Fresh install - system freezes and can't connect to WiFi
So since Windows started giving me a headache and I’ve tried Garuda before I’ve decided to switch to it completely as standalone OS. My previous experience was fine, everything worked out of the box. Now on my newer PC I have issues with stuttering and freezes and my T4U Plus WiFi adapter doesn’t work (it worked in live USB and on older PC).
System detects internet connection but is stuck in a loop of configuring interface - connection failed. I can try to fix it with GitHub repositories or AUR after I’ll find proper package but I don’t know what to do about these freezes I have. Mouse cursor behaves normally but can’t click anything.
Garuda-inxi:
Kernel: 6.8.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=aa47e7f6-d135-4601-88af-ae5a97081886 rw rootflags=subvol=@
quiet resume=UUID=5c94f891-1666-4067-bf30-b7897054b893 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.3 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Desktop Mobo: ASUSTeK model: PRIME B450-PLUS v: Rev X.0x
BIOS: American Megatrends v: 4402 date: 12/13/2023
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701030
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3589 high: 3754 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3544 2: 3600
3: 3653 4: 3600 5: 3600 6: 3600 7: 3600 8: 3552 9: 3600 10: 3754 11: 3372
12: 3600 bogomips: 86399
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Sapphire
active: HDMI-A-1 empty: DP-1, DP-2, DP-3, Writeback-1 bus-ID: 0b:00.0
chip-ID: 1002:73ff class-ID: 0300
gpu: amdgpu display-ID: 0
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600 XT (radeonsi
navi23 LLVM 17.0.6 DRM 3.57 6.8.5-zen1-1-zen) device-ID: 1002:73ff
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 6600 XT (RADV NAVI23) driver: mesa radv v: 24.0.5-arch1.1
device-ID: 1002:73ff surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.5-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:ab28
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech Logitech G PRO X Gaming Headset
lanes: 1 mode: 1.1 bus-ID: 1-2:3 chip-ID: 046d:0aaa class-ID: 0300
API: ALSA v: k6.8.5-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168
Device-2: TP-Link Archer T4U ver.3 driver: rtw_8822bu type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 2357:0115
IF: wlp2s0f0u1 state: down mac: <filter>
IF-ID-1: enp2s0f0u4 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Xiaomi Mi/Redmi series (RNDIS) driver: rndis_host v: kernel
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:5
chip-ID: 2717:ff80 class-ID: 0a00 serial: <filter>
Local Storage: total: 931.51 GiB used: 18.21 GiB (2.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lexar model: SSD NM710 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 9742 temp: 39.9 C scheme: MBR
ID-1: / raw-size: 914.43 GiB size: 914.43 GiB (100.00%)
used: 18.21 GiB (2.0%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 914.43 GiB size: 914.43 GiB (100.00%)
ID-3: /var/log raw-size: 914.43 GiB size: 914.43 GiB (100.00%)
ID-4: /var/tmp raw-size: 914.43 GiB size: 914.43 GiB (100.00%)
ID-2: swap-2 type: partition size: 17.08 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 46.4 C mobo: N/A gpu: amdgpu temp: 33.0 C
mem: 30.0 C
Memory: total: 16 GiB available: 15.53 GiB used: 2.6 GiB (16.7%)
Processes: 302 Power: uptime: 8m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1906 libs: 547 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1
Garuda (2.6.25-1):
System install date:     2024-04-13
Last full system update: 2024-04-13
I would update the BIOS first (new version release came out a few days ago) PRIME B450-PLUS - Support
I would also try a different kernel like the LTS kernel, as you mentioned the wifi worked on live USB.
In case you can’t fix your issue with the LTS kernel, in my opinion you could try this driver:
sudo pacman -S rtl88x2bu-dkms-git
Afterwards, you should probably blacklist your current module:
echo "blacklist rtw88_8822bu" | sudo tee /etc/modprobe.d/rtw8822bu.conf
One issue per topic, please.
Let’s focus only on the network one here.
AUR only:
paru rtl88x2bu-dkms-git
Pacman can’t find it, Yay can but it can’t build it
==> ERROR: Cannot find the debugedit binary required for including source files in debug packages.
error: failed to build 'rtl88x2bu-dkms-git-5.13.1.r181.2812290-3':
error: packages failed to build: rtl88x2bu-dkms-git-5.13.1.r181.2812290-3
Also LTS kernel didn’t help
Edit
Nvm, managed to get that driver with pamac and looks like it works, I’ve lost 5GHz connection however
Edit 2
Works also on zen kernel, no 5GHz still though
Try disconect the adapter, reboot and connect the adapter again.
Check whether you also have the issue with a x11 session. If so, then create a separate topic for it.
Sadly it still doesn’t let me connect to 5GHz network. Stuck on configuring interface - connection failed
You got me again :wink:. I was in a hurry as usual and went as usual for a copy and paste from a previous post…
There are quite a few issues upstream where 5G is mentioned.
I hadn’t time to read them, I’ll just reference one. Maybe repeat the search and see if there is some kind of workaround as mentioned here:
Well it just connected now, I don’t know exactly why as I haven’t changed that much with drivers or anything so I’d say the issue has been solved :slight_smile:
