCommand = /usr/bin/curl -L -C - -f -o %o %u
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
#CleanMethod = KeepInstalled
Architecture = auto
# Pacman won't upgrade packages listed in IgnorePkg and members of IgnoreGroup
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
ParallelDownloads = 5
# By default, pacman accepts packages signed by keys that its local keyring
# trusts (see pacman-key and its man page), as well as unsigned packages.
SigLevel    = Required DatabaseOptional
LocalFileSigLevel = Optional
#RemoteFileSigLevel = Required
# NOTE: You must run `pacman-key --init` before first using pacman; the local
# keyring can then be populated with the keys of all official Arch Linux
# packagers with `pacman-key --populate archlinux`.
# REPOSITORIES
#   - can be defined here or included from another file
#   - pacman will search repositories in the order defined here
#   - local/custom mirrors can be added here or in separate files
#   - repositories listed first will take precedence when packages
#     have identical names, regardless of version number
#   - URLs will have $repo replaced by the name of the current repo
#   - URLs will have $arch replaced by the name of the architecture
# Repository entries are of the format:
#       [repo-name]
#       Server = ServerName
#       Include = IncludePath
# The header [repo-name] is crucial - it must be present and
# uncommented to enable the repo.
[garuda]
Include = /etc/pacman.d/chaotic-mirrorlist
[core]
Include = /etc/pacman.d/mirrorlist
[extra]
[community]
[multilib]
[chaotic-aur]
# An example of a custom package repository.  See the pacman manpage for
# tips on creating your own repositories.
#[custom]
#SigLevel = Optional TrustAll
#Server = file:///home/custompkgs
my etc/pacman.d/chaotic-mirrorlist
## Special CDN mirror (delayed syncing, expect some (safe to ignore) amount of 404s)
# Globally
# * By: Garuda Linux donators, hosted on Cloudflare R2
Server = https://cdn-mirror.chaotic.cx/$repo/$arch
# Automatic per-country routing of the mirrors below.
Server = https://geo-mirror.chaotic.cx/$repo/$arch
## Regular Syncthing mirrors (close to instant syncing)
# Brazil
# * By: Universidade Federal de São Carlos (São Carlos)
Server = https://br-mirror.chaotic.cx/$repo/$arch
# * By: Alisson <t.me/alissonlauffer> (São Paulo)
Server = https://br-2-mirror.chaotic.cx/$repo/$arch
# Bulgaria
# * By: Sudo Man <github.com/sakrayaami>
Server = https://bg-mirror.chaotic.cx/$repo/$arch
# Canada
# * By freebird54 (Toronto)
Server = https://ca-mirror.chaotic.cx/$repo/$arch
# France
# * By: IRC-Nerds <irc-nerds.net>
Server = https://fr-1-mirror.chaotic.cx/$repo/$arch
# * By: Snowy <github.com/Gontier-Julien>
Server = https://fr-2-mirror.chaotic.cx/$repo/$arch
# Germany
# * By: Nico <dr460nf1r3.org>
Server = https://de-mirror.chaotic.cx/$repo/$arch
# * By: ParanoidBangL
Server = https://de-2-mirror.chaotic.cx/$repo/$arch
# * By: itsTyrion
Server = https://de-3-mirror.chaotic.cx/$repo/$arch
# * By: redgloboli
Server = https://de-4-mirror.chaotic.cx/$repo/$arch
# Greece
# * By: vmmaniac <github.com/vmmaniac>
Server = https://gr-mirror.chaotic.cx/$repo/$arch
# India
# * By Naman (Kaithal)
Server = https://in-mirror.chaotic.cx/$repo/$arch
# * By Albony <https://albony.xyz/>
Server = https://in-2-mirror.chaotic.cx/$repo/$arch
# * By: BRAVO68DEV <https://www.itsmebravo.dev/>
Server = https://in-3-mirror.chaotic.cx/$repo/$arch
# Korea
# * By: <t.me/silent_heigou> (Seoul)
Server = https://kr-mirror.chaotic.cx/$repo/$arch
