Kernel: 6.8.9-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=ecfb0dcf-b1fc-49eb-a70e-4c1ae4e56aef rw rootflags=subvol=@
Desktop: Hyprland v: 0.40.0 with: waybar tools: swayidle
avail: hyprlock,swaylock vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
Type: Mini-pc System: AZW product: SER v: Version 1.0
Mobo: AZW model: SER v: Version 1.0 serial: <superuser required>
part-nu: Default SKU uuid: <superuser required> UEFI: American Megatrends
LLC. v: 113 date: 02/22/2023
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
serial: <filter> charge: 10% (should be ignored) rechargeable: yes
Info: model: AMD Ryzen 7 7735HS with Radeon Graphics bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404102
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 462 high: 1397 min/max: 400/4829 scaling:
4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400
14: 400 15: 1397 16: 400 bogomips: 102212
Device-1: AMD Rembrandt [Radeon 680M] driver: amdgpu v: kernel arch: RDNA-2
speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3,
DP-4, DP-5, HDMI-A-2, Writeback-1 bus-ID: 74:00.0 chip-ID: 1002:1681
class-ID: 0300 temp: 45.0 C
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 23.2.7
compositor: Hyprland v: 0.40.0 driver: X: loaded: amdgpu
unloaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
display-ID: 1
Monitor-1: HDMI-A-1 model: Samsung LS24AG32x serial: <filter> built: 2021
res: 1920x1080 hz: 144 dpi: 93 gamma: 1.2 scale: 1
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV REMBRANDT) driver: mesa radv v: 24.0.7-arch1.3
device-ID: 1002:1681 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.7-arch1.3 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 74:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_acp6x
v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 74:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 74:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.8.9-zen1-2-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.6 status: active with: 1: pipewire-pulse
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:2 chip-ID: 8087:0029
Local Storage: total: 931.52 GiB used: 17.57 GiB (1.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S500G
lanes: 4 tech: SSD serial: <filter> fw-rev: SBJ00101 temp: 44.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
fw-rev: 0104 scheme: GPT
ID-1: / raw-size: 217.29 GiB size: 217.29 GiB (100.00%)
used: 17.4 GiB (8.0%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
used: 168 MiB (32.9%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 217.29 GiB size: 217.29 GiB (100.00%)
ID-4: /var/log raw-size: 217.29 GiB size: 217.29 GiB (100.00%)
ID-5: /var/tmp raw-size: 217.29 GiB size: 217.29 GiB (100.00%)
ID-1: swap-1 type: zram size: 28.14 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 53.0 C mobo: N/A gpu: amdgpu temp: 47.0 C
Memory: total: 28 GiB note: est. available: 28.14 GiB used: 2.19 GiB (7.8%)
Processes: 349 Power: uptime: 1h 27m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 11.24 GiB services: upowerd Init: systemd
v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1409 libs: 426 tools: pacseek,paru,yay
Compilers: gcc: 14.1.1 Shell: garuda-inxi default: Bash v: 5.2.26
running-in: terminator inxi: 3.3.34
System install date: 2024-05-15
Last full system update: 2024-05-17
Is partially upgraded: Yes
My waybar config has this module:
"idle_inhibitor": {
"format": "{icon}",
"format-icons": {
"activated": "ļ®",
"deactivated": "ļ°"
Should there be an āon-clickā action defined in this module for the idle_inhibitor to work?
Right now it does nothing whether activated or deactivated.
What am I missing?
Swaylock and Swayidle are installed and working.
The screen will lock after timeout and the monitor goes black after another timeout.
Moving the mouse or keyboard activity turns on the monitor and presents the login circle.
All this is functioning as expected. The only thing not working is the idle_inibitor. Any help is greatly appreciatedā¦
