Hello, today i have been using my laptop like usually, unitl one weird thing happened — my laptot just freezes! So i holded an poweroff button and rebooted, when i've entered as administrator — my background customization, all settings, just gone, i mean „latte“ not responding, settings restarted, when do i add a new user, same issue is repeating after rebooting, what this is issue, and do there is an a the way to run system properly?
I'm so exhausted of this... Addading info:
Kernel: 5.16.7-arch1-1
Shell: sh
DE: Plasma 5.23.5
Garuda linux KDE dragonized.
can you provide
as requested in the template?
Kernel: 5.16.7-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=c0836dda-02fe-4a40-b314-d43148a2047b rw [email protected]
Type: Convertible System: LENOVO product: 20FRS0UP10
v: ThinkPad X1 Yoga 1st serial: <superuser required> Chassis: type: 31
Mobo: LENOVO model: 20FRS0UP10 v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: N1FET57W (1.31 )
date: 09/29/2017
ID-1: BAT0 charge: 37.4 Wh (98.9%) condition: 37.8/52.1 Wh (72.6%)
volts: 16.6 min: 15.2 model: SMP 00HW029 type: Li-poly serial: <filter>
status: Discharging
Info: model: Intel Core i5-6300U bits: 64 type: MT MCP arch: Skylake
family: 6 model-id: 0x4E (78) stepping: 3 microcode: 0xEA
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2960 high: 2995 min/max: 400/3000 scaling:
driver: intel_pstate governor: powersave cores: 1: 2995 2: 2924 3: 2943
4: 2980 bogomips: 19999
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-8:3 chip-ID: 04f2:b5c1 class-ID: 0e02
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157
size: 310x170mm (12.2x6.7") diag: 354mm (13.9")
Sound Server-1: ALSA v: k5.16.7-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.45 running: no
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:156f class-ID: 0200
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel bus-ID: 04:00.0
chip-ID: 8086:24f3 class-ID: 0280
bus-ID: 1-7:2 chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 223.57 GiB used: 36.58 GiB (16.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSCKGF240A5L
type: SSD serial: <filter> rev: LVBi scheme: GPT
used: 36.58 GiB (16.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 7.5 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 30.0 C pch: 30.5 C mobo: N/A
Fan Speeds (RPM): fan-1: 0
Processes: 245 Uptime: 9m wakeups: 4 Memory: 7.5 GiB used: 1.27 GiB (16.9%)
Init: systemd v: 250 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.1
Packages: pacman: 1599 lib: 372 Shell: fish v: 3.3.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.12
Garuda (2.5.4-2):
System install date: 2021-12-13
Last full system update: 2022-02-08
Failed units: anbox-container-manager.service
Try going to Garuda Assistant and reset config's
SGS
8 February 2022 22:34
#5
If you include terminal outputs in your post please use the proper output format in your post.
Using "~" 3 times above and "~" 3 times below the text block will provide a readable, raw look.
Done, just now for you
c00ter
9 February 2022 01:14
#6
"They're gone, man. I mean just not there anymore!"
Cause of the freeze? Who knows. Do Skylake laptop processors have overheating problems? Is it well ventilated? Anyway, you may/might/probably screwed the pooch on your filesystem by now--learn REISUB for next time--but if not, it is possible to let the system resurrect itself. Possibly.
If it is still happening, then after you have done a normal log-in, reboot again. And again. Once more, even. It may or may not help. If it does, then go about re-customization. If it does not, save your data and re-install. Unrecoverable filesystems are one of the few things requiring that necessity in a rolling system.
After rebooting, firmware installation, and some packages deleting, i've found solution — that won't helped, so switched kernel version from linux-zen to linux-lts, — in the past 12 hours all works normally.
Thank you all for responses!
system
closed
12 February 2022 12:12
#9
