First off, love this distro more than any other distro I've ever used. It has improved my workflow immensely. I'm not sure I'll ever be able to get away from it.
My problem(s):
1: Frequent latte dock crashes. Happens randomly, sometimes while switching virtual desktops, sometimes for no apparent reason at all.
My hot fix: latte-dock --replace, and then right click on the top panel > edit panel > switch visibility to autohide, and then quickly switch it back to "Always Visible". I have to do this since, even after replacing the latte dock, there are still issues with the top panel showing up on all displays and all virtual desktops.
- WiFI issues with BrosTrend AC1200 WiFi adapter.
My attempted fixes: Searched the forums and tried multiple solutions. Re-installed drivers, blacklisted drivers, and even disabled ipv6 (re-enabled later). None of these worked. I resorted to tethering my phone to my computer via USB and sharing the internet connection from it. This is very inconvenient but it'll have to due for the moment as I'm very busy with work.
I'm required to post the following:
One other question: is it really necessary that users post their cryptdevice info on the forums?
root=UUID=11374ffd-57dd-4850-ae21-7018ba2a4020 rw rootflags=subvol=@
quiet
cryptdevice=UUID=a3b5cba1-2dfa-428f-8997-3864dc0e7ca3:luks-a3b5cba1-2dfa-428f-8997-3864dc0e7ca3
root=/dev/mapper/luks-a3b5cba1-2dfa-428f-8997-3864dc0e7ca3 quiet splash
ipv6.disable=1 ipv6.disable=0
Desktop: KDE Plasma v: 5.26.1 tk: Qt v: 5.15.6 info: latte-dock
Type: Desktop Mobo: ASUSTeK model: Maximus IV Extreme v: Rev 1.xx
serial: <superuser required> BIOS: American Megatrends v: 3604
date: 04/12/2013
Info: model: Intel Core i7-2600K bits: 64 type: MT MCP arch: Sandy Bridge
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1671 high: 2079 min/max: 1600/5900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1605 2: 1605 3: 1605
4: 2079 5: 1607 6: 1607 7: 1605 8: 1655 bogomips: 54583
vulnerable
Device-1: NVIDIA GM204 [GeForce GTX 980] vendor: ASUSTeK driver: nvidia
v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
(as of 2022-10) arch: Maxwell code: GMxxx process: TSMC 28nm
built: 2014-19 pcie: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:13c0 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.4
Screen-1: 0 s-res: 3840x1080 s-dpi: 85 s-size: 1147x319mm (45.16x12.56")
s-diag: 1191mm (46.87")
Monitor-1: DVI-I-0 pos: right res: 1280x1024 hz: 60 dpi: 86
size: 376x301mm (14.8x11.85") diag: 482mm (18.96") modes: N/A
Monitor-2: HDMI-0 pos: primary,left res: 2560x1080 dpi: 81
size: 798x334mm (31.42x13.15") diag: 865mm (34.06") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 980/PCIe/SSE2 v: 4.6.0 NVIDIA
520.56.06 direct render: Yes
vendor: ASUSTeK driver: snd_hda_intel bus-ID: 1-1.4.1:8 v: kernel
bus-ID: 00:1b.0 chip-ID: 1038:12ad class-ID: 0300 chip-ID: 8086:1c20
Device-2: NVIDIA GM204 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:0fbb class-ID: 0403
Device-3: SteelSeries ApS Arctis 7 type: USB
Device-4: Shure X2u Adapter type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1.6:7 chip-ID: 14ed:29b6
Device-1: Intel 82579V Gigabit Network vendor: ASUSTeK P8P67 Deluxe
driver: e1000e v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1503
Device-2: Intel 82583V Gigabit Network vendor: ASUSTeK driver: e1000e
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: b000 bus-ID: 0c:00.0
chip-ID: 8086:150c class-ID: 0200
IF: enp12s0 state: down mac: <filter>
Device-3: Realtek RTL88x2bu [AC1200 Techkey] type: USB driver: rtw_8822bu
bus-ID: 2-1.6:7 chip-ID: 0bda:b812 class-ID: 0000 serial: <filter>
IF: wlp0s29u1u6 state: up mac: <filter>
IF-ID-1: enp0s29u1u5 state: unknown speed: -1 duplex: half mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-1.1:3 chip-ID: 0a12:0001 class-ID: fe01
address: <filter>
Device-2: Samsung GT-I9070 (network tethering USB debugging enabled)
type: USB driver: rndis_host v: kernel bus-ID: 2-1.5:11 chip-ID: 04e8:6864
Local Storage: total: 447.13 GiB used: 42.22 GiB (9.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSC2BP480G4
type: SSD serial: <filter> rev: 0420 scheme: MBR
ID-1: / raw-size: 447.13 GiB size: 447.13 GiB (100.00%) used: 42.22 GiB
(9.4%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-a3b5cba1-2dfa-428f-8997-3864dc0e7ca3
ID-2: /home raw-size: 447.13 GiB size: 447.13 GiB (100.00%) used: 42.22
GiB (9.4%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-3: /var/log raw-size: 447.13 GiB size: 447.13 GiB (100.00%) used: 42.22
ID-4: /var/tmp raw-size: 447.13 GiB size: 447.13 GiB (100.00%) used: 42.22
ID-1: swap-1 type: zram size: 31.32 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 44.0 C mobo: N/A gpu: nvidia temp: 79 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 58%
Processes: 322 Uptime: 11h 53m wakeups: 24 Memory: 31.32 GiB used: 5.9 GiB
(18.8%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1275 libs: 332
Garuda (2.6.9-1):
System install date: 2022-10-21
Last full system update: 2022-10-23
I'm new to the forums, and would appreciate any tips/pointers. Thank you.