# Spain
# * By: JKANetwork
Server = https://es-mirror.chaotic.cx/$repo/$arch
# * By: Ícar <t.me/IcarNS>
Server = https://es-2-mirror.chaotic.cx/$repo/$arch
# United Arab Emirates
# * By: ayulauffer <t.me/ayulauffer>
Server = https://ae-mirror.chaotic.cx/$repo/$arch
Server = https://ae-2-mirror.chaotic.cx/$repo/$arch
# United States
Server = https://us-fl-mirror.chaotic.cx/$repo/$arch
# Michigan
# * By: Technetium1 <github.com/Technetium1>
Server = https://us-mi-mirror.chaotic.cx/$repo/$arch
# New York
# * By: Eduard <t.me/edu4rdshl>
Server = https://us-ny-mirror.chaotic.cx/$repo/$arch
# Texas
# * By: xstefen <t.me/xstefen>
Server = https://us-tx-mirror.chaotic.cx/$repo/$arch
# Utah
# * By: ash <t.me/the_ashh>
Server = https://us-ut-mirror.chaotic.cx/$repo/$arch
# Virginia
# * By: Zoe
Server = https://us-va-mirror.chaotic.cx/$repo/$arch
# IPFS mirror - for instructions on how to use it consult the projects repo (https://github.com/RubenKelevra/pacman.store)
# * By: RubenKelevra / pacman.store
# Server = http://chaotic-aur.pkg.pacman.store.ipns.localhost:8080/$arch
Possibly related issue: Error: failed retrieving file when trying to install bottles
I used to have old guruda-linux, it was so perfect, just because i installed xServer with NVIDIA, I decided to upgrade my system to the new one, so I went to my windows 11 and downloaded the latest version of guruda-linux-gaming-230305 installed on USB, I tried to launch it with NVIDIA driver but it got stuck at live kernel update or something like that, so i had to go without NVIDIA driver, and installed the system. so now im trying to update it but still giving me same error
yep exatly, any luck fixing it ?
I think my issue related to lib32-nvidia-utils, because after i installed " lib32-nvidia-utils " some of the error gone but still having issue not able to update system or use guruda-gamer apps
in /etc/pacman.d/chaotic-mirrorlist (by the way, note the comment there about 404)
  File: chaotic-mirrorlist
  # Globally
try commenting (#) out those two (maybe just cdn) and see if that works around it (or, likely, just wait).
That remark about CDN 404s indicates it's only a temporary annoyance, so remember to uncomment it/them later on.
no luck, i tried it
@dr460nf1r3 @Technetium can you guys take a look when you have a chance? I am wondering if this is a case where the mirrorlist or keyring was updated but the symlink was not.
Please post what this URL lists so we can figure out why your internet connection is getting dropped. https://status.chaotic.cx/geo
This may be due to your ISP or country censoring your connection, where do you live?
Thank you for your reply,
cdn-mirror 1678471131 Healthy
this what i get, Im from Saudi Arabia, Riyadh, Using 5G Connection. I changed my connection to fiber different ISP but no luck.
I was using the old version of guruda-linux, it was working pretty well.
In case it helps:
I just got my .sig 404 (not "connection reset by peer" though) on a chaotic package I have installed:
error: failed retrieving file 'deadbeef-1.9.5-1-x86_64.pkg.tar.zst.sig' from r2.garudalinux.org : The requested URL returned error: 404
error: failed to commit transaction (unexpected error)
of course I could just skip that package, but I went back commenting out cdn-mirror (and left geo-mirror alone this time) and:
 deadbeef-1.9.5-1-x86_64 is up to date
upgrade successful, and apparently(*) the package itself was already downloaded on the first attempt.
(*) my bad, I closed the terminal without checking.
https://status.chaotic.cx/geo gives me ch-mirror 1678520805 Healthy.
