Fresh boot of Garuda failing after system journal error
i oly found this for your mobo update stuff.
I have got two drive connected one nvme and one sata ssd the nvme is being used as my main drive for windows and the ssd is fully cleared other than the isos is currently formatted for ventoy as of right now.
I will check my cpu and ram as you suggested when I get home
Response to bios update thing (ran out of replies for being a new user
I I I
V V V
I will probably try this but the problem with this is it is bios for some other brand of motherboard I was told there was I small chance it might brick my system
I strongly advise against this.
Belief is not knowledge. I can’t even quickly find a manual for this noname cheap mobo…
It is only a symptom and not the cause. You have the same issue with different Linux distributions, either it’s the BIOS or the hardware. Windows obviously works, but something is preventing a Linux live.iso from booting. Do you have expansion cards in the computer, for example a sound card? Have you tried a different usb-stick for the live.iso? Have you tried a memtest from the grub menu?
It would be helpful if you could upload a picture to an external pic-hoster and post the link here (not just of the single error message, we need to see what happens before).
yes im sorry to say that is not recommended .it says in support his board but we dont know exactly when is a unknown brand what they change on newer boards.
hm maybe he can check if he have the TPM (Trusted Platform Module) or TPM2 Module activated was cause the issue. dont delete bios Keys may it wont start your windows.
also some CSM Module (or Settings to Check maybe disabled or activated Settings) cause issues.
in my case my windows is on nvme and when ive installed garuda to my other ssd i put the nvme out only the SSD because both give me trouble too.
Omg I just tried removing my nvme and I work perfectly! I greatly appreciate all the support and help you guys provided I am so glad to finally experience linux for the first time! : )
The suggestion was already made in an earlier post, so I have corrected the highlighted solution.
