Just installed Garuda Linux, but I can’t seem to get audio to work – neither on front panel, back, nor in one of my monitors. I tried switching between different audio systems (ALSA, Pipewire, Pulseaudio), but I couldn’t get it to work
Output for inxi -f
below
Host: anton-b650ms2h Kernel: 6.8.1-zen1-1-zen arch: x86_64 bits: 64
Desktop: KDE Plasma v: 6.0.2 Distro: Garuda Linux
Type: Desktop System: Gigabyte product: B650M S2H v: -CF
Mobo: Gigabyte model: B650M S2H v: x.x serial: <superuser required>
UEFI: American Megatrends LLC. v: F3 date: 07/10/2023
Info: 6-core model: AMD Ryzen 5 7600 bits: 64 type: MT MCP cache: L2: 6 MiB
Speed (MHz): avg: 400 min/max: 400/5170 cores: 1: 400 2: 400 3: 400 4: 400
5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400
driver: amdgpu v: kernel
Device-2: AMD Raphael driver: amdgpu v: kernel
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4 driver: X:
loaded: amdgpu unloaded: modesetting,radeon dri: radeonsi gpu: amdgpu
resolution: 1: 1920x1080~60Hz 2: 1920x1080
API: EGL v: 1.5 drivers: kms_swrast,radeonsi,swrast
platforms: gbm,x11,surfaceless,device
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.3-arch1.1
renderer: AMD Radeon RX 6700 XT (radeonsi navi22 LLVM 17.0.6 DRM 3.57
6.8.1-zen1-1-zen)
API: Vulkan v: 1.3.279 drivers: radv,llvmpipe surfaces: xcb,xlib
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel
Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel
API: ALSA v: k6.8.1-zen1-1-zen status: kernel-api
Server-1: PipeWire v: 1.0.4 status: active
Server-2: PulseAudio v: 17.0 status: active
driver: r8169
IF: enp8s0 state: down mac: 74:56:3c:c5:d6:1f
IF-ID-1: enp19s0u2 state: unknown speed: -1 duplex: half
mac: 16:54:f7:86:f7:06
Device-1: Xiaomi Mi/Redmi series (RNDIS + ADB) driver: rndis_host type: USB
Local Storage: total: 931.51 GiB used: 15.43 GiB (1.7%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WD BLACK SN770 1TB
ID-1: / size: 931.22 GiB used: 15.43 GiB (1.7%) fs: btrfs
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 584 KiB (0.2%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 931.22 GiB used: 15.43 GiB (1.7%) fs: btrfs
dev: /dev/nvme0n1p2
ID-4: /var/log size: 931.22 GiB used: 15.43 GiB (1.7%) fs: btrfs
dev: /dev/nvme0n1p2
ID-5: /var/tmp size: 931.22 GiB used: 15.43 GiB (1.7%) fs: btrfs
dev: /dev/nvme0n1p2
ID-1: swap-1 type: zram size: 30.5 GiB used: 0 KiB (0.0%) dev: /dev/zram0
System Temperatures: cpu: 35.0 C mobo: 25.0 C
GPU: device: amdgpu temp: 32.0 C device: amdgpu temp: 35.0 C fan: 0
Memory: total: 32 GiB note: est. available: 30.5 GiB used: 4.25 GiB (13.9%)
Processes: 315 Uptime: 5m Shell: fish inxi: 3.3.33
SGS
20 March 2024 09:24
2
What’s the problem with not posting garuda-inxi?
It contains additional, useful information about the status of your system.
Did you search in forum?
Sorry, I thought inxi -F
would suffice. Here’s garuda-inxi
Kernel: 6.8.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e1b0c1bb-a0cf-497d-888b-0dd26aee11dd rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A info: frameworks v: 6.0.0
uuid: <superuser required> UEFI: American Megatrends LLC. v: F3
date: 07/10/2023
Info: model: AMD Ryzen 5 7600 bits: 64 type: MT MCP arch: Zen 4 gen: 5
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 6 MiB desc: 6x1024 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2101 high: 4232 min/max: 400/5170 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3983 2: 4232 3: 400
4: 400 5: 400 6: 3398 7: 3836 8: 3974 9: 400 10: 3389 11: 400 12: 400
bogomips: 91031
vendor: XFX Speedster QICK 319 driver: amdgpu v: kernel arch: RDNA-2
speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3,
Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:73df class-ID: 0300
Device-2: AMD Raphael vendor: Gigabyte driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: HDMI-A-2 empty: DP-4,
DP-5, DP-6, Writeback-2 bus-ID: 15:00.0 chip-ID: 1002:164e class-ID: 0300
temp: 31.0 C
Screen-1: 0 s-res: 3840x1265 s-dpi: 96 s-size: 1013x333mm (39.88x13.11")
s-diag: 1066mm (41.98")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: primary,top-left
model: BOE Display A5401WR serial: <filter> built: 2021 res: 1920x1080
hz: 60 dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080 min: 640x480
Monitor-2: HDMI-A-2 mapped: HDMI-A-1-1 pos: bottom-r
model: Philips PHL 221V8 serial: <filter> built: 2021 res: 1920x1080
dpi: 102 gamma: 1.2 size: 477x268mm (18.78x10.55") diag: 547mm (21.5")
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
navi22 LLVM 17.0.6 DRM 3.57 6.8.1-zen1-1-zen) device-ID: 1002:73df
memory: 11.72 GiB unified: no
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 24.0.3-arch1.1
device-ID: 1002:73df surfaces: xcb,xlib device: 1 type: integrated-gpu
name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: mesa radv
v: 24.0.3-arch1.1 device-ID: 1002:164e surfaces: xcb,xlib device: 2
type: cpu name: llvmpipe (LLVM 17.0.6 256 bits) driver: mesa llvmpipe
v: 24.0.3-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 15:00.1
Device-3: AMD Family 17h/19h HD Audio vendor: Gigabyte
bus-ID: 15:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.8.1-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.4 status: active with: 1: wireplumber
status: active 2: pw-jack type: plugin tools: pw-cat,pw-cli,wpctl
Server-2: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
lanes: 1 port: e000 bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: enp19s0u2 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Xiaomi Mi/Redmi series (RNDIS + ADB) driver: rndis_host v: kernel
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:9
chip-ID: 2717:ff88 class-ID: 0a00 serial: <filter>
Local Storage: total: 931.51 GiB used: 15.86 GiB (1.7%)
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731100WD temp: 36.9 C scheme: GPT
used: 15.86 GiB (1.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 30.5 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 35.4 C mobo: 25.0 C
GPU: device: amdgpu temp: 35.0 C mem: 32.0 C fan: 0 watts: 5.00
Memory: total: 32 GiB note: est. available: 30.5 GiB used: 4.92 GiB (16.1%)
Processes: 318 Power: uptime: 7m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.19 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1978 libs: 580 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.0
Garuda (2.6.23-1):
System install date: 2024-03-20
Last full system update: 2024-03-20
did you search in forum?
Yes. As I said, I tried switching between audio systems, setting snd_hda_intel
detection, installing sof-firmware etc. Nothing worked. That, or I’m doing something wrong
Okay, so I “fixed” it by plugging headphones into motherboard jack instead of front panel
I probably should check physical front panel connections…