/etc/pacman.conf
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
#RootDir     = /
#CacheDir    = /var/cache/pacman/pkg/
Architecture = auto
#IgnorePkg   = plymouth-git
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
# REPOSITORIES
#       [repo-name]
[garuda]
[core]
[extra]
[community]
[multilib]
[chaotic-aur]
#[custom]
# Globally
#Server = https://cdn-mirror.chaotic.cx/$repo/$arch
# Brazil
# Bulgaria
# Canada
# France
# Germany
# * By: itsTyrion
# * By: redgloboli
# Greece
# India
# Korea
# Spain
# * By: JKANetwork
# United States
# Michigan
# New York
# Texas
# Utah
# Virginia
# * By: Zoe
STC 5G here i had to mask line in /etc/pacman.d/chaotic-mirrorlist using #
#Server = https://geo-mirror.chaotic.cx/$repo/$arch
Edit:
This post by acco2oo2 seems to have fixed the problem for me.
Original Post:
Facing this issue since two days now. Refreshed mirrors and KeyRings using Garuda-Assistant.
I get the following error in the middle:
error: failed retrieving file 'brave-bin-1:1.49.120-1-x86_64.pkg.tar.zst.sig' from r2.garudalinux.org : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'dxvk-mingw-git-2.1.r22.gd14dcf5d-1-x86_64.pkg.tar.zst.sig' from r2.garudalinux.org : Resolving timed out after 15001 milliseconds
error: failed retrieving file 'chatterino2-7tv-git-r4053.c140c88b-1-any.pkg.tar.zst.sig' from r2.garudalinux.org : Connection time-out
warning: too many errors from r2.garudalinux.org, skipping for the remainder of this transaction
error: failed retrieving file 'candy-icons-git-r971.0125545-1-any.pkg.tar.zst.sig' from r2.garudalinux.org : Connection time-out
error: failed retrieving file 'tenacity-git-1:r14377.g0fc2e899d-1-x86_64.pkg.tar.zst.sig' from r2.garudalinux.org : Connection time-out
error: failed retrieving file 'protontricks-git-1.10.2.r1.g124fc7a-1-any.pkg.tar.zst.sig' from r2.garudalinux.org : Connection time-out
error: failed retrieving file 'retroarch-autoconfig-udev-git-r2125.8ec6304-1-any.pkg.tar.zst.sig' from r2.garudalinux.org : Connection time-out
error: failed retrieving file 'ananicy-rules-1.r118.29374f8-1-any.pkg.tar.zst.sig' from r2.garudalinux.org : Connection time-out
error: failed retrieving file 'reshade-shaders-git-r909.2459c73-1-any.pkg.tar.zst.sig' from r2.garudalinux.org : Connection time-out
error: failed retrieving file 'garuda-update-4.1.0-1-any.pkg.tar.zst.sig' from r2.garudalinux.org : Connection time-out
error: failed retrieving file 'librewolf-110.0-2.1-x86_64.pkg.tar.zst.sig' from r2.garudalinux.org : Connection time-out
--> Some downloads failed. Retrying...
And following error at the end:
Total Installed Size:  6184.22 MiB
Net Upgrade Size:      1381.93 MiB
brave-bin-1:1.49.120-1-x86_64 is up to date
Full Log:
[🔴] × garuda-update
[sudo] password for aurora:
core        156.6 KiB   105 KiB/s 00:01 [--------------------------------------------------------------------] 100%
extra        1743.5 KiB   742 KiB/s 00:02 [--------------------------------------------------------------------] 100%
community        7.3 MiB  1780 KiB/s 00:04 [--------------------------------------------------------------------] 100%
multilib        162.7 KiB  90.4 KiB/s 00:02 [--------------------------------------------------------------------] 100%
chaotic-aur        2.4 MiB  2.38 MiB/s 00:01 [--------------------------------------------------------------------] 100%
sneed-arch-repo        739.0   B   479   B/s 00:02 [--------------------------------------------------------------------] 100%
error: failed retrieving file 'core.db' from in-mirror.garudalinux.org : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'community.db' from in-mirror.garudalinux.org : Connection time-out
error: failed retrieving file 'multilib.db' from in-mirror.garudalinux.org : Connection time-out
warning: too many errors from in-mirror.garudalinux.org, skipping for the remainder of this transaction
error: failed retrieving file 'extra.db' from in-mirror.garudalinux.org : Connection time-out
error: failed retrieving file 'community.db' from in-mirror.garudalinux.org : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'garuda-update-4.1.0-1-any.pkg.tar.zst.sig' from r2.garudalinux.org : Resolving timed out after 10000 milliseconds
garuda downloading...
core downloading...
extra downloading...
community downloading...
multilib downloading...
chaotic-aur downloading...
sneed-arch-repo downloading...
garuda-update-4.1.0-1-any downloading...
warning: ttf-google-fonts-git: ignoring package upgrade (1:r4667.390533e07-1 => 1:r4921.cf0f67558-1)
resolving dependencies...
warning: dependency cycle detected:
warning: intel-oneapi-compiler-dpcpp-cpp-runtime will be installed before its intel-oneapi-compiler-shared-runtime dependency
Packages (145) alembic-1.8.4-3  alsa-plugins-1:1.2.7.1-2  ananicy-rules-1.r118.29374f8-1  bind-9.18.12-2  blender-17:3.4.1-20  brave-bin-1:1.49.120-1  candy-icons-git-r971.0125545-1
chatterino2-7tv-git-r4053.c140c88b-1  chromaprint-1.5.1-7  cifs-utils-7.0-3  cmake-3.25.3-1  dbus-1.14.6-2  draco-1.5.6-1  dxvk-mingw-git-2.1.r22.gd14dcf5d-1
electron-22.3.2-1  enchant-2.3.4-1  fcitx5-5.0.22-2  fcitx5-chinese-addons-5.0.17-1  fcitx5-configtool-5.0.17-1  fcitx5-gtk-5.0.22-1  fcitx5-qt-5.0.17-1  ffmpeg-2:6.0-3
ffmpegthumbs-22.12.3-2  garuda-update-4.1.0-1  gegl-0.4.42-3  ghostscript-10.0.0-6  gmic-3.2.1-3  grep-3.9-1  gst-libav-1.22.1-2  gst-plugins-bad-1.22.1-2
gst-plugins-bad-libs-1.22.1-2  gst-plugins-base-1.22.1-2  gst-plugins-base-libs-1.22.1-2  gst-plugins-good-1.22.1-2  gst-plugins-ugly-1.22.1-2  gstreamer-1.22.1-2
gstreamer-vaapi-1.22.1-2  gtk-update-icon-cache-1:4.10.0-3  gtk4-1:4.10.0-3  hdf5-1.12.2-2  hidapi-0.13.1-2  hwdata-0.368-1  imagemagick-7.1.1.2-1  imath-3.1.7-1
inetutils-2.4-1  intel-oneapi-common-2023.0.0-3  intel-oneapi-compiler-dpcpp-cpp-runtime-2023.0.0-2  intel-oneapi-compiler-shared-runtime-2023.0.0-1
intel-oneapi-openmp-2023.0.0-1  intel-oneapi-tbb-2021.8.0-1  kfilemetadata-5.103.0-2  kid3-3.9.3-2  kid3-common-3.9.3-2  kimageformats-5.103.0-2  kpipewire-5.27.2-2
level-zero-loader-1.8.12-1  lib32-dbus-1.14.6-2  lib32-faudio-23.03-1  lib32-gtk3-1:3.24.37-1  lib32-lcms2-2.15-1  lib32-libnm-1.42.4-1  lib32-libpsl-0.21.2-1
lib32-libpulse-16.1-4  lib32-openssl-1:3.0.8-1  lib32-openssl-1.1-1.1.1.t-1  lib32-sdl2_ttf-2.20.2-1  lib32-tdb-1.4.8-1  lib32-vkd3d-1.6-1  libadwaita-1:1.2.3-1
libbpf-1.1.0-1  libde265-1.0.11-2  libedit-20221030_3.1-1  libhandy-1.8.2-1  libice-1.1.1-2  libime-1.0.17-1  libjcat-0.1.13-1  libkscreen-5.27.2-2  libmfx-23.1.3-2
libmms-0.6.4-4  libnm-1.42.4-1  libopenmpt-0.6.9-1  libpulse-16.1-4  libqalculate-4.6.0-1  librewolf-110.0-2.1  libwpe-1.14.1-2  libxau-1.0.11-2  libxdmcp-1.1.4-2
libxfont2-2.0.6-2  linux-hardened-6.1.15.hardened1-1  linux-hardened-headers-6.1.15.hardened1-1  linux-zen-6.2.2.zen2-1  linux-zen-headers-6.2.2.zen2-1  lmdb-0.9.30-3
mcfly-0.8.0-1  mercurial-6.3.3-1  mlt-7.14.0-2  mpv-1:0.35.1-3  networkmanager-1.42.4-1  networkmanager-pptp-1.2.12-1  nextcloud-client-2:3.7.4-1  nm-cloud-setup-1.42.4-1
obs-studio-29.0.2-2  openal-1.23.0-2  opencolorio-2.2.1-4  opencv-4.7.0-6  openexr-3.1.6-1  openimageio-2.4.9.0-2  openvpn-2.6.1-1  pcsclite-1.9.9-3  perl-alien-build-2.78-1
phodav-3.0-2  proton-ge-custom-2:GE.Proton7.50-4  protontricks-git-1.10.2.r1.g124fc7a-1  python-fonttools-4.39.0-1  python-pydantic-1.10.6-1
