While I'm using LXQT-Kwin version of Garuda and using literally 2 apps it seems to hang after some time for no reason.
I'm not stressing the Cpu in each case.
Without any information about your system (which you were asked to provide in the text you deleted before posting) there's very little to go on.
The main reasons for a freeze would be 1) a hardware issue, like high temperatures or a loose connection or 2) completely exhausting available RAM.
(And before you say "but I'm literally only running 2 apps" that doesn't mean anything without more information)
And Welcome to the Forums, @Masalale
I would normally agree with you but in this case memory is barely reached half use and temp is fairly normal at 63c
Without any further information (inxi, journalctl output from around the time of the freeze, ...) it could be literally anything. Bad RAM, failing hard drive, ... literally anything.
Hi, welcome to this forum Masalale,
Please provide your config details with
inxi -Faz
For the third time please provide your inxi -Faz output. If your next post on this thread does not contain that information your thread will be binned.
Welcome to the forum, but this is not Reddit, we have rules here.
It seems the problem is Opera dev I've switched to Edge and it's smooth.