python-trove-classifiers-2023.3.9-1  python-urllib3-1.26.13-1  qt5-base-5.15.8+kde+r182-1  qt5-script-5.15.13-1  qt5-wayland-5.15.8+kde+r63-1  qt5-webengine-5.15.13-1
qt6-webengine-6.4.2-4  reshade-shaders-git-r909.2459c73-1  retroarch-1.14.0-2  retroarch-autoconfig-udev-git-r2125.8ec6304-1  scrcpy-1.25-2  sdl2-2.26.4-1  sed-4.9-3
simplescreenrecorder-0.4.4-2  spice-gtk-0.42-3  spice-protocol-0.14.4-1  sweet-theme-full-git-r308.6e2ef01-1  systemd-253.1-3  systemd-libs-253.1-3
systemd-sysvcompat-253.1-3  tar-1.34-2  telegram-desktop-4.6.5-3  tenacity-git-1:r14377.g0fc2e899d-1  tinycompress-1.2.8-2  v4l-utils-1.24.1-1  wine-staging-8.3-1
wpebackend-fdo-1.14.1-1  xapian-core-1:1.4.22-1  xcb-imdkit-1.0.5-1  yt-dlp-2023.03.04-1
librewolf-110.0-2.1-x86_64 is up to date
tenacity-git-1:r14377.g0fc2e899d-1-x86_64 is up to date
dxvk-mingw-git-2.1.r22.gd14dcf5d-1-x86_64 is up to date
chatterino2-7tv-git-r4053.c140c88b-1-any is up to date
candy-icons-git-r971.0125545-1-any is up to date
protontricks-git-1.10.2.r1.g124fc7a-1-any is up to date
retroarch-autoconfig-udev-git-r2125.8ec6304-1-any is up to date
ananicy-rules-1.r118.29374f8-1-any is up to date
reshade-shaders-git-r909.2459c73-1-any is up to date
error: failed retrieving file 'chatterino2-7tv-git-r4053.c140c88b-1-any.pkg.tar.zst.sig' from r2.garudalinux.org : Resolving timed out after 10000 milliseconds
error: failed retrieving file 'garuda-update-4.1.0-1-any.pkg.tar.zst.sig' from r2.garudalinux.org : Resolving timed out after 15009 milliseconds
error: failed retrieving file 'ananicy-rules-1.r118.29374f8-1-any.pkg.tar.zst.sig' from r2.garudalinux.org : Resolving timed out after 14997 milliseconds
error: failed retrieving file 'dxvk-mingw-git-2.1.r22.gd14dcf5d-1-x86_64.pkg.tar.zst.sig' from r2.garudalinux.org : Connection time-out
error: failed retrieving file 'brave-bin-1:1.49.120-1-x86_64.pkg.tar.zst.sig' from r2.garudalinux.org : Connection time-out
System info:
╰─λ garuda-inxi
root=UUID=1d17e6de-9557-4600-a71d-2fc817db7784 rw [email protected]
quiet
cryptdevice=UUID=ccf6a087-7f6c-4357-9cb5-8bf35bb72a1d:luks-ccf6a087-7f6c-4357-9cb5-8bf35bb72a1d
root=/dev/mapper/luks-ccf6a087-7f6c-4357-9cb5-8bf35bb72a1d quiet splash
resume=/dev/mapper/luks-253338ee-7144-43f5-bc83-a762863e12f3 loglevel=3
mitigations=off ibt=off
Type: Laptop System: ASUSTeK product: ROG Strix G713QM_G713QM v: 1.0
Mobo: ASUSTeK model: G713QM v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G713QM.321 date: 09/07/2022
ID-1: BAT0 charge: 51.5 Wh (60.0%) condition: 85.8/90.0 Wh (95.3%)
volts: 15.7 min: 15.9 model: AS3GWAF3KC GA50358 type: Li-ion
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
microcode: 0xA50000B
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1197 high: 1200 min/max: 1200/4462 boost: enabled
scaling: driver: acpi-cpufreq governor: powersave cores: 1: 1197 2: 1198
3: 1200 4: 1195 5: 1192 6: 1198 7: 1196 8: 1197 9: 1200 10: 1200 11: 1197
12: 1198 13: 1198 14: 1200 15: 1197 16: 1200 bogomips: 102210
link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1 off: eDP-1
empty: none bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 36.0 C
compositor: kwin_x11 driver: X: loaded: modesetting dri: radeonsi
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 507x317mm (19.96x12.48")
s-diag: 598mm (23.54")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary model: Acer B246WL
serial: <filter> built: 2020 res: 1920x1200 hz: 60 dpi: 94 gamma: 1.2
size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10 modes:
max: 1920x1200 min: 720x400
Monitor-2: eDP-1 note: disabled model: AU Optronics 0x8294 built: 2020
res: 1920x1200 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46")
diag: 438mm (17.3") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.49 6.2.2-zen1-1-zen) direct-render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel bus-ID: 1-2.4:6 v: kernel chip-ID: 0c76:1620 pcie:
class-ID: 0300 gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
Device-4: JMTek LLC. USB PnP Audio Device type: USB
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:5
chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 4.98 TiB used: 2.13 TiB (42.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM512GD3JX013N
lanes: 4 type: SSD serial: <filter> rev: 41000C20 temp: 31.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Western Digital
model: WDS480G2G0A-00JH30 size: 447.13 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
model: WDS480G2G0A-00JH30 size: 447.14 GiB block-size: physical: 512 B
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Western Digital
model: WD40NDZW-11A8JS1 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 4008 scheme: GPT
ID-1: / raw-size: 430.27 GiB size: 430.27 GiB (100.00%)
used: 93.26 GiB (21.7%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-ccf6a087-7f6c-4357-9cb5-8bf35bb72a1d
used: 752 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 430.27 GiB size: 430.27 GiB (100.00%)
ID-4: /var/log raw-size: 430.27 GiB size: 430.27 GiB (100.00%)
ID-5: /var/tmp raw-size: 430.27 GiB size: 430.27 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.05 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.56 GiB used: 0 KiB (0.0%)
mapped: luks-253338ee-7144-43f5-bc83-a762863e12f3
System Temperatures: cpu: 38.0 C mobo: N/A gpu: amdgpu temp: 37.0 C
Fan Speeds (RPM): cpu: 0
Processes: 422 Uptime: 1h 20m wakeups: 9 Memory: 15.05 GiB
used: 5.6 GiB (37.2%) Init: systemd v: 253 default: graphical
pkgs: 2206 libs: 568 tools: octopi,pamac,paru Shell: fish v: 3.6.0
default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.25
Garuda (2.6.15-1):
System install date:     2022-10-03
Last full system update: 2023-03-05
I just opened r2.garudalinux.org on my browser and noticed, that it's cloudflare protected.
Is it possible, that the cloudflare bot-blocker is stuck in a verification loop and taking so long to redirect you that it just gives up? (same as using privacy plugins and visiting a cloudflare page :pensive:)
Are you using a VPN of any kind?
Can someone explain to me why pacman is not simply switching to the next mirror in the mirrorlist when these errors happen? That seems to be the main issue here.
I never used VPN on linux, the old version was well, this one not really
